#11
Veeduber wrote:
Too expensive, right? I think so too. But the cost of LED's continues to drop and ultrabrights will probably be down to a nickle each by the time the bird is ready to fly, if ever. -R.S.Hoover Did you count on using less LED's as you went up and down. The superbright LED's come in packages that will spread the light through a 45 degree angle. Combine that with the need to have less light output in the up and down directions, and you come out needing only about 10 LEDs. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
![]() Did you count on using less LED's as you went up and down. The superbright LED's come in packages that will spread the light through a 45 degree angle. Combine that with the need to have less light output in the up and down directions, and you come out needing only about 10 LEDs. ok, good idea. but, the more light the better, when you want to be seen and avoided, so perhpas a you want a mix of narrow angle LEDs covering the horizon and broad beam LEDs as well. -Jeff |
(Jay) wrote in message . com...
(Jeff Peterson) wrote in message om... In order to get the wide angle coverage you need, you can either use a large number of LEDs, each with a narrow beam or you can use the same number of LEDs each with a broad light beam. When you grind the front off the LEDs the forward-directed brightness (officially called the luminous intensity [in milli-candella, aka mcd] ) will be decreased because the light is no longer directed forward but is spread out instead. The total amount of light emitted (officially called the luminous flux [in lumens, aka lm]) is not affected by grindind off the front. This means you need just as many ground-off LEDs as you do intact ones. The advantage of grinding them off is that you dont need to go to all the trouble of pointing them every which way. As far as scratches go, yes, they do diffuse the light output, and that's just what you want. You save having to do as much pointing but you have to grind and POLISH each one. The scratches cause a loss in the total flux. Look at what you have to do to prepare the ends of fiber for installation of connectors, and thats even for the longer wavelengths in IR. you polish optical fiber so one end will press tightly up against the next and transmit the light with little reflection. effectively you get a direct glass to glass connection, at 1.3 microns, if the ends are polished well. in our application the LED plastic case terminates and the light continues in air. there will be about a 4 percent reflection here. unless we were so fussy as to anti-reflection-coat the plastic we are stuck with this 4% reflection. cant fix this by polishing. a scratched up surface diffuses the transmitted light to a wide pattern but doesnt reduce the flux. by the way, painting the body white helps increase output by giving that light reflected back into the plasitc a second cahnce to get out. i noticed this coincidence: all these devices seem to use about the same current, 20 ma. so very likely they have similar flux. i think the more expensive ones are the ones that have the LED chip located very close to the focus of the hemispherical lens....these have the narrow beam that gives them high mcd numbers. if you are grinding the dome off, it doesnt make sense to pay extra for this. They use the same current because its the same little chunck of Si. The cost of molding the lens doesn't vary much depending on the angle. What you're paying all the money for as I understand it is: 1) Pick of the litter, the semi-conductor die vary in efficiency and are binned. You pay more for the really good one, and less for the others. i am no expert on this, but i think the selection is to find the ones with the narrow (and therefore bright) beams. we want braod beams so would should buy the cheaper LEDs |
Is this something like what your talking about?
