Transient alternator problem
Old July 7th 04, 12:05 AM
Jeremy Lew
Default Transient alternator problem
Was flying IFR in the clear on top of an overcast layer today. I noticed at
some point that the ammeter was indicating zero, and not moving. The Alt
warning light was not illuminated, except when I pressed the test button. I
started to shut down non-essential electriconics in case this was for real.
After a minute or two, the ammeter needle resumed normal indications, and
stayed that way for the rest of the flight. The Alt warning light was
properly illumated during low-RPM operations on the ground, as well as
during the engine runup split switch check.
The warning light/ammeter needle discrepancy suggests to me that problem was
in the ammeter, and that the alternator was functioning normally the whole
time. Anyone have any theories as to what would cause indications like
this? Is external RF interference possible?
Thanks,
Jeremy
Old July 7th 04, 03:08 AM
Nathan Young
On Tue, 6 Jul 2004 19:05:22 -0400, "Jeremy Lew"
What kind of plane & what year?
Old July 7th 04, 04:01 AM
John Clonts
"Jeremy Lew" wrote in message
at
I
real.
was
(x-posted to rec.aviation.owning)
What a coincidence, we've had the same sort of intermittent problem with our
charging system on the last few flights! Of course, when we've had our
voltmeter there to diagnose it, it seems to work perfectly
Will let you know what we find-- please do likewise!
(Ours is a 1978 Cessna 210M - IO520).
Cheers,
John Clonts
Temple, Texas
N7NZ
Old July 7th 04, 01:38 PM
Jeremy Lew
Ours is a '78 Warrior (PA-28-151/161).
According to our maintenance officer, the ALT warning light and zero ammeter
reading during low rpm (~1000) ground operations is actually not normal. It
did make me pause for a minute, but then I figured I was being paranoid
since I don't usually look at either of those indicators until the 2000 rpm
runup, when both of those indicators were normal.
We have a new alternator on order, I'll let you know what our outcome is
too.
Jeremy
"John Clonts" wrote in message
noticed
at
Alt
button.
I
real.
and
was
whole
our
Cheers,
John Clonts
Temple, Texas
N7NZ
Old July 7th 04, 01:41 PM
Dave Butler
FWIW, on the '75 Archer I used to own, the ammeter needle would sometimes stick
against the faceplate and not move. The mechanic bent the needle a little bit so
it wouldn't drag against the faceplate. The bent needle looked like crap, but it
worked after that.
Dave
too.
Jeremy
noticed
at
Alt
button.
I
real.
and
was
whole
our
Cheers,
John Clonts
Temple, Texas
N7NZ
Dave Butler, software engineer 919-392-4367
Old July 7th 04, 05:19 PM
Jeremy Lew
My needle moved to zero during cruise flight, so I don't think it could be
the case for me.
Jeremy
"Dave Butler" wrote in message
stick
bit so
but it
worked after that.
Dave
ammeter
It
rpm
too.
Jeremy
noticed
at
Alt
button.
I
real.
and
problem
was
whole
our
Cheers,
John Clonts
Temple, Texas
N7NZ
Old July 7th 04, 06:40 PM
Jim Weir
Had the same thing on the 182 about ten years ago. Drove me nuts for about a
week until I noticed that the throttle control was adjacent to the diode plate
on the rear of the alternator. Spreading the two apart, you could clearly see
where the throttle cable insulation was chafed through and touching the diode
plate, killing the alternator. Of course, on the ground with the engine torque
not moving the alternator just that few thousandths of an inch that made
contact, it wouldn't do it for love nor money except when the airplane was
actually flying.
Run your hand all the way around the rear diode plate on the alternator and see
if there is a cable nearby.
http://www.rst-engr.com
Old July 7th 04, 09:41 PM
Robert M. Gary
"Jeremy Lew" wrote in message ...
I've had the same problem in my Mooney. Sometimes the buss voltage
drops down to just 13v sometimes to 12v but then comes back. It
appears the problem is an old master switch. The contacts on the
switch wear out and if the alternator does not get full battery
voltage from the field (going through the master switch) it will put
out less voltage. The contacts are a bit intermitant sometimes as they
get corrosion.
-Robert
Old July 8th 04, 01:46 AM
Martin Kosina
Hmmm - I thought the ammeter *should* indicate zero when the battery
is fully charged and the electrical load is not changing ? What is the
"normal" indication you are refering to ?
Old July 8th 04, 02:34 AM
Jeremy Lew
I've never seen our ammeter reading zero before. Doesn't any load on the
battery mean constant discharge and therefore constant charge for the
alternator? Normally, the needle is so sensitive that you can see it
jumping in sync with the anti-collision strobe.
"Martin Kosina" wrote in message
om...
noticed at
Alt
button. I
real.
and
Transient alternator problem John Clonts Owning 6 July 11th 04 06:01 PM
Transient visit to the Pacific Northwest sprack Piloting 5 May 5th 04 05:57 AM
