#91
On Mon, 24 May 2004 16:21:20 -0500, "Dan Luke"
wrote: wrote: There weren't that many German night fighters so if the entire bomber swarm passed through the sector together, the night fighter would not get an opportunity to attack multiple targets. They basically took off, headed for an assembly point and turned for the target when they reached it. You sure about that? I thought the Brit bombers attacked in a "bomber stream" rather than any kind of group formation. -- Dan Please read what I said again Dan. I'm not claiming that they flew a formation, what I said was that they took off and headed for an assembly point, then turned for the target. The bombers all had to head for the assembly point so that the swarm/stream could get into the same flight path. If they did not do this, the bomber stream would be greatly dispersed. Perhaps assembly point is a poor term, use "initial point" or "turn in" point instead and perhaps you'll see what I mean. They did not actually "assemble" at the turning point, they just used it as a navigation aid to locate where they were and turn to the target heading, or the initial navigation point towards their target. Each bomber did this individually and flew individually climbing as they left their airfield. So they weren't forming a formation, not in the sense of the US daylight bombing, they were just arriving at this point and turning to the target. From then on until they had the target in sight, each individual bomber was responsible for it's own navigation. They often could see other bombers in decent weather, and obviously could also see each other being shot down. During the bombing raid on Nuremburg in 1944, the weather was crystal clear above a low cloud layer and the moon was bright. The bombers stuck out like they were flying during the day. The Germans happened to have numerous fighters orbiting several radio beacons directly in the line of flight and once they released the fighters to engage, the German pilots had little trouble finding targets. So bright was the night that the Wild Sau (undirected single seat fighters, as opposed to twin engine radar guided night fighters) figured prominantly in the nights activities. Nearly 100 bombers were shot down. Corky Scott |
#92
![]() "Peter Duniho" wrote in message ... "Capt.Doug" wrote in message ... It's not neccessarily about doing her a favor. If someone called the FAA safety hotline, what would happen? Do you think there is enough of a case for a successful prosecution? I doubt it. All that would likely happen is that her attitude would become more cavalier because she beat the Feds at their game. That's baloney. First of all, from the description given, there were plenty of witnesses to make a case, plus there's going to be a record of the damage to the plane. Secondly, so what if this particular case isn't the one that gets her? Unless people are willing to report irresponsible piloting like that, the FSDO never has a chance to even start building a case. As for her attitude becoming "more cavalier", I can't imagine how it could be any more cavalier than it already is. Just how much worse could she possibly get? She's already nearly killed herself, running the plane into something in flight. Any more cavalier, and she won't be a problem because she WILL be dead. Pete Then again we have only heard one side of the story. Sure would be interesting to hear the other side. It's funny how things change once both sides have their chance to speak.. |
#93
Cub Driver wrote:
In THE FOG OF WAR, Robert McNamara talks about This video has been recommended to me. Is it worth seeing? (I'm not interested in a Michael Moore screed. I get all that stuff I can stand on the local cocktail party circuit.) Yes, THE FOG OF WAR is the kind of documentary that *should* have won a Palme d'Or. Try to see it in a theatre if you can -- I was trembling when I walked out, and I'm not easily moved or impressed by documentaries. All the best, David |
#94
"David Megginson" wrote in message
. rogers.com... I read somewhere about bomber squadrons forming up in low vis before a raid. Often the crews wouldn't see the conflicting plane, but they'd feel the wake turbulence and then realized that they'd survived another near miss. Time Team (programme on TV here in the UK) had an archeological dig of a site where two B17s collided in cloud...or rather of where they ended up in the ground. http://www.channel4.com/history/time...e/reedham.html Paul |
#95
... As for her attitude becoming "more cavalier", I can't imagine how it could be any more cavalier than it already is. Just how much worse could she possibly get? She's already nearly killed herself, running the plane into something in flight. Any more cavalier, and she won't be a problem because she WILL be dead. Well, she did recogise that she should get on the ground ASAP and landed when and where she did. Paul |
#96
"Roger Halstead" wrote in message
... [...] What I don't understand is why some one would be frustrated seeing some one else doing something foolish. Every day I see people not eating right, eating too much, and not exercising which is probably just as dangerous as scud running and I'm not condoning either one. The difference being that they are much less likely to kill someone else while engaging in those dangerous activities, and they won't be used against the rest of us pilots to "prove" to the public that flying is too dangerous to be allowed to happen without even more regulation. Pete |
#97
"Paul Sengupta" wrote in message
... "David Megginson" wrote in message . rogers.com... I read somewhere about bomber squadrons forming up in low vis before a raid. Often the crews wouldn't see the conflicting plane, but they'd feel the wake turbulence and then realized that they'd survived another near miss. Time Team (programme on TV here in the UK) had an archeological dig of a site where two B17s collided in cloud...or rather of where they ended up in the ground. http://www.channel4.com/history/time...e/reedham.html Paul Paul, Can't immeadiately recall if it's our Discovery Channel or History Channel but that series is being re-packaged/re-aired over on this side of the pond. I saw that particular episode ... very good stuff. Jay B |
#98
In article , Paul Sengupta wrote:
Time Team (programme on TV here in the UK) had an archeological dig of a site where two B17s collided in cloud...or rather of where they ended up in the ground. A B-17 collided with the Isle of Man during the war. They were cruising at about 1200' MSL over the Irish Sea, and someone forgot about the big rock in the middle and they slammed into the side of North Barrule. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
#99
![]() "Tom Sixkiller" wrote in message ... Do you know the difference between a A36 and a V35? Yes. Do you know the difference between a V35 and an ultralight? Does he? You'd have to ask him. |
#100
I would argue the point that an individual who flies VFR in IMC is a
skillful pilot. Most pilots would suggest that flying in IMC and being lost in a thunderstorm do not demonstrate good judgment or skill. She stated that it was so difficult to control the plane that she couldn't take her hands off the yoke to hit the "nearest" button on her GPS to find the closest airport. I do not think this demonstrates a high level of proficiency or judgment. I spoke with our mechanic today- the plane had tree bark and leaves embedded in the wingtip and leading edge. This to me would suggest that at some point in time she had hit a tree. These are the facts of the post- if you do not believe that these events brought this individual close to killing herself so be it. |
Homebuilt Airplane Crash | Harry O | Home Built | 1 | November 15th 04 03:40 AM |
Bizzare findings of Flight 93 crash in PA on 9-11 | Laura Bush murdered her boy friend | Military Aviation | 38 | April 12th 04 08:10 PM |
AF investigators cite pilot error in fighter crash | Otis Willie | Military Aviation | 0 | January 9th 04 09:55 PM |
Sunday's Crash in LI Sound | Marco Leon | Piloting | 0 | November 5th 03 04:34 PM |
Homemade plane crash | Big John | Home Built | 9 | October 17th 03 06:45 PM |