http://www.killacycle.com/Lights.htm "Veeduber" wrote in message ... Little while back, on the subject of LED's, I mentioned that if they weren't bright enough simply use more of them. That produced a couples of queries from homebuilders wanting to know how many and how-to. The how-to is easy, especially if you're a ham radio operator, pick your teeth with a soldering iron and have been passing notes to your buds in Morse code since the fourth grade. Circuit board is an insulator such as phenolic or fiberglas with a layer of copper glued to one or both sides. Single-sided stuff is inexpensive and commonly available. To mount an LED by the bulb you simply drill a 5mm hole (.196" givertake), poke the LED thru the hole and give it a dot of crazy glue. That leaves the LED with its head sticking out one side and its legs out the other. One leg is for power, the other for ground. Bend the ground leg over and solder it to the copper then collect the other legs singly or in sets, according to how you want to wire it, solder them to a dropping resister and connecting the other of the resister end to power. Let there be light... and there usually is. Want them to flash? Then you gotta pony up another dollar fifty. That'll buy you a NE555 timer chip, a capacitor, three quarter-watt resisters and a generic PNP transister. Crazy-glue the timer chip to the circuit board 'dead bug,' meaning it's legs are sticking up, solder the thing together in the proper manner and your LED will blink sixty times a minute with whatever duty cycle you've selected. If we're talking a nominal 12vdc and up to 45 LED's, a 1:10 duty cycle will give you a nice flasher that should last about 100,000 hours... mebbe a little less. That's one way. Trouble is, with the LED just poking through the circuit board it's staring straight ahead; most of its light is going to be in a cone that's only about 20 degrees wide. Even a hundred LED's won't put out very much light if viewed from the side. To be seen from the side the LED has to be pointing to the side... which means it can't be pointing anywhere else at the same time. So you use a buncha them, pointing ever whichaway. Do you need FORTY-FIVE of those suckers? At about half a buck each the red ones aren't too expensive, their production having been subsidized by their use as automotive tail lights. And ultra-bright white LED's are down to about two bucks because they are coming into common use for flashlights and such. But those green jobbies cost the earth... nearly three bucks each. So you're looking at two hundred and fifty bucks worth of LED's... which is about a big handful. On the up-side, it's a one-time cost. Build them right into the airframe, GLUE on the molded Lexan cover, forget about it. Okay, but why FORTY-FIVE of those suckers? Got an orange? Okay, a grapefruit then. Cut it in half. Now you got a hemi-sphere. That's your tail light's coverage. Take the other half of the grapefruit and slice IT in half. Now you got two quada-spheres, or whatever. They are your wing tip nav-light's coverage. Remember the part about the 20 degree angle? Take one of the wing tip chunks of grapefruit and divide it into twenty-degree slices. (Don't cut it, use a marking pin on the rind; you can eat it for breakfast tomorrow. Yeah, I know... but she already thinks you're crazy anyway.) 180 degrees, you need about 9 LED's. 90 degrees, about five. (yeah, it overlaps a bit) Nine times five is 45. So how do you do that? How do you arrange 45 LED's so their output covers a quarter of a sphere? Take a look at an LED. The tip is about the size of a grain of popcorn. Now imagine your wing-tip nav light is little EAR of popcorn with nine kernels from top to bottom that tapers smoothly to the end FIVE kernels away. Now all we have to do is replace the kernels with LED's :-) Looks something like the eye of a bug. To make something like that I used the comptuer to make a drawing showing rows of holes for the legs of the LED's. Glued it to the non-copper side of the circuit board. Started drilling. (#80 carbide burr; about 12,000 rpm. SOP for anyone who fiddles with electronics.) (The pattern is about 3-3/16" long, 1-3/16" wide at its fattest point, which happens to be 1-3/16" back of the nose, and is a smooth tear-drop shape. The holes are logically placed so that their LED can be bent to the proper angle.) Over on the copper side of the board the hole for the grounded leg is left straight. The leg will be poked through it then bent over and soldered to the copper cladding. But the hole for the power leg gets deburred with a regular 1/8" diameter drill bit having an angle of 116 degrees. That gives me a shallow NON-CONDUCTIVE hole through