Hi,
i'm asking myself to make an Instrument Rating or not. There are some questions to IFR-Pilots : ... when flying under a flight plan (IFR) can i fly routes at my choice ? e.g. take-off under IMC, enroute 10 min under IFR (clouds), 30 min VFR on top, descending to my destination under IMC (through cloúds), landing at destination under VMC (below the lower layer of clouds) ... when reaching IMC after 30 min. VMC ("round trip under VFR") do i have to file a flight plan (IFR) or am i able to fly only by reference to the instruments through an e.g. 300 ft Layer of clouds and after that, when reaching "On Top" fly again under VFR ? Peter |
"Peter Bauer" wrote in message
om... Hi, i'm asking myself to make an Instrument Rating or not. There are some questions to IFR-Pilots : [scenarios about flying in VMC under VFR between IFR segments snipped] You can switch back and forth between IFR and VFR if you want but you may it inconvenient, since every time you want to go back to IFR, you need to obtain the necessary clearance from ATC (assuming not in Class G airspace...in controlled airspace, you must have an ATC clearance and an IFR flight plan in order to fly in IMC, even briefly). There is a way to file a mixed IFR/VFR flight plan, but I've never heard of that being used when you need IFR at both the departure and arrival ends of the flight. Typically, if you're flying under IFR, find yourself in VMC and want to take advantage of that to operate under the flexibility of VFR, you'd get a "VFR on top" clearance. That's an IFR clearance, and you would still be operating under IFR, but you usually would get the flexibility of choosing your routing and altitude as if you were VFR (and in fact would have to fly the +500' VFR cruising altitudes rather than the even thousands IFR cruising altitudes). For example, taking your first scenario, done this way, you'd take off in IMC, arrive at VMC above the clouds, get a "VFR on top" clearance, fly in VMC using VFR altitudes and procedures for 30 minutes, and then descend back to your destination through IMC for the landing, possibly flying a full instrument approach. Your flight plan would be for the entire flight, you'd be flying under IFR for the entire flight, but the time during which you were flying with a "VFR on top" clearance, you'd be able to get most of the advantage you'd get had you cancelled IFR and flown VFR for that period. Something to keep in mind that some new instrument pilots forget: "VFR on top" does not require that there be IMC below you. It can be used any time you can maintain VMC. If you're cruising along IFR, but there's not a cloud for 100 miles and ATC starts vectoring you around or slowing you down or gives you a hold, often you can use the "VFR on top" clearance to resolve whatever issue ATC had, and allow yourself to proceed directly to whereever you were headed. Basically, when IFR procedures become inconvenient and VMC prevails, "VFR on top" allows you to practically fly VFR without giving up your IFR clearance. Pete |
Peter Duniho wrote:
the "VFR on top" clearance to resolve whatever issue ATC had, and allow yourself to proceed directly to whereever you were headed. Is that likely to work? ATC may, after all, deny the "on top" clearance. - Andrew |
![]() You can switch back and forth between IFR and VFR if you want but you may it inconvenient, since every time you want to go back to IFR, you need to obtain the necessary clearance from ATC (assuming not in Class G airspace...in controlled airspace, you must have an ATC clearance and an IFR flight plan in order to fly in IMC, even briefly). There is a way to file a mixed IFR/VFR flight plan, but I've never heard of that being used when you need IFR at both the departure and arrival ends of the flight. But what ...when descending under VMC into Class G Airspace and then coming into IMC "wheather" (e.g. fog,..) then i can fly IFR without a clearance ??? If a second pilot does the same "plan" .... very dangerous, isn't it ? Nobody knows from each other flying in fog... Typically, if you're flying under IFR, find yourself in VMC and want to take advantage of that to operate under the flexibility of VFR, you'd get a "VFR on top" clearance. That's an IFR clearance, and you would still be operating under IFR, but you usually would get the flexibility of choosing your routing and altitude as if you were VFR (and in fact would have to fly the +500' VFR cruising altitudes rather than the even thousands IFR cruising altitudes). i can really fly VFR under an IFR-Flight Plan ?? But probably with the same "squawk" as under IFR ? ...and then after getting "tired" flying VFR ..changing back to the initial IFR Flight Plan ? (what is when too far away under VFR flying from the "filed" Plan ??? Does ATC give me then another "Plan", an "abbreviated" Flight Plan ? For example, taking your first scenario, done this way, you'd take off in IMC, arrive at VMC above the clouds, get a "VFR on top" clearance, fly in VMC using