![]() Bill Zaleski wrote: At a towered airport you turn whatever direction you want, unless otherwise instructed. Agreed, but you may not cross an extension of the departure runway centerline till outside the "D" or with clearance. That's one of the dumbest things I have ever heard. I'm supposed to fly 4 or 5 miles until I leave the class D before I can cross an extended centerline of the departure rwy? Bull****. If the tower controller doesn't give me a damn good reason not to turn then I'll turn to whatever is convenient for me. This happens a lot here, for some reason. It happens alot becaue it's ridiculous to assume it wouldn't. The tower has a fit, Where is here, I'd like to come thru there one day. |
"Bill Zaleski" wrote in message
... Agreed, but you may not cross an extension of the departure runway centerline till outside the "D" or with clearance. This happens a lot here, for some reason. The tower has a fit, and rightfully so. Hmm, don't remember reading that in the AIM. |
"Newps" wrote in message
... No, the left turn preference does not apply to towered airports. How does that jibe with 91.129a? |
![]() Gary Drescher wrote: "Newps" wrote in message ... No, the left turn preference does not apply to towered airports. How does that jibe with 91.129a? How does it not jibe? |
Seems to me that "Maintain runway heading until advised" would fit the bill
in this situation. "Bill Zaleski" wrote in message ... On Thu, 15 Jul 2004 19:21:17 -0600, Newps wrote: Bob Chilcoat wrote: I took of from Reading, PA this morning from RW 31 with an on-course heading of 105. As I was cleared for takeoff, I was told "Cleared for takeoff, proceed on course". In the past, they've also added "Right turn approved". This time they didn't. I was concerned that I hadn't been cleared for a right turn, and a right turn would have gotten me on course sooner. I then said "Request right turn to on course" but the controller seemed a bit irritated and just added "On course approved". Did I have permission for a right turn in the pattern or not? At a towered airport you turn whatever direction you want, unless otherwise instructed. Agreed, but you may not cross an extension of the departure runway centerline till outside the "D" or with clearance. This happens a lot here, for some reason. The tower has a fit, and rightfully so. |
... Gary Drescher wrote: "Newps" wrote in message ... No, the left turn preference does not apply to towered airports. How does that jibe with 91.129a? How does it not jibe? As I mentioned, 91.129a says that pilots at Class D airports have to comply with the untowered-airport requirements set forth in 91.126 and 91.127 (except when otherwise authorized by ATC). --Gary |
On Thu, 15 Jul 2004 19:44:28 -0400, "Bob Chilcoat"
wrote: I took of from Reading, PA this morning from RW 31 with an on-course heading of 105. As I was cleared for takeoff, I was told "Cleared for takeoff, proceed on course". In the past, they've also added "Right turn approved". This time they didn't. I was concerned that I hadn't been cleared for a right turn, and a right turn would have gotten me on course sooner. I then said "Request right turn to on course" but the controller seemed a bit irritated and just added "On course approved". Did I have permission for a right turn in the pattern or not? You were given free reign to get on course any way you saw fit. He must've been slow and didn't need to send you in any particular direction. z |
![]() "Newps" wrote in message ... Bob Chilcoat wrote: I took of from Reading, PA this morning from RW 31 with an on-course heading of 105. As I was cleared for takeoff, I was told "Cleared for takeoff, proceed on course". In the past, they've also added "Right turn approved". This time they didn't. I was concerned that I hadn't been cleared for a right turn, and a right turn would have gotten me on course sooner. I then said "Request right turn to on course" but the controller seemed a bit irritated and just added "On course approved". Did I have permission for a right turn in the pattern or not? At a towered airport you turn whatever direction you want, unless otherwise instructed. After clearing first, with something like "request southeast departure"? |
On Thu, 15 Jul 2004 20:36:09 -0600, Newps wrote:
Agreed, but you may not cross an extension of the departure runway centerline till outside the "D" or with clearance. That's one of the dumbest things I have ever heard. I'm supposed to fly 4 or 5 miles until I leave the class D before I can cross an extended centerline of the departure rwy? Bull****. If the tower controller doesn't give me a damn good reason not to turn then I'll turn to whatever is convenient for me. Just to play devil's advocate, why would you need to cross the extended centerline? You took off, you turned in the direction that you intended to go which would either be right or left of the centerline. Unless you were completely screwed up (or were declaring an emergency and it wouldn't matter) you wouldn't need to reverse the turn and cross the centerline again. Doing so would confuse the controller, and any traffic taking off behind you which was expecting you to keep going in generally the direction you were going, right? Wouldn't anything else be a transit of the Class D which would need approval anyway? |
![]() "Bob Chilcoat" wrote in message ... I took of from Reading, PA this morning from RW 31 with an on-course heading of 105. As I was cleared for takeoff, I was told "Cleared for takeoff, proceed on course". In the past, they've also added "Right turn approved". This time they didn't. I was concerned that I hadn't been cleared for a right turn, and a right turn would have gotten me on course sooner. I then said "Request right turn to on course" but the controller seemed a bit irritated and just added "On course approved". Did I have permission for a right turn in the pattern or not? Why would you need specific permission for a right turn? "Proceed on course" means a turn on course in the shortest direction. In your case, a right turn is about 155 degrees while a left turn is about 205 degrees, so you should turn right. |
Procedure turn in Strong X-wind | smackey | Instrument Flight Rules | 26 | November 30th 04 10:05 PM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