which the hot leg of the LED protrudes. From that point on the wiring is exactly the same as for the first example, with a dropping resister (about 4 cents each) attached to each leg, or to pairs or even sets of three... depending on how you want to wire it. The LED's get poked into their holes to a depth determined by the ANGLE to which they have to be bent, which I worked out on the comptuer before I started drilling. Since the pattern is symmetrical this isn't as tough as it sounds. Basically, the LED's in the middle stick up about 3/4" and stand up straight. The ones on the outside only stand up about a quarter of an inch and get bent over at 90 degrees. Between the middle row and the outer row you've got three LED's, each standing about an eighth of an inch higher, each bent at a different angle. Not a very good description but you should get the idea. The computer also provides the profile of the Lexan cover, which starts life as two poster-board templates to which you glue some crunchy urethane foam then sand it into a smooth surface. Coat that with something that will harden up nice -- I used sheet-rock mud -- then use it to make a female mold and from that pull a solid plug of either Portland cement or Plaster of Paris. The cement shrinks a bit more than the plaster but both are saturated and have to be cured for about ten days before you can use them to make your cover, which you do by gluing flannel to the plug, greasing it up and popping it into the oven with a hunka Lexan balanced on top. When the Lexan gets rubbery, protect your hand and mold the plastic to the plug. Do that until you have a nice symmetrical shape. Now do it again for the other wing. If you know about thermoplastics and canopies and who shot John you know you can use the original mold to flare the skirt so as to form a flange. Trim that, apply sealant and attach it with glue, rivets or whatever... you won't be removing it. Did you want fries with that? Or mebbe a strobe? Then order a batch of item # 06040 from Harbor Freight. You can throw away the case; all you want is the guts. It has its own plastic shield. Trim a piece of aluminum so the clear plastic is a nice fit then glue the guts to the aluminum... or whatever... and mount them ALL OVER your airplane... wing tips, top & bottom of the fuselage, top of the vertical stabilizer, ass-end of the rudder... wherever you want a bright little spark of light. The little strobe costs about eight bucks and runs on two AA cells. Forget that and pony up another buck per unit for an LM340T-5 voltage regulator and a couple of caps, an electrolytic 470uF/16v for the input and a disk ceramic ..1uF for the output. Screw the LM340T-5 to the piece of aluminum to which you've mounted the guts and solder it all up. 18ga. wire is over-kill for either the stobe or the flashing LED's The strobes aren't very bright but then, neither are they very large nor expensive... use a buncha them. It won't keep the Big Boys from running your ass down but it might scare the crows out of your way. ---------------------------------------------------------- Too expensive, right? I think so too. But the cost of LED's continues to drop and ultrabrights will probably be down to a nickle each by the time the bird is ready to fly, if ever. -R.S.Hoover |
Notice, no white rear light there...
-- Dan D. http://www.ameritech.net/users/ddevillers/start.html .. "Snoopy" Snoopy is wrote in message ... Is this something like what your talking about? http://www.killacycle.com/Lights.htm "Veeduber" wrote in message ... Little while back, on the subject of LED's, I mentioned that if they weren't bright enough simply use more of them. That produced a couples of queries from homebuilders wanting to know how many and how-to. The how-to is easy, especially if you're a ham radio operator, pick your teeth with a soldering iron and have been passing notes to your buds in Morse code since the fourth grade. Circuit board is an insulator such as phenolic or fiberglas with a layer of copper glued to one or both sides. Single-sided stuff is inexpensive and commonly available. To mount an LED by the bulb you simply drill a 5mm hole (.196" givertake), poke the LED thru the hole and give it a dot of crazy glue. That leaves the LED with its head sticking out one side and its legs out the other. One leg is for power, the other for ground. Bend the ground leg over and solder it to the copper then collect the other legs singly or in sets, according to how you want to wire it, solder them to a dropping resister and connecting the other of the resister end to power. Let there be light... and there usually is. Want them to flash? Then you gotta pony up another