Interesting that many have not defined the origin of the placement of
the "red line" on the tachometer. I don't know where to look it up, but I suspect it has something to do with prop tip speed (as one poster mentioned). Shorten the prop, lengthen the prop, change the pitch and you will necessisarily change the placement of the redline on the tach. Change the pistons (bore); change the rods (stroke); change the rings (compression); change the induction system; change the exhaust (back pressure) and you change the torque of the engine, again altering the redline. |
necessisarily change the placement of the redline on the tach. Doesn't this imply that redline RPM isn't related to engine limitations? Why would (just for example) shortening the prop allow one to raise the RPM limit of the engine? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Doesn't this imply that redline RPM isn't related to engine limitations? I believe it's both. Why would (just for example) shortening the prop allow one to raise the RPM limit of the engine? It's bad to allow the prop tip to go supersonic. I believe that this is because the shock wave reduces the efficiency of the prop. Others can chime in on this. Shortening the prop "slows" the linear speed that the prop tip is experiencing at a given RPM. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
"EDR" wrote in message ... Interesting that many have not defined the origin of the placement of the "red line" on the tachometer. I don't know where to look it up, but I suspect it has something to do with prop tip speed (as one poster mentioned). It can have something to do with it, but the same engine in different airplanes will have a different redline. The thing that changes is TBO. The propeller chosen for that installation will be consistent with the engine service life desired. |
In article , C J Campbell
wrote: "EDR" wrote in message ... Interesting that many have not defined the origin of the placement of the "red line" on the tachometer. I don't know where to look it up, but I suspect it has something to do with prop tip speed (as one poster mentioned). It can have something to do with it, but the same engine in different airplanes will have a different redline. The thing that changes is TBO. The propeller chosen for that installation will be consistent with the engine service life desired. That's right. Some airplanes have prohibited operation in the middle of the RPM range because of harmonics. Certain models of Cessna 210's, for example. |
RPM limit of the engine? It's bad to allow the prop tip to go supersonic. Understood. However, how is it that you can up the RPM limit of a given engine simply because you want to keep the prop tips subsonic? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
However, how is it that you can up the RPM limit of a given engine simply because you want to keep the prop tips subsonic? You would decrease the RPM limit, not increase it, to keep the tips subsonic. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
simply because you want to keep the prop tips subsonic? You would decrease the RPM limit, not increase it, to keep the tips subsonic. Understood. If you lengthened the prop, you'd have to decrease the RPM redline to keep the tips subsonic. However, the part of the question I was referring to was if you *shortened* the prop. Part of the original post implied that you would be able to simply *increase* the engine's redline RPM if you shortened your prop, regardless of engine limitations. I don't believe this is true. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Mon, 14 Jun 2004 19:39:46 GMT, "Jay Honeck"
wrote: However, how is it that you can up the RPM limit of a given engine simply because you want to keep the prop tips subsonic? You would decrease the RPM limit, not increase it, to keep the tips subsonic. Understood. If you lengthened the prop, you'd have to decrease the RPM redline to keep the tips subsonic. However, the part of the question I was referring to was if you *shortened* the prop. Part of the original post implied that you would be able to simply *increase* the engine's redline RPM if you shortened your prop, regardless of engine limitations. I don't believe this is true. It isn't true. Theoretically, you could increase the redline rpm providing you don't exceed the limitations of any other part of the "system", such as the engine. The redline would have to be based upon the most restrictive component. Rich Russell |
Found the source, sort of...
http://www.airweb.faa.gov/Regulatory...rgAdvisoryCirc ular.nsf/0/c2f903127f0f41e4862569ae006d44d7/$FILE/AC20-88A.pdf ANNOUNCEMENT OF AVAILABILITY OF ADVISORY CIRCULAR 20-88A; LINES ON THE MARKING OF AIRCRAFT POWERPLANT INSTRUMENTS (DISPLAYS) g. Tachometer (Reciprocating Engine Aircraft) Red Radial - At maximum permissible rotational speed (rpm). Green Arc - From maximum rotational speed for continuous operation to minimum recommended for continuous operation (except in the restricted range, if any). For propeller driven small airplanes which must meet the requirements in Appendix F to Part 36 of the FAR at maximum normal operating power, from the corrected rotational speed used to establish the aircraft noise level to the minimum recommended for continuous operation (except in the restricted ranges, if any). Yellow Arc - From maximum rotational speed for continuous operation to maximum permissible rotational speed. Yellow Arc (Offset) - Conditional operating range for one engine inoperative flight that exists above the normal takeoff rating limit (if applicable). Red Arc - Range(s) in which operation is restricted, except to pass through, for all operating conditions because of excessive stresses, etc. |
| Are You Flying a "Beater?" | Jay Honeck | Piloting | 90 | June 16th 04 12:38 PM |
| Contract Tower Program - Discussion Thread | running with scissors | Instrument Flight Rules | 6 | April 22nd 04 05:04 AM |
| Baby Bush will be Closing Airports in California to VFR Flight Again | Larry Dighera | Piloting | 119 | March 13th 04 03:56 AM |
| Fuel line thread sealant | Paul Lee | Home Built | 7 | February 26th 04 01:44 AM |
| recovery from inverted IMC (a propos of "backup gyros" thread) | Sydney Hoeltzli | Piloting | 4 | July 15th 03 03:00 PM |
