In article , Michael wrote:
"Roger Long" wrote I had an idea today which worked well and I wonder if anyone sees a downside. I always operate our 172 N on the ground leaned to the max. Instead of using the brakes this morning, I just leaned some more until the engine sagged and controlled my speed that way. Turning the vernier knob didn't seem much more work than pushing the throttle in and out. Running super lean like that must be good for the plugs. There is no downside whatsoever to your idea. You can't possibly hurt your engine by overleaning at these power settings. Not only that, you'll prevent yourself from trying to take off after forgetting to push the mixture control back in because the engine will probably quit if you try. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
"Roger Long" wrote in message . ..
I like to keep RPM in ground operations just over 1000 to minimize fouling. This is always a compromise with brake usage however. Controlling speed by riding the brakes is a clear no, no. One suggestion a CFI made to me recently is to just leave the throttle alone, apply brakes briefly, let the plane pick up speed again, repeat as necessary. I had an idea today which worked well and I wonder if anyone sees a downside. I always operate our 172 N on the ground leaned to the max. Instead of using the brakes this morning, I just leaned some more until the engine sagged and controlled my speed that way. Turning the vernier knob didn't seem much more work than pushing the throttle in and out. Running super lean like that must be good for the plugs. The first year I owned my Mooney IO-360 engine I had the plugs cleaned 3 times. The next year I took the advice that if increasing throttle causes an increase in RPM, you are too rich in taxi. Since then I've not cleaned any plugs outside of annual. I also bought an EDM with fuel flow. I now can lean in cruise much better. Flying a Mooney in cruise with full rich mixture can cause it to burn almost as much gas as a Bonanza (i.e. Chevy Suburban ![]() -Robert |
Who's At Fault in UAV/Part91 MAC? | Larry Dighera | Instrument Flight Rules | 24 | April 29th 04 03:08 PM |
Va and turbulent air penetration speed. | Doug | Owning | 69 | January 11th 04 08:35 PM |
Control Tower Controversy brewing in the FAA | PlanetJ | Instrument Flight Rules | 168 | December 6th 03 01:51 PM |
Antenna Ground Plane Grounding | Fastglasair | Home Built | 1 | July 8th 03 05:21 PM |