dollar fifty. That'll buy you a NE555 timer chip, a capacitor, three quarter-watt resisters and a generic PNP transister. Crazy-glue the timer chip to the circuit board 'dead bug,' meaning it's legs are sticking up, solder the thing together in the proper manner and your LED will blink sixty times a minute with whatever duty cycle you've selected. If we're talking a nominal 12vdc and up to 45 LED's, a 1:10 duty cycle will give you a nice flasher that should last about 100,000 hours... mebbe a little less. That's one way. Trouble is, with the LED just poking through the circuit board it's staring straight ahead; most of its light is going to be in a cone that's only about 20 degrees wide. Even a hundred LED's won't put out very much light if viewed from the side. To be seen from the side the LED has to be pointing to the side... which means it can't be pointing anywhere else at the same time. So you use a buncha them, pointing ever whichaway. Do you need FORTY-FIVE of those suckers? At about half a buck each the red ones aren't too expensive, their production having been subsidized by their use as automotive tail lights. And ultra-bright white LED's are down to about two bucks because they are coming into common use for flashlights and such. But those green jobbies cost the earth... nearly three bucks each. So you're looking at two hundred and fifty bucks worth of LED's... which is about a big handful. On the up-side, it's a one-time cost. Build them right into the airframe, GLUE on the molded Lexan cover, forget about it. Okay, but why FORTY-FIVE of those suckers? Got an orange? Okay, a grapefruit then. Cut it in half. Now you got a hemi-sphere. That's your tail light's coverage. Take the other half of the grapefruit and slice IT in half. Now you got two quada-spheres, or whatever. They are your wing tip nav-light's coverage. Remember the part about the 20 degree angle? Take one of the wing tip chunks of grapefruit and divide it into twenty-degree slices. (Don't cut it, use a marking pin on the rind; you can eat it for breakfast tomorrow. Yeah, I know... but she already thinks you're crazy anyway.) 180 degrees, you need about 9 LED's. 90 degrees, about five. (yeah, it overlaps a bit) Nine times five is 45. So how do you do that? How do you arrange 45 LED's so their output covers a quarter of a sphere? Take a look at an LED. The tip is about the size of a grain of popcorn. Now imagine your wing-tip nav light is little EAR of popcorn with nine kernels from top to bottom that tapers smoothly to the end FIVE kernels away. Now all we have to do is replace the kernels with LED's :-) Looks something like the eye of a bug. To make something like that I used the comptuer to make a drawing showing rows of holes for the legs of the LED's. Glued it to the non-copper side of the circuit board. Started drilling. (#80 carbide burr; about 12,000 rpm. SOP for anyone who fiddles with electronics.) (The pattern is about 3-3/16" long, 1-3/16" wide at its fattest point, which happens to be 1-3/16" back of the nose, and is a smooth tear-drop shape. The holes are logically placed so that their LED can be bent to the proper angle.) Over on the copper side of the board the hole for the grounded leg is left straight. The leg will be poked through it then bent over and soldered to the copper cladding. But the hole for the power leg gets deburred with a regular 1/8" diameter drill bit having an angle of 116 degrees. That gives me a shallow NON-CONDUCTIVE hole through which the hot leg of the LED protrudes. From that point on the wiring is exactly the same as for the first example, with a dropping resister (about 4 cents each) attached to each leg, or to pairs or even sets of three... depending on how you want to wire it. The LED's get poked into their holes to a depth determined by the ANGLE to which they have to be bent, which I worked out on the comptuer before I started drilling. Since the pattern is symmetrical this isn't as tough as it sounds. Basically, the LED's in the middle stick up about 3/4" and stand up straight. The ones on the outside only stand up about a quarter of an inch and get bent over at 90 degrees. Between the middle row and the outer row you've got three LED's, each standing about an eighth of an inch higher, each bent at a different angle. Not a very good description but you should get the idea. The computer also provides the profile of the Lexan cover, which starts life as two poster-board templates to which you glue some crunchy urethane foam then sand it into a smooth surface. Coat that with something that will harden up nice -- I used sheet-rock mud -- then use it to make a female mold and from that pull a solid plug of either