#41
I'll second the "fly pretty well" with a load of ice. I should not have
been there years ago.....but....... Another second...My two cents...I don't believe a 182 should have the TKS...might go when you shouldn't... John N3DR "Matt Whiting" wrote in message ... Andrew Gideon wrote: One of the members of my club has proposed that we add TKS de-ice to our two 182s. Apparently, such a system is to become available later this year. My reaction at first was negative. After all, in our near-NYC location, the utility of such a tool is limited to a few months a year. Surely we could spend money better (ie. on upgades that would be useful year round). His reply to this reasoning is that our aircraft utilization is much lower in the cold months than in the summer. If we can increase winter use, then we get better value from our investment. It's a good point. Of course, when I mentioned this to my wife, she asked how much of the lower use was due to the threat of ice, and how much was due to our lack of love for preflighting in subzero weather. Another good point grin. But it does have me wondering. The system would not be "known icing" compliant. So...what difference in utilization would it make? I'm curious what others - esp. that fly with de-ice - would reply. Without "known icing" certification, I don't think it buys you much at all from utilization perspective. It is insurance if you get caught in ice, but that is it. And if if DOES increase utilization it means that you have pilots flying in conditions they likely shouldn't be in anyway. And, I know from a hairy personal experience, a Skylane will carry a lot of ice and still fly pretty well. I'd invest the money and weight into something more useful. Matt |
#42
"Richard Kaplan" wrote in message
s.com... [...] Why is what I am doing unwise? To me, the difference is between "what could be" and "what is". In particular, icing is not present with such great frequency even when icing has been forecast, that it's simply impractical to cancel a flight solely because of such a forecast. I'm sure you're familiar with the story of the boy who cried wolf. On the other hand, once you've got a pilot report of icing, you've confirmed the icing forecast, and changed the statistical odds of running into a problem by a significant amount, since you've reduced the set of possibilities to the small subset of "forecast icing" that includes actual icing going on. In any case, more power to you if you feel that's a fine approach. I have even had the local Mooney salesman tell me that the TKS system, even if approved for known ice, should not be used to actually fly into reported icing conditions. His opinion made sense to me at the time, and it still makes sense. That is, TKS (and other light piston GA de-ice systems) is for getting you out of icing that you didn't expect, not for flying into icing you know is there. You disagree, which is your right. We will simply have to "agree to disagree". Pete |
#43
"Peter Duniho" wrote in message ... On the other hand, once you've got a pilot report of icing, you've confirmed the icing forecast, and changed the statistical odds of running into a problem by a significant amount, since you've reduced the set of Actually Peter, pilot reports of icing are unreliable because ice can be 100 feet thick or 3,000 feet thick and can be 1 mile in length or 100 miles in length. The fact that someone did or did not get ice 10 minutes ago 10 miles from where you plan to fly is not a reliable way to make a decision. Your plane is not certified for flight into known icing conditions - that means not into reported icing and it also means not into forecast icing conditions. Yes, you are right that makes a non-known-ice impractical for cross-country winter flight; rationalizing this away does not change the facts. Lots of people have died due to the rationalization under which you fly. In any case, more power to you if you feel that's a fine approach. I have even had the local Mooney salesman tell me that the TKS system, even if approved for known ice, should not be used to actually fly into reported icing conditions. His opinion made sense to me at the time, and it still Can you put me in touch with him please so I can understand his reasoning? I say again --- people have died many times doing what you are doing. Yet there is not a single accident -- fatal or otherwise -- I am aware of from someone doing what I do. Please either correct my facts or explain to me why this is not valid comparison of our relative risks. -------------------- Richard Kaplan, CFII www.flyimc.com |
#44
"Peter Duniho" wrote in message ... even had the local Mooney salesman tell me that the TKS system, even if approved for known ice, should not be used to actually fly into reported icing conditions. His opinion made sense to me at the time, and it still Perhaps we are confusing the distinction between flying THROUGH icing conditions (i.e. taking off and climbing through icing to get on top at 15,000 feet, which I do regularly) vs. flying IN icing conditions (i.e. staying in an icing layer, which I do not do)? -------------------- Richard Kaplan, CFII www.flyimc.com |
#45
Peter Duniho wrote:
I have even had the local Mooney salesman tell me that the TKS system, even if approved for known ice, should not be used to actually fly into reported icing conditions. Are Mooneys able to be equipped with TKS at the factory? If not, I would be suspicious of this salesperson's opinion, given that Cirrus does have this option. -- Peter ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
#46
"Peter R." wrote in message ... Peter Duniho wrote: Are Mooneys able to be equipped with TKS at the factory? If not, I would be suspicious of this salesperson's opinion, given that Cirrus does have this option. Yes, factory TKS known-ice has been offered on Mooneys since the mid-80s. Cirrus, that is an interesting situation. Cirrus has a non-known-ice TKS system with minimal endurance (about 1 hour), no airframe icing testing, and no windshield deice. Clearly that is a system for emergencies only. The Cirrus salesman I spoke with at Oshkosh last year told me it was "certified for inadvertent icing" which I stated does not exist... all it means is that the equipment was approved on a "does no harm" basis, i.e. you could get a CD player "certified" for the same purpose. That is one reason among others why I am skeptical of whatever information a Mooney salesman may have provided; airplane salesmen are not necessarily an authority on technical aspects of their airplanes. This is particularly concerning given that Cirrus is promoted as such as "safe" airplane for new cross-country pilots -- never mind that weather accidents are a key issue in aviation safety, yet there is apparently no plan to make the Cirrus known-ice approved and until very recently Cirrus airplanes were not sold with weather datalink -- so much for an emphasis on safety. -------------------- Richard Kaplan, CFII www.flyimc.com |
