I don't wish to sound like a smartass here, but what's your problem with
getting a full checkout in this airplane from a competent pilot current in the aircraft? It sounds like you might benefit from a bit of complex training here!!! Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt "Greg Copeland" wrote in message news ![]() On Thu, 24 Jun 2004 12:30:03 +0000, EDR wrote: In article , GE wrote: I'm taking delivery today of my first aircraft and it had a constant speed prop. I have only flown fixed props thus far. I want to have as much understanding of the c-s prop as possible before I get with my instructor. I understand the basic difference in what the controls do, but I don't really have a good understanding of the hows and whys of flying with them. Any general information, explanations, and tips would be greatly appreciated. Go to www.avweb.com on the left side of the screen, select COLUMNS scroll down to find THE PELICAN"S PERCH there are articles on fuel injection, manifold pressure, constant speed props, leaning, etc Everything you ever want to know about operating a high performance aircraft engine is in those articles. Great link! I started reading this article, http://www.avweb.com/news/columns/186619-1.html, and have a question. In the Runup section, when he starts to test for proper mag operation, somethings seems odd there. Can someone help explain that? He says, "Are the mags working? The leaner the mixture, the more mag drop you'll see on one mag, and that's normal." He then goes on to say, "The EGTs should rise on the first single-mag operation, stay there for the second, then drop again on the return to BOTH. That rise is proof-positive the entire ignition system is working, and working well, and the leaner the mixture, the more diagnostic it is." Can someone help explain the supporting logic there? If both mags are working properly and you switch to a single mag, why would the EGT go up? After all, in theory, you're producing less spark and thusly, a slightly less effecient ignition of the fuel/air. I would of thought that EGT would stay the same or go down *just slightly* when running off of one mag. Likewise, if one mag is not working, I would fully expect to see a big EGT drop for the given problematic mag, which he does agree with. But, he further asserts that, "If any of them fail to rise or even drop during single-mag operation, there is a problem with that plug, the wire, or the mag." So, why would running on one mag, versus two, always cause higher EGTs? And why would no rise in EGT indicate a bad mag, wire or plug? Anyone? P.S. I cross posted because this seems like good student pilot material too. |
The initial poster asking these questions sounds like he might benefit
from a complex checkout, or at least a thorough checkout in this airplane given by a competent pilot current in the aircraft! :-) Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt "Greg Copeland" wrote in message news ![]() On Thu, 24 Jun 2004 12:30:03 +0000, EDR wrote: In article , GE wrote: I'm taking delivery today of my first aircraft and it had a constant speed prop. I have only flown fixed props thus far. I want to have as much understanding of the c-s prop as possible before I get with my instructor. I understand the basic difference in what the controls do, but I don't really have a good understanding of the hows and whys of flying with them. Any general information, explanations, and tips would be greatly appreciated. Go to www.avweb.com on the left side of the screen, select COLUMNS scroll down to find THE PELICAN"S PERCH there are articles on fuel injection, manifold pressure, constant speed props, leaning, etc Everything you ever want to know about operating a high performance aircraft engine is in those articles. Great link! I started reading this article, http://www.avweb.com/news/columns/186619-1.html, and have a question. In the Runup section, when he starts to test for proper mag operation, somethings seems odd there. Can someone help explain that? He says, "Are the mags working? The leaner the mixture, the more mag drop you'll see on one mag, and that's normal." He then goes on to say, "The EGTs should rise on the first single-mag operation, stay there for the second, then drop again on the return to BOTH. That rise is proof-positive the entire ignition system is working, and working well, and the leaner the mixture, the more diagnostic it is." Can someone help explain the supporting logic there? If both mags are working properly and you switch to a single mag, why would the EGT go up? After all, in theory, you're producing less spark and thusly, a slightly less effecient ignition of the fuel/air. I would of thought that EGT would stay the same or go down *just slightly* when running off of one mag. Likewise, if one mag is not working, I would fully expect to see a big EGT drop for the given problematic mag, which he does agree with. But, he further asserts that, "If any of them fail to rise or even drop during single-mag operation, there is a problem with that plug, the wire, or the mag." So, why would running on one mag, versus two, always cause higher EGTs? And why would no rise in EGT indicate a bad mag, wire or plug? Anyone? P.S. I cross posted because this seems like good student pilot material too. |