Portland cement or Plaster of Paris. The cement shrinks a bit more than the plaster but both are saturated and have to be cured for about ten days before you can use them to make your cover, which you do by gluing flannel to the plug, greasing it up and popping it into the oven with a hunka Lexan balanced on top. When the Lexan gets rubbery, protect your hand and mold the plastic to the plug. Do that until you have a nice symmetrical shape. Now do it again for the other wing. If you know about thermoplastics and canopies and who shot John you know you can use the original mold to flare the skirt so as to form a flange. Trim that, apply sealant and attach it with glue, rivets or whatever... you won't be removing it. Did you want fries with that? Or mebbe a strobe? Then order a batch of item # 06040 from Harbor Freight. You can throw away the case; all you want is the guts. It has its own plastic shield. Trim a piece of aluminum so the clear plastic is a nice fit then glue the guts to the aluminum... or whatever... and mount them ALL OVER your airplane... wing tips, top & bottom of the fuselage, top of the vertical stabilizer, ass-end of the rudder... wherever you want a bright little spark of light. The little strobe costs about eight bucks and runs on two AA cells. Forget that and pony up another buck per unit for an LM340T-5 voltage regulator and a couple of caps, an electrolytic 470uF/16v for the input and a disk ceramic .1uF for the output. Screw the LM340T-5 to the piece of aluminum to which you've mounted the guts and solder it all up. 18ga. wire is over-kill for either the stobe or the flashing LED's The strobes aren't very bright but then, neither are they very large nor expensive... use a buncha them. It won't keep the Big Boys from running your ass down but it might scare the crows out of your way. ---------------------------------------------------------- Too expensive, right? I think so too. But the cost of LED's continues to drop and ultrabrights will probably be down to a nickle each by the time the bird is ready to fly, if ever. -R.S.Hoover |
![]() "Jay" wrote in message om... (Jeff Peterson) wrote in message om... In order to get the wide angle coverage you need, you can either use a large number of LEDs, each with a narrow beam or you can use the same number of LEDs each with a broad light beam. When you grind the front off the LEDs the forward-directed brightness (officially called the luminous intensity [in milli-candella, aka mcd] ) will be decreased because the light is no longer directed forward but is spread out instead. The total amount of light emitted (officially called the luminous flux [in lumens, aka lm]) is not affected by grindind off the front. This means you need just as many ground-off LEDs as you do intact ones. The advantage of grinding them off is that you dont need to go to all the trouble of pointing them every which way. As far as scratches go, yes, they do diffuse the light output, and that's just what you want. You save having to do as much pointing but you have to grind and POLISH each one. The scratches cause a loss in the total flux. Look at what you have to do to prepare the ends of fiber for installation of connectors, and thats even for the longer wavelengths in IR. i noticed this coincidence: all these devices seem to use about the same current, 20 ma. so very likely they have similar flux. i think the more expensive ones are the ones that have the LED chip located very close to the focus of the hemispherical lens....these have the narrow beam that gives them high mcd numbers. if you are grinding the dome off, it doesnt make sense to pay extra for this. They use the same current because its the same little chunck of Si. The cost of molding the lens doesn't vary much depending on the angle. This is correct. The flux, or total light output, does not change. We either spread it out, or concentrate it. What you're paying all the money for as I understand it is: 1) Pick of the litter, the semi-conductor die vary in efficiency and are binned. You pay more for the really good one, and less for the others. Not quite the whole story. In ascending order of output AND price: 1. Gallium Phosphide 2. Gallium Aluminum Arsenide 3. Allium Indium Gallium Phosphide (AlInGaP, pronounced like the abbreviation) 4. Indium Gallium Nitride (InGaP, ditto) All of the major die manufacturers bin their die. I won't tell you the ratios of brightest to dimmest, quantity-wise, but reputable LED manufacturers are interested in producing product yielding the most efficient use of the wafer. Specifying bins (bright OR dim ones) dictates a significant price penalty to the user. Naturally, over a product lifetime, the entire wafer goes up in intensity, but the primary factor in retail price is the wafer material, shown above. 