I once stopped at an FBO in Minneapolis with a Seneca. The lineman
brought out the JET-A truck. Scary to think what could happen if I wasn't paying attention. I'm sure the larger piston twins (Navajo, 421, etc) have this happen even more often. On Wed, 09 Jun 2004 14:33:00 GMT, "Helix" wrote: For more hints on Precise Flying and Safety...Click Here A simple test of AVGAS for Jet Fuel Contamination Fred H. Quarles ATP-CFII(resume) Fueling Safety Certain piston aircraft are particularly susceptible to mis-fueling incidents and you should be especially vigilant if you are flying one of these birds. Among them are the TURBO charged versions of many airplanes. In the desire to be the hottest thing going, manufacturers often labeled their aircraft "TURBO" or some such designation. And inadequately trained linemen thinking that these were kerosene burning jet airplanes of some sort often put JET FUEL where AVGAS should have gone. This created a lethal comgination for many unsuspecting pilots. The plane would start and apparently run ok, even enough for takeoff, but would start having engine detonation problems about the time the point of no return was reached on takeoff, causing a engine failure shortly after takeoff at low altitude, resulting in a fatal crash." This scenario has been repeated many times, usually with some pilot and passengers getting killed. Aero Commander aircraft seem to be particularly susceptible to this sort of mis-fueling, as do Piper Turbo Arrow aircraft and other airplanes with TURBO painted on them IF You Suspect Fuel Contamination Do NOT FLY!!! Check it out first. A simple way to test for jet fuel contamination of AVGAS is to take a fuel sample, put a drop of fuel on a piece of white paper. If there is a 5% or more concentration of jet fuel in the avgas, it will leave a visible oily residue, turning the paper translucent. If it is avgas only, the avgas will evaporate cleanly and leave no trace. (I developed this test and gave it to the AOPA Air Safety Foundation. It was later validated by NASA. You can get a copy of the report from AOPA ASF, Frederick Airport, Frederick, MD) Another way to avoid fueling accidents is to BE PRESENT EVERY SINGLE TIME WHEN YOUR PLANE IS RE-FUELED. NEVER TURN YOUR BACK ON THIS PROCEEDING. Always VISUALLY Check the fuel truck to be sure you are getting the appropriate fuel Yourself. LOOK AT THE FUEL TRUCK. Always VISUALLY CHECK THE FUEL LEVEL YOURSELF AFTER FUELING. (lOOK INSIDE THE TANK) ALWAYS put the fuel cap back on YOURSELF. Check that it is secure so it won't come loose in flight. NEVER RELY ON A LINEMAN FOR THESE PARTICULAR INSPECTIONS. The Most Common Cause of Inflight Engine Failure Running out of fuel is the most common cause of in flight engine failure. If you follow the safety procedures above, you can go a long way to preventing an engine failure. EVERY Flight (1) Watch the re-fueling. BE PRESENT while this is going on. (2) Visually make sure they are puttinG the right sort of fuel in the aircraft. (the truck is marked AVGAS or JET FUEL.... Look at it (3) Look in the tank after the fueling and KNOW what the fuel level is. (4) ALWAYS Put the fuel cap back on YOURSELF. Make sure it is aligned properly and closes properly. If it comes loose your fuel will siphon out without your being aware of what is happening. (5) Keep a LARGE RESERVE of fuel. The lower your experience level the more important this is. It gives you the luxury of time to sort out a problem if you are lost, dis-oriented, or otherwise have a time consuming problem in flight. If you are low on fuel, your anxiety level will increase exponentially, making it difficult to think under stress and increase your chance of an accident. After my first experience long ago in nearly running out of gas, I have made it a practice, to KEEP ONE FULL TANK in reserve. I use a little bit of it in flight to confirm it is not contaminated and I when I am sure it is ok, I use it for the next takeoff and keep the other tank full for the next leg. This way, I minimize further the chance of getting caught by surprise, either on takeoff or landing, with contaminated fuel. Losing an engine on takeoff, at night, or on landing is VERY DISCONCERTING. Today's navigation equipment makes it possible to navigate more precisely. However this stuff can and does fail. If you are low on fuel when it happens (the usual situation), then your chance for running out of gas goes way up. This is even more true at night, in haze, or limited visibility conditions Fred H. Quarles ATP-CFII (resume) 888-595-9131 http://IFRGROUNDSCHOOL.cjb.net http://10day.cjb.net http://go.to/hints http://ferrypilot.cjb.net |
This happens lots with turbine conversions.
