#31
here you go, they do exist
http://www.atpcoinc.com/Pages/Products.html "Thomas J. Paladino Jr." wrote: I have always wondered why there are no small GA turboprops. It seems like most of the major problems & maintenance issues associated with GA aircraft are related to the piston motor, and as far as I can tell, turboprops are much more reliable, fuel efficient, smoother running and easier to maintain. So it begs the question, why are there no small turboprops in the 100-300hp range for use on GA aircraft? I would think that turbine engines of this size would be relatively easy to produce, and would be ideal for GA applications. The smoother operation and lower vibration levels would also ease wear and tear on the entire airframe and avionics components. So what's the deal? Does turbine technology not translate downwards very well? Would it be cost prohibitive? Am I entirely missing something? |
#32
the lanceair has a turbo prop version, I saw one take off few months back, fast
little airplane Bob Gardner wrote: Author Stuart Woods has a Malibu with a turbo engine, and I have seen a turbo-powered 206. Bob Gardner "Thomas J. Paladino Jr." wrote in message ... I have always wondered why there are no small GA turboprops. It seems like most of the major problems & maintenance issues associated with GA aircraft are related to the piston motor, and as far as I can tell, turboprops are much more reliable, fuel efficient, smoother running and easier to maintain. So it begs the question, why are there no small turboprops in the 100-300hp range for use on GA aircraft? I would think that turbine engines of this size would be relatively easy to produce, and would be ideal for GA applications. The smoother operation and lower vibration levels would also ease wear and tear on the entire airframe and avionics components. So what's the deal? Does turbine technology not translate downwards very well? Would it be cost prohibitive? Am I entirely missing something? |
#33
![]() "Robert M. Gary" wrote in message om... "Mike Rapoport" wrote in message link.net... Diesels are more promising. And can run on the same gas. And there's other sources for diesel...and maybe you can smoke it, too. http://www.artistictreasure.com/learnmorecleanair.html |
#34
"Peter Duniho" wrote in message ...
For experimentals, it sounds like (from one of George's earlier posts) that people ARE looking to incorporate small turbines into light airplanes, but I doubt it's cost effective. As near as I can tell, for a given horsepower, turbines are simply more expensive and for sure it's harder to find someone qualified to work on them. Maybe one day they'll be ubiquitous in a wide variety of applications, and they'll start showing up in light airplanes too. But it seems to me that until there's a huge market for certificated low-horsepower turbine engines, no one's going to bother working on them. Pete I know there's been an RV-4T - they grafted a turboprop onto the front of an RV-4. I think the biggest problem they had (besides fuel consumption) was that they didn't mount the exhaust stacks right, and it "backed up" a bit in the engine. |
#35
On Tue, 25 May 2004 00:40:15 GMT, "G.R. Patterson III"
wrote: Barney Rubble wrote: Slightly off-topic, why has no-on mentioned diesel engines (that run on Jet-A1)? This has got to be the way to go, better economy, better operation at altitude, simpler mechanicals (less to break) and FADEC/ECU controlled? Actually, because of the higher compression ratios, the mechanicals are not simpler. I know that the forces generated during compression are higher at a higher compresion ratio, but I cannot imagine that they are higher than the power forces. Now whether the power forces (peak) are higher in a compression ignition engine ... maybe (and probably), but I've never seen data from conn rod strain gages. |
#36
G.R. Patterson III opined
Greg Copeland wrote: Is simple economics the answer? $30k piston versus something like $80k turbine, or something like that? It's certainly one answer. The price on that Maule is $450,000. With an IO-540, it's $173,420. I've read that there are technical problems building small turbines; ie. the smaller the diameter of the turbine, the faster the blades must spin to produce power. The biggie is edge effects. There is a minimum clearance between the turbine and the case, and that clearance is independent of the diameter of the turbine. So small turbines have much higher tip losses. -ash Cthulhu for President! Why vote for a lesser evil? |