2) New process technologies- All these really bright LEDs are the result of recent changes in semiconductor processing, so there is less competition because less guys can make them. Yes, and add that material #4 is the subject of a patent dispute, only recently negotiated (or subverted). Regarding position lights, commercially-available 3mm (aka T-1) LEDs are possible at 500 mcd over a 50-degree angle. There are some VERY high intensity LED packages not available to the retail user (yet), e.g. the red and blue lightheads and in unmarked cruisers. Yes, these are LEDs, not strobes. Bernie in the LED business for 20 years remove my age to reply directly |
For an excellent four channel dimming system that handles LEDs see:
http://www.fdatasystems.com/LC_40.htm R "baltobernie" wrote in message ... "Jay" wrote in message om... (Jeff Peterson) wrote in message om... In order to get the wide angle coverage you need, you can either use a large number of LEDs, each with a narrow beam or you can use the same number of LEDs each with a broad light beam. When you grind the front off the LEDs the forward-directed brightness (officially called the luminous intensity [in milli-candella, aka mcd] ) will be decreased because the light is no longer directed forward but is spread out instead. The total amount of light emitted (officially called the luminous flux [in lumens, aka lm]) is not affected by grindind off the front. This means you need just as many ground-off LEDs as you do intact ones. The advantage of grinding them off is that you dont need to go to all the trouble of pointing them every which way. As far as scratches go, yes, they do diffuse the light output, and that's just what you want. You save having to do as much pointing but you have to grind and POLISH each one. The scratches cause a loss in the total flux. Look at what you have to do to prepare the ends of fiber for installation of connectors, and thats even for the longer wavelengths in IR. i noticed this coincidence: all these devices seem to use about the same current, 20 ma. so very likely they have similar flux. i think the more expensive ones are the ones that have the LED chip located very close to the focus of the hemispherical lens....these have the narrow beam that gives them high mcd numbers. if you are grinding the dome off, it doesnt make sense to pay extra for this. They use the same current because its the same little chunck of Si. The cost of molding the lens doesn't vary much depending on the angle. This is correct. The flux, or total light output, does not change. We either spread it out, or concentrate it. What you're paying all the money for as I understand it is: 1) Pick of the litter, the semi-conductor die vary in efficiency and are binned. You pay more for the really good one, and less for the others. Not quite the whole story. In ascending order of output AND price: 1. Gallium Phosphide 2. Gallium Aluminum Arsenide 3. Allium Indium Gallium Phosphide (AlInGaP, pronounced like the abbreviation) 4. Indium Gallium Nitride (InGaP, ditto) All of the major die manufacturers bin their die. I won't tell you the ratios of brightest to dimmest, quantity-wise, but reputable LED manufacturers are interested in producing product yielding the most efficient use of the wafer. Specifying bins (bright OR dim ones) dictates a significant price penalty to the user. Naturally, over a product lifetime, the entire wafer goes up in intensity, but the primary factor in retail price is the wafer material, shown above. 2) New process technologies- All these really bright LEDs are the result of recent changes in semiconductor processing, so there is less competition because less guys can make them. Yes, and add that material #4 is the subject of a patent dispute, only recently negotiated (or subverted). Regarding position lights, commercially-available 3mm (aka T-1) LEDs are possible at 500 mcd over a 50-degree angle. There are some VERY high intensity LED packages not available to the retail user (yet), e.g. the red and blue lightheads and in unmarked cruisers. Yes, these are LEDs, not strobes. Bernie in the LED business for 20 years remove my age to reply directly |
LED tail strobe | Jeff Peterson | Home Built | 41 | May 15th 04 03:13 PM |
1 watt and 5 watt LED for Nav lights? | Bill | Home Built | 21 | May 10th 04 05:15 PM |
LEDs for Nav Lights - Jim Weir | Scott Gettings | Home Built | 3 | February 17th 04 01:53 AM |
LEDs with Strobe lights | pekka1510 | Home Built | 11 | August 31st 03 11:36 PM |
LEDs | Morgans | Home Built | 6 | August 19th 03 03:49 AM |