![]() "C J Campbell" wrote in message ... I think Deakin is worth reading, but some of what he says should be taken with a grain of salt. His columns are mostly based on experiments with his own highly modified Bonanza, a few high performance radial engines, and some theory. In fact, a careful reading of his columns will show no test data for the most common engine and propeller combinations in use today. You've not read hiscolumns about the test beds they've run at GAMI? The reasons for this are fairly simple -- few airplanes have the instrumentation that Deakin needs to test his theories. This is why Deakin's theories for running lean of peak remain a minority view. Granted, it is a very noisy minority, but remember that it is also a small minority. I think they have a point. They may even be right. But they don't have nearly the evidence that they think they have. See above. Deakin's remarks are mostly pertinent to running TCM engines, which are much different than engines from other manufacturers. I bellieve they run Lycoming on the test bed as well, everything from pipsqueaks to the big 540's. Not to put too fine a point on it, some TCM engines are the only ones I know of that so consistently develop cracks that the most part of an annual inspection basically consists of measuring and cataloging the spread of these cracks. The engine used in the early 70's Cessna T206 rarely made it to its 1400 hour TBO, for example. Barring solid data to the contrary (and Deakin, remember, does not give you solid data -- he only appears to do that), your airplane should be operated in accordance with the manufacturer's recommendations. This will ensure that you maintain your insurance coverage, if nothing else. I think GAMI generated enough data on their stand to run a computer dry. http://www.engineteststand.com/ |
![]() I also highly recommend John C Eckalbar's books FLYING THE BEECH BONANZA and FLYING HIGH PERFORMANCE SINGLES AND TWINS These books will describe the relationship between aircraft weight and the various V-speeds you should know when you fly. |
On Thu, 24 Jun 2004 16:08:47 +0000, Dudley Henriques wrote:
I don't wish to sound like a smartass here, but what's your problem with getting a full checkout in this airplane from a competent pilot current in the aircraft? It sounds like you might benefit from a bit of complex training here!!! Dudley Henriques I wondered the same thing, but you're replying to the wrong person. I'm a student and GE posted the original question. Cheers! |
I caught that right after I posted it :-) I had cleaned out OE last
night back to four days old and missed the pickup. Thought I had deleted this but obviously it didn't work! Anyway.....it looks to me like the IP needs a complete checkout in this airplane before flying it. His questions just seem way out of line for someone taking delivery of an airplane they are rated and competent to fly! Sorry about the mispost :-) DH "Greg Copeland" wrote in message news ![]() On Thu, 24 Jun 2004 16:08:47 +0000, Dudley Henriques wrote: I don't wish to sound like a smartass here, but what's your problem with getting a full checkout in this airplane from a competent pilot current in the aircraft? It sounds like you might benefit from a bit of complex training here!!! Dudley Henriques I wondered the same thing, but you're replying to the wrong person. I'm a student and GE posted the original question. Cheers! |
On Thu, 24 Jun 2004 09:14:59 -0700, Tom Sixkiller wrote:
"C J Campbell" wrote in message ... I think Deakin is worth reading, but some of what he says should be taken with a grain of salt. His columns are mostly based on experiments with his own highly modified Bonanza, a few high performance radial engines, and some theory. In fact, a careful reading of his columns will show no test data for the most common engine and propeller combinations in use today. You've not read hiscolumns about the test beds they've run at GAMI? The reasons for this are fairly simple -- few airplanes have the instrumentation that Deakin needs to test his theories. This is why Deakin's theories for running lean of peak remain a minority view. Granted, it is a very noisy minority, but remember that it is also a small minority. I think they have a point. They may even be right. But they don't have nearly the evidence that they think they have. See above. Deakin's remarks are mostly pertinent to running TCM engines, which are much different than engines from other manufacturers. I bellieve they run Lycoming on the test bed as well, everything from pipsqueaks to the big 540's. Not to put too fine a point on it, some TCM engines are the only ones I know of that so consistently develop cracks that the most part of an annual inspection basically consists of measuring and cataloging the