VFR altitudes and procedures for 30 minutes, and then descend back to your destination through IMC for the landing, possibly flying a full instrument approach. Your flight plan would be for the entire flight, you'd be flying under IFR for the entire flight, but the time during which you were flying with a "VFR on top" clearance, you'd be able to get most of the advantage you'd get had you cancelled IFR and flown VFR for that period. Something to keep in mind that some new instrument pilots forget: "VFR on top" does not require that there be IMC below you. It can be used any time you can maintain VMC. If you're cruising along IFR, but there's not a cloud for 100 miles and ATC starts vectoring you around or slowing you down or gives you a hold, often you can use the "VFR on top" clearance to resolve whatever issue ATC had, and allow yourself to proceed directly to whereever you were headed. Well, i haven't known about this......because i'm only an PP-ASEL without IFR-Privileges. But the described possibilitites makes it very interesting getting an IFR-Pilot ;-) Basically, when IFR procedures become inconvenient and VMC prevails, "VFR on top" allows you to practically fly VFR without giving up your IFR clearance. Pete Thanks to you...Pete Peter |
![]() If a second pilot does the same "plan" .... very dangerous, isn't it ? Nobody knows from each other flying in fog... Yes. That is the purpose of controlled airspace - to prevent such things by ensuring that everyone in there under IFR is being separated. Flying IFR in uncontrolled airspace is not all that prudent, and fortunately not necessary in most of the US. Most airports have controlled airspace surrounding them to the ground for the purpose of instrument approaches. Jose -- (for Email, make the obvious changes in my address) |
I fly IFR into Ontario, California IFR on my run and do it VFR on top as much as possible. It cuts down on our run time as we fly a more direct route, and since we are on a schedule it helps a lot. ATC may, after all, deny the "on top" clearance. They can, but unlikely. It frees up the controller to focus on other things. -John *You are nothing until you have flown a Douglas, Lockheed, Grumman or North American* |
om... .. when flying under a flight plan (IFR) can i fly routes at my choice ? e.g. take-off under IMC, enroute 10 min under IFR (clouds), 30 min VFR on top, descending to my destination under IMC (through cloúds), landing at destination under VMC (below the lower layer of clouds) .. when reaching IMC after 30 min. VMC ("round trip under VFR") do i have to file a flight plan (IFR) or am i able to fly only by reference to the instruments through an e.g. 300 ft Layer of clouds and after that, when reaching "On Top" fly again under VFR ? You do not say where you are flying, Peter. Others have answered on the assumption that you are flying in the US, I'll give you an answer for Germany. The airspace system in Germany is not very different to that in the US, but there are a couple of differences. Controlled airspace generally starts at 2500 ft agl rather than 1200 ft agl. Flying under IFR in class G is forbidden in Germany. Thus for an IFR flight, if your destination is not an IFR airport surrounded by controlled (or class F) airspace, you usually need to be able to cancel IFR by the minimum instrument altitude which is not below 2500 ft. This makes IFR flights to VFR airports fairly painful. To fly under IFR you need a clearance. Pop-up IFR clearances (if you find IMC on a VFR flight like your second scenario) are troublesome. I've had to dictate an entire flight plan (including the colour of the dinghy cover) to a FIS controller to get an IFR pop-up, despite having filed a VFR plan with almost exactly the same info. "VFR on top" clearances, as Pete described are not used in Germany (in fact they're not used outside the US). But you will find that practical IFR clearances tend to include long direct legs, so it's unusual to be in a situation where a VFR routing will save you a lot over an IFR one. So where are you based? Hope that helps Julian Scarfe |
"Andrew Gideon" wrote in message
online.com... Is that likely to work? ATC may, after all, deny the "on top" clearance. As Ditch says, ATC has the authority to deny the clearance, of course. But since it makes their life easier, I don't know why they would. I have never been denied a request for a "VFR on top" clearance. Granted, I fly VFR much more often than IFR, but I just can't see why ATC would ever deny a "VFR on top" clearance. Pete |
Routine Aviation Career | Guy Alcala | Military Aviation | 0 | September 26th 04 12:33 AM |
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore | Otis Willie | Military Aviation | 2 | February 22nd 04 03:33 AM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
Wm Buckley on John Kerry | Big John | Piloting | 22 | February 7th 04 02:19 AM |
Announcing THE book on airshow flying | Dudley Henriques | Piloting | 11 | January 9th 04 07:33 PM |
