#21
Recently, m pautz posted:
So, the question I have for the group is why are power planes taught to have these wide patterns with low angled turns? I was taught similarly to you to fly tight patterns. A dead stick landing while in the pattern was a part of my check ride. It's in the PTS. FWIW, I'm as good as "dead stick" on final most of the time. So, I suspect that these stretched patterns at low altitudes are just bad habits built up over time. Why are the patterns outside the glide angle of a powerless airplane? I had a friend who died because of engine failure. The pilot was within gliding distance of the airport, but he didn’t know how to fly a power-out pattern. They crashed short of the runway on final. There are no "patterns outside the glide angle of a powerless plane" AFAIK. Pattern altitudes are typically at least 1,000' above GL, and if in the pattern, it's up to the pilot to make sure that the field can be made in the event of an engine failure. It seems that your friend failed on that last part, possibly not due to a lack of know-how. Neil |
On 16 Jun 2004 15:23:53 -0700, (Michael) wrote:
And what happens when you eventually hit an updraft? If you're already high, hot, and slipping like crazy, that updraft will put you too high and hot to land, and you will need to go around. 2400 feet gives a lot of room for error. I've never experienced an updraft. The airfields here most often are crowded with pines on either side; perhaps that has something to do with it? (Flying downwind at pattern altitude at Lakes Region in Wolfeboro NH, you can't even see the runway for the pines.) all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! weblog www.vivabush.org |
#24
However rare an engine failure in the pattern might be we've all read
about them. I can't recall anyone ever hitting an updraft in a cub, citabria, etc. on final that pushed them so high they missed the field. Where have you seen this? I also try to be high on final and then slip if needed. Just curious Dave 68 7ECA Michael wrote: Cub Driver wrote Personally, I have gone back to power-off landings for just this reason. And I try, not always successfully, to come in "high, hot, and slipping like crazy" since I don't have the option of raising the flaps. And what happens when you eventually hit an updraft? If you're already high, hot, and slipping like crazy, that updraft will put you too high and hot to land, and you will need to go around. Here's a bit of reality - unless you run out of gas, it is highly unlikely that an engine that was working just fine when you entered the pattern will fail so suddenly and so completely that it won't produce enough power to flatten your glide enough for you to make the runway given a reasonable pattern. On the other hand, it may well crap out badly enough that you won't have the power to go around - especially if you are flying a 65 hp Cub, which is a marginal performer anyway. I'm all for keeping the pattern close in, but there are limits to everything. Michael |
#25
![]() Michael wrote: Cub Driver wrote Personally, I have gone back to power-off landings for just this reason. And I try, not always successfully, to come in "high, hot, and slipping like crazy" since I don't have the option of raising the flaps. And what happens when you eventually hit an updraft? If you're already high, hot, and slipping like crazy, that updraft will put you too high and hot to land, and you will need to go around. Here's a bit of reality - unless you run out of gas, it is highly unlikely that an engine that was working just fine when you entered the pattern will fail so suddenly and so completely that it won't produce enough power to flatten your glide enough for you to make the runway given a reasonable pattern. On the other hand, it may well crap out badly enough that you won't have the power to go around - especially if you are flying a 65 hp Cub, which is a marginal performer anyway. I'm all for keeping the pattern close in, but there are limits to everything. Michael high, hot, and slipping like crazy High: correct, but as I will explain later high is better than low. Hot: A normal power-off landing need not be any hotter than than a powered approach. I was taught to come in with normal approach speed. Cub D. comes in hot because there is no runway too short for a cub and he is using the kenetic energy as a safety buffer instead of power. The same buffer can be provided with potential energy (coming in high) Slipping: Not needed unless your flaps are boken. Cub driver uses slips because he is experienced and practices this (Also because he likes them). Dave already explained how his wife made the runway with an extemely high approach. And what happens when you eventually hit an updraft? If you're already high On a peice of paper draw a side view of the runway, a high approach and a low approach. You will see that *minor* changes in the approach angle with the low approach has a *major* change on your touch-down spot. The same angle change of a high approach has a *minor* change on the touch-down spot. For example: presume that you come in with a powered-approach that has a glide angle of 40:1 and Mr. C150 comes in with a high approach that has a 10:1 glide angle. If an updraft raises you 50 feet, your touch down spot has moved 2000 feet. If that same updraft raises Mr. C150 50 feet, his touch down spot only moves 500 feet. When I was being taught power-off approaches 30 years ago, I asked my instructor the same question about getting too high. He setup an approach that was so high above the numbers, I didn't think we would make the other end of the runway. He pulled full flaps and I was amazed at how short we landed. and you will need to go around. I have been flying power-off landings and have not done a go-around in 30 years. Here's a bit of reality - unless you run out of gas, it is highly unlikely... I agree with you completely. Due to the unlikely nature of a power failure, maybe it has been proven that a powered approach is safer; maybe not. I don't know. That is why I asked the original question. However, here is another bit of reality from Wolfgang Langewiesche, "But meanwhile it can't be denied that engine failure, though very unlikely, is very serious if it does happen, and that the accuracy of his power-off approach can thus suddenly become the most important thing in he pilot's life." Even a 767 was successfully landed with no power because the pilot had extensive practice in power-off landings. http://www.wadenelson.com/gimli.html My main point is that if you don't practice power-off landings when your power works, you won't be able to do it when the the power doesn't work. Marty Pautz "promote a society that respects its elders; before it is too late." |
#26
dave wrote
