Weight and Balance
Old June 23rd 04, 05:13 AM
Dale Larsen
Default Weight and Balance
The local FSDO has this form they want submitted before scheduling an
inspection. It asks for (1) "Net empty C.G. range" and (2) "Loaded C.G.
limits".
Now I know that my C.G. has to fall within 15-28% of chord, and I can easily
figure that out. It works out to 77.95 to 84.84 inches aft of datum. This
is what I would think is the "Loaded C.G. limits". My empty C.G. is 78.48
which is within the limits. But what the hell is: "Net empty C.G. range"?
-Confuzed
Old June 23rd 04, 04:43 PM
Stealth Pilot
On Wed, 23 Jun 2004 03:13:20 GMT, "Dale Larsen"
limits".
-Confuzed
I think you've got it right.
have you got a removable fuel tank?
the auster has a number of empty weights.
belly tank on/off
metal/wood prop (involves additional tail ballast for the metal prop)
exhaust manifold and rear facing pipe. (involves additional tail
ballast as well)
may explain it.
Stealth Pilot
Australia
Old June 23rd 04, 06:11 PM
Dale Larsen
That explains it! It most likely does not apply to my aircraft, since I
only have one configuration and one empty weight.
Thanks for your help.
Dale
"Stealth Pilot" wrote in message
limits".
easily
This
78.48
range"?
-Confuzed
belly tank on/off
ballast as well)
may explain it.
Stealth Pilot
Australia
Why 4130 tube? Leon McAtee Home Built 31 March 28th 04 04:04 PM
Pitts S-1 weight and balance wallyairplanefan Aerobatics 2 March 6th 04 05:09 AM
RV-7a baggage area David Smith Home Built 32 December 15th 03 05:08 AM
Rebuilding my KR-2 Forrest Home Built 10 December 9th 03 05:09 AM
