I was level at 1500' MSL and ATC announced a Gulfstream bizjet crossing from my
right to left, 3000' MSL less than a mile lateral distance. I had my instrument student do a 360 for wake turbulence separation and dissipation. ATC questioned my actions and told me the 360 wasn't necessary. BTW: I was in Class Echo airspace in southern Maine. I havent been instructing all that long but this did seem to me to be a classic wake turb encounter in the making. I am interested in hearing from other pilots and CFII's on this subject. Was I over cautious ? Or prudent..... Hank |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 HankPilot2002 wrote: I was level at 1500' MSL and ATC announced a Gulfstream bizjet crossing from my right to left, 3000' MSL less than a mile lateral distance. I had my instrument student do a 360 for wake turbulence separation and dissipation. ATC questioned my actions and told me the 360 wasn't necessary. BTW: I was in Class Echo airspace in southern Maine. I havent been instructing all that long but this did seem to me to be a classic wake turb encounter in the making. I am interested in hearing from other pilots and CFII's on this subject. Was I over cautious ? Or prudent..... Hank I'll take a crack at it... Let's say the Gulfstream was IFR, and was level. Judging by your level altitude, you were VFR. Either way, you still have the 1000ft vertical separation, regardless of lateral separation, so doing a 360 wouldn't have mattered for separation. As long as you had him in sight, and being (assumed) VFR, you could maintain visual separation. In that instance, the 360 wouldn't have been needed. Let's now say that the Gulfstream was climbing. He was going to be crossing your path above you, which may mean that you would catch the underside of his wake before the tail end of it after his climb. In that instance, you could have done a 360 to avoid the wake altogether, then continue. But once again, It wouldn't have been needed, as you had vertical separation of over 1000ft. Overcautious? yes. But better to be over than under. You would have been fine, but as CFII, you would have been in the best position to make the call. Judging that this post happened after your flight, you walked away from the flight. Which means you lived. ![]() your call was a good one. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.2.4 (GNU/Linux) iD8DBQFA8ztMyBkZmuMZ8L8RAtNYAKCWM7okfijLEHOwKLoSky QwZ0M8SACdEowi YtNXYif1EpxMEY8eXAsmnNI= =+OlY -----END PGP SIGNATURE----- |
![]() I was level at 1500' MSL and ATC announced a Gulfstream bizjet crossing from my right to left, 3000' MSL less than a mile lateral distance. I had my instrument student do a 360 for wake turbulence separation and dissipation. ATC questioned my actions and told me the 360 wasn't necessary. BTW: I was in Class Echo airspace in southern Maine. I havent been instructing all that long but this did seem to me to be a classic wake turb encounter in the making. I am interested in hearing from other pilots and CFII's on this subject. Was I over cautious ? Or prudent..... The "classic" wake turbulence encounter is flying up the funnel and being turned over. To do that, your courses would need to be fairly well aligned. Your encounter sounds like it was more at right angles. You'd get a bump bump and be through it. By doing a 360, you allowed your course to parallel the other aircraft's course, and if you didn't know where he was, you risked the classic encounter as you passed 90 degrees or 270 degrees of your turn. If it was indeed crossing right to left, I'd have just proceeded on course. Jose -- (for Email, make the obvious changes in my address) |
I'd have to research the study.. but most wake turbulence only drops about
500ft.. if I remember correctly.. if you were 500ft it would not be an issue.. also.. wake turbulence is the worst if the heavier aircraft (bizjet) is configured for landing, flaps and gear etc.. if he was still gear up.. and in level flight... the bumps would not be so bad even if you had 500ft. It's the wing tip vortices that are the worst, and yes you may get some vortices from the flap end at mid span. We've rendezvoused for refueling, 1000ft below a heavy tanker (KC-10/DC10) and moved into refueling position and not feel his wake until we are practically on the boom.. at near cruise speeds BT "HankPilot2002" wrote in message ... I was level at 1500' MSL and ATC announced a Gulfstream bizjet crossing from my right to left, 3000' MSL less than a mile lateral distance. I had my instrument student do a 360 for wake turbulence separation and dissipation. ATC questioned my actions and told me the 360 wasn't necessary. BTW: I was in Class Echo airspace in southern Maine. I havent been instructing all that long but this did seem to me to be a classic wake turb encounter in the making. I am interested in hearing from other pilots and CFII's on this subject. Was I over cautious ? Or prudent..... Hank |