#37
wrote: Actually, because of the higher compression ratios, the mechanicals are not simpler. Well sort of. Some two stroke cycle diesels don't have overhead valves. No diesel has a spark ignition system. This type of engine could be considered mechanically more simple than a four stroke cycle engine. But the fuel pump is a lot more complex and higher pressure, and most diesels have either a turbo supercharger or a mechanically driven supercharger, or both. See http://www.deltahawkengines.com/index.htm for an example of a very cool V four two stroke diesel engine intended for the homebuilt market initially, and perhaps eventual certification. Corky Scott |
#38
"Gerald Sylvester" wrote in message
nk.net... Did you know you can buy true turbo jets for model aircraft? They cost about $3000 and give about 20 lb thrust, They are around 4" in diameter. I then said to a guy, "Man that sounds like a turbine." He told me it was. This is what we were talking about earlier with the jet engines on the Cri-cri. http://www.amtjets.com/gallery_real_plain.html Some more "normal" and some unusual applications: http://www.amtjets.com/gallery.html Paul |
#39
Hi George,
Slightly off-topic, why has no-on mentioned diesel engines (that run on Jet-A1)? This has got to be the way to go, better economy, better operation at altitude, simpler mechanicals (less to break) and FADEC/ECU controlled? Actually, because of the higher compression ratios, the mechanicals are not simpler. I know that the forces generated during compression are higher at a higher compresion ratio, but I cannot imagine that they are higher than the power forces. Now whether the power forces (peak) are higher in a compression ignition engine ... maybe (and probably), but I've never seen data from conn rod strain gages. Peak pressure during combustion is about twice as high on a diesel engine compared to a spark ignition engine (about 160 bar / 2400 psi vs. 80 bar / 1200 psi). Hence the heavier build of diesels. On the plus side, diesels run about 200 degC cooler than SI-engines even though most diesels are turbocharged vs. naturally aspirated gasolines. However diesels are MUCH more simple in mixture control - there is none. You just inject the amount of fuel you need to burn to achieve the desired torque. On gasoline (spark ignition) engines you control the engine torque by restricting the air flow with a throttle. You then have to match the fuel flow to the varying air flow pretty precisely. Also, the entire ignition system, spark plugs, magnets, is omitted on a diesel. 50% of engine problems on aviation piston engines is related to ignition problems. regards, Friedrich -- for personal email please remove "entfernen" from my adress |
#40
On Mon, 24 May 2004 at 17:31:12 in message
, Peter Duniho wrote: "David CL Francis" wrote in message ... [...] Can you explain why the efficiency of turbines is much higher at altitude? What sort of efficiency are you talking about? Mainly the same reason turbocharged reciprocating engines operate more efficiently at altitude. You're carrying around a compressor that just isn't all that useful down low. Once you get higher, where there's less drag, you get more "bang for the buck" out of the engine. Of course, as Mike Rapaport pointed out, there's also the issue of efficiency with respect to the size of the engine (independent of operating altitude). But is that efficiency? I would have thought that efficiency was measurement by a parameter like pounds of fuel used per effective shaft horsepower per hour. That certainly changes with altitude but not so much. -- David CL Francis |
Small Aircraft Transportation System (SATS) first practical trial | Larry Dighera | Piloting | 0 | November 27th 03 03:11 PM |
Order your FREE Small Blue Planet Toys Christmas Catalog before Oct 20th! | Small Blue Planet Toys | Aviation Marketplace | 0 | October 15th 03 05:26 PM |
Air Force announces winner in Small Diameter Bomb competition | Otis Willie | Military Aviation | 0 | August 30th 03 03:06 AM |
Small Blue Planet Toys goes Postal !! Economy Shipping Options now availalble | Small Blue Planet Toys | Aviation Marketplace | 0 | July 11th 03 04:00 PM |
HUGE Summer SALE + Free Shipping @ Small Blue Planet Toys | Small Blue Planet Toys | Aviation Marketplace | 0 | July 8th 03 11:53 PM |
