Turbine question
Old May 28th 04, 07:29 PM
DeltaDeltaDelta
Default Turbine question
I've noted that turbine conversions of piston planes have become popular
(Turbine Bonanza, JetProp, Turbine Otter...). While reading the pireps of
these planes in Private Pilot, I saw that in most of these planes, the
turbine appeared to be turned "backwards", ie with the rear nozzle turned
toward the prop and the exhaust pipes near the spinner. Why is this so?
Triple Delta
Old May 28th 04, 09:18 PM
Ditch
The engines they use for the conversion are typically the Rolls Royce whatever
(formerly the Allison 250). These are reverse flow, free spinning turbines.
Basically, the air enters the front and is routed thru the engine from back to
front.
The PT-6 is the same way (what I am currently flying). The Garretts (Or
whatever they are called today) are direct drive turbines and the airflow is
front to back.
-John
*You are nothing until you have flown a Douglas, Lockheed, Grumman or North
American*
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 06:03 AM
Why are there no small turboprops? Thomas J. Paladino Jr. Piloting 59 June 8th 04 03:57 PM
turbine propeller sebastian Home Built 19 March 21st 04 01:47 AM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 10:41 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 02:26 AM
