Hi all what would be involved in converting a GPU to a usable aircraft
powerplant ? looking specifically at the O-290. Ive googled and not come up with much. Thanks in advance. Sean Trost |
powerplant ? looking specifically at the O-290. Ive googled and not come up with much. That's really an ancient question! A good bet is to contact EAA (you are a member, of course) and get references from them -- old copies of Sport Aviation (now available on CD-ROM), and maybe a dedicated book on the topic. Ed WIschmeyer Member, EAA Homebuilt Aircraft Council |
I gots one of them there how to convert books, It's 9 years older'n God,
but so's the engine--I'll send you a little pitcher of it & yew can see---yew better price all the parts you might need for o/haul berfore you decide---they's a gittin scarce.... Sean Trost wrote: Hi all what would be involved in converting a GPU to a usable aircraft powerplant ? looking specifically at the O-290. Ive googled and not come up with much. Thanks in advance. Sean Trost |
At one time the EAA had a manual on the procedure and may still be
available. Ken Brock used to machine the cases to remove the heavy mounting flange and add a second mag drive. The O-290 crank has a light prop flange that is prone to cracking. Aircraft Spruce and Ken Brock both sell a re-inforcement plate. See p172 of the current Aircraft Spruce catalog. If you want this engine, I know there are many of them just languishing in the back of hangars. I have a friend that flew his LongEze for many trouble free hours before he replaced it with an O-320. I believe the parts are getting harder to find and more expensive was the basic reason he didn't overhaul it. -- Cy Galley Safety Programs Editor EAA Sport Pilot "Sean Trost" wrote in message . com... Hi all what would be involved in converting a GPU to a usable aircraft powerplant ? looking specifically at the O-290. Ive googled and not come up with much. Thanks in advance. Sean Trost |
Thanks to all who responded.
The Motor in Question is on Ebay right now For those interested. I have decided to wait and try and score a 320 or 360 somehow. Sean Trost Sean Trost wrote: Hi all what would be involved in converting a GPU to a usable aircraft powerplant ? looking specifically at the O-290. Ive googled and not come up with much. Thanks in advance. Sean Trost |
Sean, where is that O-290 GPU on eBay.
I searched but couldn't find it. Regards, Gordon. "Sean Trost" wrote in message ... Thanks to all who responded. The Motor in Question is on Ebay right now For those interested. I have decided to wait and try and score a 320 or 360 somehow. Sean Trost Sean Trost wrote: Hi all what would be involved in converting a GPU to a usable aircraft powerplant ? looking specifically at the O-290. Ive googled and not come up with much. Thanks in advance. Sean Trost |
Gordon,
looks to me like it has two mags on it. and an aircraft sump. so mebeee not a GPU. its item #2481925834 good luck Sean Gordon Arnaut wrote: Sean, where is that O-290 GPU on eBay. I searched but couldn't find it. Regards, Gordon. "Sean Trost" wrote in message ... Thanks to all who responded. The Motor in Question is on Ebay right now For those interested. I have decided to wait and try and score a 320 or 360 somehow. Sean Trost Sean Trost wrote: Hi all what would be involved in converting a GPU to a usable aircraft powerplant ? looking specifically at the O-290. Ive googled and not come up with much. Thanks in advance. Sean Trost |
Earlier, Sean Trost wrote
...and an aircraft sump... I disagree. The downdraft carb behind the accessory case is one of the hallmarks of the O-290G, so I believe that it still has the GPU sump. Also, the heavy crankcase flange at the crank output is another O-290G giveaway. It _does_ look like it has two mags, and that's a puzzler to me. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
I say,Gov'nr, ---if you remove the governor, you can install another mag.
Bob Kuykendall wrote: Earlier, Sean Trost wrote ...and an aircraft sump... I disagree. The downdraft carb behind the accessory case is one of the hallmarks of the O-290G, so I believe that it still has the GPU sump. Also, the heavy crankcase flange at the crank output is another O-290G giveaway. It _does_ look like it has two mags, and that's a puzzler to me. Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
Earlier, jerry Wass wrote:
I say,Gov'nr, ---if you remove the governor, you can install another mag. Ah, so that's what that beastie is. Thanks! Bob K. |
| V-8 powered Seabee | Corky Scott | Home Built | 212 | October 3rd 04 12:45 AM |
| Harley engine special | Brett | Home Built | 106 | May 28th 04 04:10 AM |
| Auto conversions & gear boxes | Dave Covert | Home Built | 56 | April 1st 04 07:19 PM |
| VW conversions | John McFarlane | Home Built | 3 | November 5th 03 02:03 AM |
