Clearing a fouled plug
Old July 6th 04, 12:57 AM
Roger Long
Default Clearing a fouled plug
Should you clear a fouled plug on run up with the mag on "Both" or switched
to the side that is running rough? Since it's just heat, I can't think of
any reason why one way would be better than the other.
Roger Long
Old July 6th 04, 01:58 AM
steve
I'd keep both running....I don't see how shutting down mags that are
perfectly running makes for a better de-fouling. Plus, keeping them both
going will prevent anything from fouling those plugs as well.
"Roger Long" wrote in message
switched
Roger Long
Old July 6th 04, 02:12 AM
G.R. Patterson III
If a plug is fouled and you switch over to the side that's running rough, there won't
be much heat on the affected cylinder 'cause that plug won't be firing well if at
all. Run on both. The engine will shake less, too.
George Patterson
In Idaho, tossing a rattlesnake into a crowded room is felony assault.
In Tennessee, it's evangelism.
Old July 6th 04, 05:53 AM
Brad Z
Quack!
Don wrote in message ...
'Both'
Otherwise you are likely to fowl the plugs that are not firing.
On Mon, 05 Jul 2004 23:57:46 GMT, "Roger Long"
switched
of
Don
Pilot/Owner Signoff for spark plug maintenance? John Clonts Owning 3 September 14th 04 11:08 AM
Helicopter headset plug - help needed NewsGroups Home Built 4 September 8th 04 05:21 PM
wiring a mic plug S Green Owning 2 February 8th 04 11:28 PM
Plug in voltmeter Bob Owning 12 December 27th 03 01:00 PM
WTB: Turbine ignition exciter unit, single plug Juan E Jimenez Aviation Marketplace 0 August 25th 03 12:48 AM