"Nathan Young" wrote in message ... I once stopped at an FBO in Minneapolis with a Seneca. The lineman brought out the JET-A truck. Scary to think what could happen if I wasn't paying attention. I'm sure the larger piston twins (Navajo, 421, etc) have this happen even more often. On Wed, 09 Jun 2004 14:33:00 GMT, "Helix" wrote: For more hints on Precise Flying and Safety...Click Here A simple test of AVGAS for Jet Fuel Contamination Fred H. Quarles ATP-CFII(resume) Fueling Safety Certain piston aircraft are particularly susceptible to mis-fueling incidents and you should be especially vigilant if you are flying one of these birds. Among them are the TURBO charged versions of many airplanes. In the desire to be the hottest thing going, manufacturers often labeled their aircraft "TURBO" or some such designation. And inadequately trained linemen thinking that these were kerosene burning jet airplanes of some sort often put JET FUEL where AVGAS should have gone. This created a lethal comgination for many unsuspecting pilots. The plane would start and apparently run ok, even enough for takeoff, but would start having engine detonation problems about the time the point of no return was reached on takeoff, causing a engine failure shortly after takeoff at low altitude, resulting in a fatal crash." This scenario has been repeated many times, usually with some pilot and passengers getting killed. Aero Commander aircraft seem to be particularly susceptible to this sort of mis-fueling, as do Piper Turbo Arrow aircraft and other airplanes with TURBO painted on them IF You Suspect Fuel Contamination Do NOT FLY!!! Check it out first. A simple way to test for jet fuel contamination of AVGAS is to take a fuel sample, put a drop of fuel on a piece of white paper. If there is a 5% or more concentration of jet fuel in the avgas, it will leave a visible oily residue, turning the paper translucent. If it is avgas only, the avgas will evaporate cleanly and leave no trace. (I developed this test and gave it to the AOPA Air Safety Foundation. It was later validated by NASA. You can get a copy of the report from AOPA ASF, Frederick Airport, Frederick, MD) Another way to avoid fueling accidents is to BE PRESENT EVERY SINGLE TIME WHEN YOUR PLANE IS RE-FUELED. NEVER TURN YOUR BACK ON THIS PROCEEDING. Always VISUALLY Check the fuel truck to be sure you are getting the appropriate fuel Yourself. LOOK AT THE FUEL TRUCK. Always VISUALLY CHECK THE FUEL LEVEL YOURSELF AFTER FUELING. (lOOK INSIDE THE TANK) ALWAYS put the fuel cap back on YOURSELF. Check that it is secure so it won't come loose in flight. NEVER RELY ON A LINEMAN FOR THESE PARTICULAR INSPECTIONS. The Most Common Cause of Inflight Engine Failure Running out of fuel is the most common cause of in flight engine failure. If you follow the safety procedures above, you can go a long way to preventing an engine failure. EVERY Flight (1) Watch the re-fueling. BE PRESENT while this is going on. (2) Visually make sure they are puttinG the right sort of fuel in the aircraft. (the truck is marked AVGAS or JET FUEL.... Look at it (3) Look in the tank after the fueling and KNOW what the fuel level is. (4) ALWAYS Put the fuel cap back on YOURSELF. Make sure it is aligned properly and closes properly. If it comes loose your fuel will siphon out without your being aware of what is happening. (5) Keep a LARGE RESERVE of fuel. The lower your experience level the more important this is. It gives you the luxury of time to sort out a problem if you are lost, dis-oriented, or otherwise have a time consuming problem in flight. If you are low on fuel, your anxiety level will increase exponentially, making it difficult to think under stress and increase your chance of an accident. After my first experience long ago in nearly running out of gas, I have made it a practice, to KEEP ONE FULL TANK in reserve. I use a little bit of it in flight to confirm it is not contaminated and I when I am sure it is ok, I use it for the next takeoff and keep the other tank full for the next leg. This way, I minimize further the chance of getting caught by surprise, either on takeoff or landing, with contaminated fuel. Losing an engine on takeoff, at night, or on landing is VERY DISCONCERTING. Today's navigation equipment makes it possible to navigate more precisely. However this stuff can and does fail. If you are low on fuel when it happens (the usual situation), then your chance for running out of gas goes way up. This is even more true at night, in haze, or limited visibility conditions Fred H. Quarles ATP-CFII (resume) 888-595-9131 http://IFRGROUNDSCHOOL.cjb.net http://10day.cjb.net http://go.to/hints http://ferrypilot.cjb.net |
"Vigo" wrote in message ... This happens lots with turbine conversions. Damn, dude, - TRIM. That was a 6k post for 6 words. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.701 / Virus Database: 458 - Release Date: 6/7/2004 |
... I once stopped at an FBO in Minneapolis with a Seneca. The lineman brought out the JET-A truck. Scary to think what could happen if I wasn't paying attention. I'm sure the larger piston twins (Navajo, 421, etc) have this happen even more often. There's going to be an even bigger problem now with diesel piston engines starting to become more common in GA. Paul |
Particularly when there are Spam Cans with diesel conversions. "You want
Jet-A in that Skyhawk!? Are you crazy?" -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "Paul Sengupta" wrote in message ... "Nathan Young" wrote in message ... I once stopped at an FBO in Minneapolis with a Seneca. The lineman brought out the JET-A truck. Scary to think what could happen if I wasn't paying attention. I'm sure the larger piston twins (Navajo, 421, etc) have this happen even more often. There's going to be an even bigger problem now with diesel piston engines starting to become more common in GA. Paul |
| Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 06:15 AM |
| Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | S Green | Instrument Flight Rules | 3 | June 11th 04 12:20 AM |
| Looking for Cessna Caravan pilots | [email protected] | Owning | 9 | April 1st 04 03:54 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
