Instead of designing and building something that may or may not work
and taking years in the process why don't you just go out and buy the closest equivalent and have a certified airplane in the process. The Canadair CL-215. Big, roomy, radial engines, certified, you can redo the interior to your own specs, and if you want the big bulgy widows on the sides.... why not. Available now...... You could be actually flying throughout those Pacific Islands within months. |
Shiver Me Timbers wrote:
Instead of designing and building something that may or may not work and taking years in the process why don't you just go out and buy the closest equivalent and have a certified airplane in the process. The Canadair CL-215. Big, roomy, radial engines, certified, you can redo the interior to your own specs, and if you want the big bulgy widows on the sides.... why not. CL-415 would be better with enhanced performance and more dependable engines... Course if you want the real thing: http://www.barnstormers.com/listing....es%40cs-ent.ca And cost a fraction of what a new CL-415 geauxs for... |
"Tom Osmundson" wrote in message om... Yes, the PBY never had flaps, but I'm going to put some 30% chord fowler flaps over about 70% of the span. Should be pretty close to STOL then with a good power to weight ratio. I've got access to Catia V5, so I'm ok there. I have more experience using ProE wildfire, but that's what I got. :-) The gear will weigh a lot, and I want to make sure it is up to rough fields. I think it can be reasonable in weight if one puts enough time into it. I've been looking at safety issues right off the bat with this concept. I've already went through NTSB stuff on the Catalina as well as other types, like the seawind. So I've been documenting problems such as the nose wheel doors on the catalina collapsing causing a nose-over in the water. You mention loosing an engine might be a problem with 2x200 hp. I had been looking at the power loading of several twins and have noticed many with similar power loading. In fact a 1997 PA-34 Seneca V has 2 engines rated 200 hp continuous (220 for TO) with a gross of 4750 lbs, but a stall speed of 70 mph. But you do bring up a good point about SE performance, and that's one thing I will keep an eye on. Thanks for your comments! Keep em coming! Tom Look carefully at the props. A seaplane needs a lot of thrust at low airspeeds to break free of the water. The very high wing Catalina would allow for large, slow props which, being much more efficient, would allow lower HP for the same performance. Of course you have to deal with the water spray erosion of the blades but modern Kevlar-carbon blades might survive better than metal. Reversible props would allow the airplane to pivot on it's center for good water handling. Seaplane safety depends a lot on just how slowly the aircraft leaves and returns to the water. Your idea of Fowler flaps is a good one. The Catalina's big, high aspect ratio wing helps too. Bill Daniels |
Darrel Toepfer wrote:
CL-415 would be better with enhanced performance and more dependable engines... True.... But a Catalina has those big round engines and so does the CL-215. Some of those will be on the used market for a whole lot less than a turbine model. Course if you want the real thing: http://www.barnstormers.com/listing....es%40cs-ent.ca And cost a fraction of what a new CL-415 geauxs for... Parts, parts, parts. With a Canadair CL-215 you can phone, fax, or e-mail Bombardier and have brand new parts delivered overnight. If you want to cruise the islands of the Pacific do you want to be flying a sixty year old plane with no factory support or an airplane that is still being made with one hundred percent factory support. |
"kumaros" wrote in message ...
to have. Better than a sailboat. I recall a French series of nature documentaries filmed in Patagonia etc. featuring a huge amphibian twin-engined aircraft, sort of a flying combination of a house, a boat and an airplane. I wish I could find the name of the series. Maybe something involving Jaques Cousteau? He had a converted Catalina. Veeduber - "pilot's head in the pylon" - the shoulders are in the hull, then? |
Maybe something involving Jaques Cousteau? He had a converted Catalina. Veeduber - "pilot's head in the pylon" - the shoulders are in the hull, then? Yes, but his son died in the crash.... |
I watched the series on PBS a while back (probably a couple years) it was
very interesting. Completely purpose built. But alas, sorry I have no other info on it! John kumaros wrote: "Kathryn & Stuart Fields" wrote in message ... Nathan: Several of us including a P.E have set around the table talking about the same thing. Diesel engines great for the lagoon hopping out in the So. Pacific. I even approached one of Burt Rutan's test pilots and told him to get Burt working on the idea..?? I think the idea is neat.. We spent 8 years out in the Pacific in the Marshall islands and the type of ship you are playing with would be the thing to have. Better than a sailboat. I recall a French series of nature documentaries filmed in Patagonia etc. featuring a huge amphibian twin-engined aircraft, sort of a flying combination of a house, a boat and an airplane. I wish I could find the name of the series. Kumaros It's all Greek to me |
Hey maybe he is as interested in designing as he is building and flying!
Go for it. John Dibs on shotgun on first passenger flight! ;-) Shiver Me Timbers wrote: Instead of designing and building something that may or may not work and taking years in the process why don't you just go out and buy the closest equivalent and have a certified airplane in the process. The Canadair CL-215. Big, roomy, radial engines, certified, you can redo the interior to your own specs, and if you want the big bulgy widows on the sides.... why not. Available now...... You could be actually flying throughout those Pacific Islands within months. |
On Thu, 10 Jun 2004 11:28:59 +0000, John Oliveira wrote:
PBY was only US warplane (not counting single engine observation) that did not have flaps! You're kidding right? Many of the pre-WWII US warplanes did not have flaps. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ e-mail: khorton02(_at_)rogers(_dot_)com |
| Anyone recommend a source for designing hinged wings? | Tim Schoenfelder | Home Built | 8 | August 28th 03 03:07 AM |