right to left, 3000' MSL less than a mile lateral distance. IIRC, the wake descends only about 500 feet, so you would have been well below it. Probably wouldn't have descended even that far if you were less than a mile away. If the Gulfstream was cruising, clean, the turbulence would not have been serious anyway. Years ago, I spotted a wide-body crossing right to left, four or five miles in front of me, and just barely above my altitude. A couple of minutes later, I felt one quick bump. vince norris I had my instrument student do a 360 for wake turbulence separation and dissipation. ATC questioned my actions and told me the 360 wasn't necessary. BTW: I was in Class Echo airspace in southern Maine. I havent been instructing all that long but this did seem to me to be a classic wake turb encounter in the making. I am interested in hearing from other pilots and CFII's on this subject. Was I over cautious ? Or prudent..... Hank |
![]() "BTIZ" wrote in message news:2fHIc.23345$r3.6120@okepread03... also.. wake turbulence is the worst if the heavier aircraft (bizjet) is configured for landing, flaps and gear etc.. if he was still gear up.. and in level flight... the bumps would not be so bad even if you had 500ft. A quote from a popular primary text: "The greatest vortex strength occurs under CLEAN configuration, high weight, and slow speed." (emphasis mine) (... and high air density) Their contention appears to be that flaps and gear help break up the vortex pattern. The clean configuration at slow speeds results in the highest AOA, supposedly the primary culprit. |
... I was level at 1500' MSL and ATC announced a Gulfstream bizjet crossing from my right to left, 3000' MSL less than a mile lateral distance. I had my instrument student do a 360 for wake turbulence separation and dissipation. ATC questioned my actions and told me the 360 wasn't necessary. BTW: I was in Class Echo airspace in southern Maine. I havent been instructing all that long but this did seem to me to be a classic wake turb encounter in the making. I am interested in hearing from other pilots and CFII's on this subject. Was I over cautious ? Or prudent..... You're PIC. If you feel it necessary to do a 360, ATC has no reason to be critical. They don't have all the facts -- perhaps you had reason to doubt your altimeter or mode 'C' for some reason, or needed to impress upon your student that it's OK to deviate if you feel uneasy in a situation. Unless, of course, you were flying IFR in which case you should probably have asked first. That said, you were being over cautious to this threat. Wake turbulence levels off about 800' below an aircraft track, so you still had 700' of buffer. |
"BTIZ" wrote:
also.. wake turbulence is the worst if the heavier aircraft (bizjet) is configured for landing, flaps and gear etc.. According to the latest edition of the Aeronautical Information Manual (effective 19 February 2004), paragraph 7-3-3: "The greatest vortex strength occurs when the generating aircraft is HEAVY, CLEAN, and SLOW." [emphasis present in original document] A clean aircraft generates stronger wake vortices than does one configured for landing. |
Ace Pilot wrote:
"BTIZ" wrote: also.. wake turbulence is the worst if the heavier aircraft (bizjet) is configured for landing, flaps and gear etc.. According to the latest edition of the Aeronautical Information Manual (effective 19 February 2004), paragraph 7-3-3: "The greatest vortex strength occurs when the generating aircraft is HEAVY, CLEAN, and SLOW." [emphasis present in original document] A clean aircraft generates stronger wake vortices than does one configured for landing. Not necessarily. When it is landing it will be SLOW, which is much more important than the minimal effect of how it happens to be configured. CV |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
caution - wake turbulence | John Harlow | Piloting | 1 | June 4th 04 04:40 PM |
My First Time In Severe Turbulence (Long) | David B. Cole | Instrument Flight Rules | 6 | March 10th 04 10:21 PM |
Wake turbulence avoidance and ATC | Peter R. | Piloting | 24 | December 20th 03 11:40 AM |
How much turbulence is too much? | Marty Ross | Instrument Flight Rules | 8 | August 21st 03 05:30 PM |