However rare an engine failure in the pattern might be we've all read about them. Actually, the only ones I know of where there wasn't enough power left to limp to the runway were indeed fuel exhaustion. I can't recall anyone ever hitting an updraft in a cub, citabria, etc. on final that pushed them so high they missed the field. Where have you seen this? In Texas, where we routinely see 500 fpm updrafts in the summer. I was in a Cub. I knew I was a little high and a little hot and I was already slipping - and then I hit an updraft and nothing I did was good enough to get down. Oh, I suppose I might have managed a landing well past midfield but at that point a go-around seemed like the hot tip. I also try to be high on final and then slip if needed. There's a difference between a little high on final and slip off the altitude if need be, and being high, hot, and slipping like crazy on every approach. I favor the former, but not the latter. In a glider, the ideal approach is one where you fly your pattern with half spoilers - in the middle of your range. That allows you to flatten the glide if you hit sink or steepen it if you hit lift. By the same token, in a no-flaps airplane I favor an approach that puts me about 1/3 of the way down the runway without slipping, and a medium slip to scrub off the altitude on short final - all of this at normal approach speed. I believe that if you need close to a maximum-effort slip on final, then one of two things happened - either you set up too high and too hot, or you hit a serious updraft on final. If you're consistently slipping hard down final, you're not leaving yourself an out against the day you have to fly short final over a hot parking lot. My objection is not to power-off patterns, which I favor. I also do not object to slipping down final a little, especially in a no-flaps airplane. I'm just saying that you can overdo it. Too much speed and altitude can be as bas as too little. Michael |
#27
"m pautz" wrote in message
news:IEhAc.62559$0y.6475@attbi_s03... Cub driver uses slips because he is experienced and practices this (Also because he likes them). And he hasn't got any flaps? Paul |
#28
![]() Paul Sengupta wrote: "m pautz" wrote in message news:IEhAc.62559$0y.6475@attbi_s03... Cub driver uses slips because he is experienced and practices this (Also because he likes them). And he hasn't got any flaps? Paul oops, My lack of knowledge is showing. I just presumed that all cubs had flaps. I just checked the internet and found out that the flaps didn't exist until the super cub. Fortunately I seem to learn something new every day. I should be real smart by my 200th birthday. :-) |
#29
![]() "Michael" wrote in message om... dave wrote However rare an engine failure in the pattern might be we've all read about them. Actually, the only ones I know of where there wasn't enough power left to limp to the runway were indeed fuel exhaustion. I can't recall anyone ever hitting an updraft in a cub, citabria, etc. on final that pushed them so high they missed the field. Where have you seen this? In Texas, where we routinely see 500 fpm updrafts in the summer. I was in a Cub. I knew I was a little high and a little hot and I was already slipping - and then I hit an updraft and nothing I did was good enough to get down. Oh, I suppose I might have managed a landing well past midfield but at that point a go-around seemed like the hot tip. In IL we get 1000 fpm thermals. Not sure why but at low altitudes, such as on final, they have little effect. They need altitude to develop or some such thing. As someone else explained, thermals have very little effect on touchdown point when flying a steep approach. Had you stayed with it you would have found you would have touched down very near your original touchdown point. Sink sems to be a much bigger issue than lift. The antidote for sink is high and slipping like crazy if you have to. |
#30
![]() Thanks for the additional information - Dan high, hot, and slipping like crazy High: correct, but as I will explain later high is better than low. Hot: A normal power-off landing need not be any hotter than than a powered approach. I was taught to come in with normal approach speed. Cub D. comes in hot because there is no runway too short for a cub and he is using the kenetic energy as a safety buffer instead of power. The same buffer can be provided with potential energy (coming in high) Slipping: Not needed unless your flaps are boken. Cub driver uses slips because he is experienced and practices this (Also because he likes them). Dave already explained how his wife made the runway with an extemely high approach. And what happens when you eventually hit an updraft? If you're already high On a peice of paper draw a side view of the runway, a high approach and a low approach. You will see that *minor* changes in the approach angle with the low approach has a *major* change on your touch-down spot. The same angle change of a high approach has a *minor* change on the touch-down spot. For example: presume that you come in with a powered-approach that has a glide angle of 40:1 and Mr. C150 comes in with a high approach that has a 10:1 glide angle. If an updraft raises you 50 feet, your touch down spot has moved 2000 feet. If that same updraft raises Mr. C150 50 feet, his touch down spot only moves 500 feet. When I was being taught power-off approaches 30 years ago, I asked my instructor the same question about getting too high. He setup an approach that was so high above the numbers, I didn't think we would make the other end of the runway. He pulled full flaps and I was amazed at how short we landed. and you will need to go around. I have been flying power-off landings and have not done a go-around in 30 years. Here's a bit of reality - unless you run out of gas, it is highly unlikely... I agree with you completely. Due to the unlikely nature of a power failure, maybe it has been proven that a powered approach is safer; maybe not. I don't know. That is why I asked the original question. However, here is another bit of reality from Wolfgang Langewiesche, "But meanwhile it can't be denied that engine failure, though very unlikely, is very serious if it does happen, and that the accuracy of his power-off approach can thus suddenly become the most important thing in he pilot's life." Even a 767 was successfully landed with no power because the pilot had extensive practice in power-off landings. http://www.wadenelson.com/gimli.html My main point is that if you don't practice power-off landings when your power works, you won't be able to do it when the the power doesn't work. Marty Pautz "promote a society that respects its elders; before it is too late." all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! weblog www.vivabush.org |
Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 06:49 PM |
"bush flying" in the suburbs? | [email protected] | Home Built | 85 | December 28th 04 11:04 PM |
VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 05:22 AM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