#47
Richard Kaplan wrote:
Cirrus, that is an interesting situation. Cirrus has a non-known-ice TKS system with minimal endurance (about 1 hour), no airframe icing testing, and no windshield deice. Clearly that is a system for emergencies only. FWIW, the system that is supposed to become available later this year for 182s - the system we're considering, which is why I started this thread - will last for about three hours and does have windscreen protection. How *well* it does all this, of course, I cannot say. - Andrew |
#48
"Andrew Gideon" wrote in message online.com... FWIW, the system that is supposed to become available later this year for 182s - the system we're considering, which is why I started this thread - will last for about three hours and does have windscreen protection. That is a much tougher call with the C182 than the Cirrus. First off, if the C182 system is not known-ice then it is not legal to use in either forecast or reported icing. That said, history shows that in reality lots of C182 pilots do fly in ice, that the C182 is generally a docile enough and overpowered enough airplane that it handles ice well, but that occasionally pilots push this too far and get into icing accidents in a C182 which would almost for sure be less likely with TKS. In other words, legally the C182 is in the same class as the Cirrus but years of informal "testing" by C182 pilots has shown that the airframe does not have any nasty handling characteristics in ice, nor does it seem particularly prone to induction or fuel vent icing. So TKS in a C182 will almost for sure help to make flights which are not legal but which nonetheless have been happening all the time in C182s for many years. I guess it's sort of like asking your doctor what cigarette is safest -- he should tell you to not smoke at all, yet if you are going to smoke anyway then you ought to minimize the risk. And legalities aside I have no doubt that TKS on a C182 with a 3-hour endurance would improve the risk considerably. By the way, I presume the TKS on the C182 will be on the prop as well as the airframe. I rarely if ever use the windshield deice on my plane since enough fluid sprays off the prop to clear the windshield in most cases; that's a good thing because the windshield spraybar is only on the pilot side so it doesn't help me when I am instructing. -------------------- Richard Kaplan, CFII www.flyimc.com |
#49
First off, if the C182 system is not known-ice then it is not legal to use in either forecast or reported icing. Hmm...based upon what are you making this statement? Note that I'm not speaking of "wise" or "smart", but merely "legal". I did some checking, and the only FAR I could find in part 91 that discussed this was 500-something and applicable only to turbines and such. I didn't find anything that spoke specifically of flight of an "unprotected" piston aircraft into icing. That said, history shows that in reality lots of C182 pilots do fly in ice, that the C182 is generally a docile enough and overpowered enough airplane that it handles ice well, but that occasionally pilots push this too far and get into icing accidents in a C182 which would almost for sure be less likely with TKS. What do you mean by "overpowered"? I hope that this isn't related to the myth "a 182 can carry what it can hold", as this just isn't true. Shove four real adults in, and you cannot carry full fuel. [Of course, "full fuel" is 88 gallons usable, so ...] In other words, legally the C182 is in the same class as the Cirrus but years of informal "testing" by C182 pilots has shown that the airframe does not have any nasty handling characteristics in ice, nor does it seem particularly prone to induction or fuel vent icing. Our 182Q is quite prone to carb icing, if that's what you mean by induction. Apparently, this is because of the location of the carburator, which is because of the space consumed by the Continental as opposed to the Lycoming on other 182 versions (at least, this is what I've been told). So TKS in a C182 will almost for sure help to make flights which are not legal but which nonetheless have been happening all the time in C182s for many years. I guess it's sort of like asking your doctor what cigarette is safest Laugh! [...] By the way, I presume the TKS on the C182 will be on the prop as well as the airframe. I rarely if ever use the windshield deice on my plane since enough fluid sprays off the prop to clear the windshield in most cases; that's a good thing because the windshield spraybar is only on the pilot side so it doesn't help me when I am instructing. I don't have my notes with me, but I believe it weeps onto the prop, pilot-side windscreen, and leading edges of wings and elevators. - Andrew |
#50
s.com... [...] That is one reason among others why I am skeptical of whatever information a Mooney salesman may have provided; airplane salesmen are not necessarily an authority on technical aspects of their airplanes. I didn't mention the "salesman" characteristic in way of certifying his knowledge; it was simply a descriptive "one pilot I know" to provide context. He's a pilot who (presumably) has flown TKS-equipped airplanes, and since he's based around here, I have to assume he did so in icing conditions (forecast at least, probably actual). Anyway, I'm not going to "out" a disinterested third party in a public newsgroup. I'll send what little contact information I have to you in email. You can feel free to contact him; just don't be surprised if he sells you a Mooney (or worse, an Extra 500). ![]() Pete |
| Garmin 430 wierd issues | Jon Kraus | Owning | 6 | November 12th 04 03:07 AM |
| Back issues of Naval Aviation News | Steve Tobey | Naval Aviation | 0 | April 23rd 04 10:50 PM |
| Article: GPS Vehicle Tracking System Issues for the Buyer | Johann Blake | Military Aviation | 0 | January 16th 04 12:26 PM |
| How much could I get for these back issues? | Aaron Smith | Home Built | 8 | December 15th 03 01:07 PM |
| ISO back issues Combat Aircraft magazine | mark e digby | Military Aviation | 0 | August 12th 03 06:39 PM |