spread of these cracks. The engine used in the early 70's Cessna T206 rarely made it to its 1400 hour TBO, for example. Barring solid data to the contrary (and Deakin, remember, does not give you solid data -- he only appears to do that), your airplane should be operated in accordance with the manufacturer's recommendations. This will ensure that you maintain your insurance coverage, if nothing else. I think GAMI generated enough data on their stand to run a computer dry. http://www.engineteststand.com/ Is the data offered in the articles you refer to or is it available on the web site? It does not appear to be jumping out at me. I see a couple of pictures of some graphs, a webring link, and email address, and a link to gami.com. What am I missing? Thanks, Greg |
On Thu, 24 Jun 2004 08:55:30 -0700, "C J Campbell"
wrote: I think Deakin is worth reading, but some of what he says should be taken with a grain of salt. His columns are mostly based on experiments with his own highly modified Bonanza, a few high performance radial engines, and some theory. In fact, a careful reading of his columns will show no test data for the most common engine and propeller combinations in use today. The reasons for this are fairly simple -- few airplanes have the instrumentation that Deakin needs to test his theories. This is why Deakin's theories for running lean of peak remain a minority view. Granted, it is a very noisy minority, but remember that it is also a small minority. I think they have a point. They may even be right. But they don't have nearly the evidence that they think they have. Deakin's Bonanza is highly modified? I thought it had an ordinary Continental TIO-550. Or is that engine considered highly modified? Far as I know, from what I've read, the only extra instrument he has on his instrument panel is the JPI EGT analyzer. He has said repeatedly that in order to take advantage of running the engine lean of peak, you really have to have a multi cylinder EGT guage, otherwise you do not know if you are truly running all the cylinders lean of peak. One or two may still be on the rich side or at peak which would cause them to run a lot hotter than the lean ones. Deakin's remarks are mostly pertinent to running TCM engines, which are much different than engines from other manufacturers. Not to put too fine a point on it, some TCM engines are the only ones I know of that so consistently develop cracks that the most part of an annual inspection basically consists of measuring and cataloging the spread of these cracks. The engine used in the early 70's Cessna T206 rarely made it to its 1400 hour TBO, for example. Barring solid data to the contrary (and Deakin, remember, does not give you solid data -- he only appears to do that), your airplane should be operated in accordance with the manufacturer's recommendations. This will ensure that you maintain your insurance coverage, if nothing else. I guess I'll have to ask why you think Deakin does not give solid evidence for his recommendations. The GAMI folks (who's testing he repeatedly cites) have been testing different types of engines for years, and developed their precision injectors and proved them with more testing before marketing them. In addition, running engines lean of peak isn't new. When radial engines were what powered most commercial aircraft, cruising them lean of peak is what just about every pilot was trained to do. My father, who flew PB4Y-1's and -2's and P2V Neptunes used to tell me about flying them and how he set up for cruise and he mentioned the leaning process. Ernest Gann talked about it. There were even percentage of horsepower instruments in the big engined airliners that pilots were required to adjust the engines to using the lean of peak setting. It was the only way to get maximum range out of the airplane, at reasonable speed. Charles A. Lindbergh rather famously demonstrated to pilots in the South Pacific during WWII how to greatly extend their range using lean of peak operation. The technique worked for the F4U Corsair, the P-47 Thunderbolt, and most famously, the P-38 Lightning. The Lightning's range was extended to such a degree that it permitted the large twin engined fighter to accompany a bombing raid on a northern New Guinea Japanese airbase, which had previously been out of range for fighters. The Japanese were totally unprepared for the attack as they had believed no bombing force would dare attack without fighter escort, and they believed no American fighter had the range to make the trip from Port Moresby. The attack is sometimes cited as perhaps the single most effective raid of it's type in the Pacific War. How did Lindbergh learn about lean of peak operation? I have no idea when he first learned it or who taught him, but he knew about it when he made his sort of well known solo trip across the Atlantic Ocean. He leaned the engine visually, by leaning out the window and watching the exhaust flame change color as he leaned the engine. Deakin, as he stated several times in several different articles, isn't introducing something new. He's re-intruducing a technique that is old and well proven. It just did not work well with horizontally opposed aircraft engines until now. It worked very well for radials because the big ones all had impellers and equal length intake manifold runners. The impellers distributed exactly the same fuel/air mixture to each and every cylinder, every time it was ready to fire. Horizontally opposed engines don't have the benefit of equal fuel/air mixture being distributed to each cylinder. The GAMI people fix this by taking your EGT readings which you give them when you install a multi cylinder EGT guage and record the temperatures for each cylinder. Then they send you a set of injectors calibrated for each specific cylinder. If you install them properly (in the correct cylinders, which is very important), the rich cylinders will be leaned and the lean cylinders richened. The cylinder to cylinder distribution now becomes equal enough that leaning should not produce any rough engine operation. Some people had to return an injector to be recalibrated, sometimes several times, but eventually the EGT's reach relative uniformity. If you can run the engine lean of peak without engine roughness, which creates less heat in the engine, why would you not want to do that? Less heat, less fuel burned, nearly the same speed at cruise (a little less), what's wrong with this picture, anything? Can anyone explain how this could possibly hurt the engine? It can't burn valves because they are running cooler than they would if the mixture were set to rich of peak operation. You can't cause detonation because that's a result of heat and high power settings. The lean of peak setting is normally used at or above 7,000 to 8,000 feet where no normally aspirated engine is producing more than 60 or 65% power. With that percentage of power, it's impossible to cause detonation. Even Lycoming agrees with this. Unless you really need to get somewhere at maximum possible speed, in which case you would run the engine for best power which is a setting on the rich side of peak, I don't understand why everyone would not want to set for lean of peak cruise, when possible, if they have the right instrumentation and the engine tolerates it. It's possible that the POH's specify rich of peak operation because that produces the highest cruise speeds, which is often what sells the airplane. Corky Scott |
On Thu, 24 Jun 2004 17:47:41 GMT, "Dudley Henriques"
wrote: I caught that right after I posted it :-) I had cleaned out OE last night back to four days old and missed the pickup. Thought I had deleted this but obviously it didn't work! Anyway.....it looks to me like the IP needs a complete checkout in this airplane before flying it. His questions just seem way out of line for someone taking delivery of an airplane they are rated and competent to fly! Sorry about the mispost :-) DH "Greg Copeland" wrote in message news ![]() On Thu, 24 Jun 2004 16:08:47 +0000, Dudley Henriques wrote: I don't wish to sound like a smartass here, but what's your problem with getting a full checkout in this airplane from a competent pilot current in the aircraft? It sounds like you might benefit from a bit of complex training here!!! Dudley Henriques I wondered the same thing, but you're replying to the wrong person. I'm a student and GE posted the original question. Cheers! I applaud the original poster. He said, " I have only flown fixed props thus far. I want to have as much understanding of the c-s prop as possible before I get with my instructor." He's trying to learn a little something in advance so he doesn't start completely cold with the instructor. He is seeking complex training and proactively preparing in advance for that training. Rich Russell |
I caught that right after I posted it :-) I had cleaned out OE last night back to four days old and missed the pickup. Thought I had deleted this but obviously it didn't work! Anyway.....it looks to me like the IP needs a complete checkout in this airplane before flying it. His questions just seem way out of line for someone taking delivery of an airplane they are rated and competent to fly! Sorry about the mispost :-) FWIW, I just (today!) completed complex and high performance checkouts. Before I started the actual work, though, I read a fair bit on both the specific aircraft and constant-speed prop use in general. [I even posted some questions here, I believe.] Reading ahead is never a bad idea, in my experience (granted: I don't read many mysteries {8^). - Andrew |
PA28: Difference in constant speed prop vs fixed pitch | Nathan Young | Owning | 25 | October 10th 04 04:41 AM |
Constant speed prop oil leak | DP | Piloting | 23 | April 21st 04 10:15 PM |
Why do constant speed power setting charts limit RPM? | Ben Jackson | Piloting | 6 | April 16th 04 03:41 AM |
Practicing SFLs with a constant speed prop - how? | Ed | Piloting | 22 | April 16th 04 02:42 AM |
Constant Speed Prop vs Variable Engine Timing | Jay | Home Built | 44 | March 3rd 04 10:08 PM |
