#71
![]() "Michael" wrote in message om... new that progress has ground to a halt. In fact, I would have to say that the biggest factor in our high accident rate is the FAA. If we ever get airplanes that are as up to date as a 1995 Honda Civic, the situation will improve. Homebuilts do not have a better safety record. If you think a safer plane can be developed without FAA regulation, why don't you buy or build an experimental airplane and install the appropriate safety equipment so it is safer than your Twin Comanche? -------------------- Richard Kaplan www.flyimc.com |
#72
"Richard Kaplan" wrote
What piston engine design would be more reliable? (Economics make turbine engine comparisons unfair, even if turbines are more reliable -- and I am not certain that they are.) First off, turbine engines are not out of the questions at all. The reason they are so incredibly expensive has a lot to do with the FAA and milspecs. Second, turbine engines are inherently more reliable - there are far fewer moving parts, and no reversals of direction. In addition, they separate the combustion stages (suck, squeeze, bang, blow) in space rather than in time - and that means only a relatively small part of the engine has to be tough enough to accomodate the most difficult portion of the cycle. In other words, pound for pound the turbine will always be more reliable. Second, we've learned a lot about piston engine reliability in the past half century. Little of that has made it into aircraft engine designs. For example, separate cylinders are disasters. There's not sufficient mechanical stability, so everything moves too much. Note that the two modern aviation piston engines - the Thielert and Orenda - have abandoned that nonsense. That's just one example. There are countless others in the ignition, fuel, and other systems. I have experienced a lot more engine problems driving cars than flying airplanes for sure. Driving cars made in the last 20 years? I find that amazing. Experimental airplanes do not seem to have any lower incidence of engine failures anecdotally, nor do I recall reading any data to suggest there exists a more reliable experimental piston engine design. Experimentals are amateur-designed. The engine installations are amateur-designed too. The very fact that after the first 50 hours are flown off the accident rate appears to even out with the certified airplanes should suggest to you what a disaster the FAA-mandated professional engineering is. Amateurs can do almost as well working in their garages. Michael |
#73
![]() Michael wrote: Yes it would. The very fact that the manufacturers COULD do it if they chose, and choose not to, indicates that they don't want the facts known. What makes you think the manufacturers could do that? Many, if not most engine repairs and overhauls are not performed by the manufacturer, so they have no little data. You're expecting a manufacturer to spend hundreds of thousands of dollars to research a report which provides no benefit to the manufacturer. The fact that they "choose not to" merely indicates that they don't want to waste their money. George Patterson In Idaho, tossing a rattlesnake into a crowded room is felony assault. In Tennessee, it's evangelism. |
#74
Michael wrote:
I would argue that accuracy is not only important but essential, and an inacurate report is worse than useless - it is actively dangerous. I would further argue that distorting the facts of an accident to advance an agenda is never justified. However, I know it happens - and therefore I distrust the reports. Given my experience and that of others, I consider the distrust justified. Fair enough on all counts. You'd call the talk given by that guy "encouraging dangerous behavior"? I'd agree that that would not be a "safety seminar". Well, isn't flying a light plane on a long overwater leg dangerous behavior? Or are you suggesting it's safe? See the problem here? I see a linguistic trap. Nothing is safe but death (and I'm not even sure of that {8^). The question is whether the decrease in safety of a given act is balanced by whatever benefit is accrued. Put another way, is it (whatever "it" is) "safe enough". I know that you know this given what I've read from you. But perhaps making this more explicit would help explain my own perspective on the matter of "safety" and the question "is it safe". [...] Then by that definition, any skill/knowledge training is safety training. Yes. Failing an example which disproves this, that is my opinion. - Andrew |
#75
"G.R. Patterson III" wrote
You're expecting a manufacturer to spend hundreds of thousands of dollars to research a report which provides no benefit to the manufacturer. A report that showed that the engine was extremely reliable when maintained and overhauled in accordance with the manufacturer's recommendations (that's all SB's/TBO's are to Part 91 operators) would have great benefit to the manufacturer. Of course I don't believe that's what the report will show. Michael |
#76
Andrew Gideon wrote
Well, isn't flying a light plane on a long overwater leg dangerous behavior? Or are you suggesting it's safe? See the problem here? I see a linguistic trap. Nothing is safe but death (and I'm not even sure of that {8^). Right. That's why I don't believe that there is any such thing as a safety seminar. The only really valid safety advice it could give is to hide under the bed. It would be different if we HAD to fly. Professional pilots, who MUST fly, can speak of safety and safety seminars. For us, they basically have no meaning. The question is whether the decrease in safety of a given act is balanced by whatever benefit is accrued. Put another way, is it (whatever "it" is) "safe enough". Right again. But if what you're doing is primarily recreational, which is true of most flying most of us do, safe enough really means that the fun is worth the risk. I know that you know this given what I've read from you. But perhaps making this more explicit would help explain my own perspective on the matter of "safety" and the question "is it safe". And the point I'm trying to get across is that there is no such thing as safe. When you're flying for fun, you're taking unnecessary risks. I don't have a problem with that, obviously, but I think you should be honest about it. Then by that definition, any skill/knowledge training is safety training. Yes. Failing an example which disproves this, that is my opinion. There won't be an example to disprove it. There can't be. Whatever kind of flying you do, you're going to be safer if you get training than if you don't. It's not a crap shoot, after all. But the reality is that some kinds of flying present more risk than others. Michael |
#77
What are "separate cylinders" and what's the alternative? (unless you mean the wankel) Jose -- (for Email, make the obvious changes in my address) |
#78
![]() "Michael" wrote in message om... First off, turbine engines are not out of the questions at all. The reason they are so incredibly expensive has a lot to do with the FAA and milspecs. Second, turbine engines are inherently more reliable - So why hasn't someone developed an inexpensive, reliable turbine engine for experiental airplanes? sufficient mechanical stability, so everything moves too much. Note that the two modern aviation piston engines - the Thielert and Orenda - have abandoned that nonsense. What planes are these used in? Do you have any references about these? Driving cars made in the last 20 years? I find that amazing. Well as one example I experienced a sudden catastrophic engine failure this year in my 1999 Toyota minivan. An engine cooling fan circuit malfunctioned and the engine overheated while driving in a snowstorm. I pulled over right away but nonetheless the engine block had melted and I needed a new block and new cylinders... $8000 in warranty work repairing the engine due to failure of a $125 part. Experimentals are amateur-designed. The engine installations are amateur-designed too. The very fact that after the first 50 hours are flown off the accident rate appears to even out with the certified airplanes should suggest to you what a disaster the FAA-mandated professional engineering is. Amateurs can do almost as well working in their garages. Well can anyone do BETTER than FAA certified airplanes? Who in your mind can produce an airplane with a more reliable engine than an FAA certified engine? -------------------- Richard Kaplan www.flyimc.com |
#79
![]() "Richard Kaplan" wrote: I have experienced a lot more engine problems driving cars than flying airplanes for sure. Another Jaguar driver! -- Dan C172RG at BFM |
#80
![]() Teacherjh wrote: For example, separate cylinders are disasters. What are "separate cylinders" and what's the alternative? (unless you mean the wankel) Each cylinder on a typical Lycoming or Continental engine can be removed independently. All of the cylinders in a typical automobile engine are cast in a single unit (known as the block). This is also true of many water-cooled aircraft engines and many motorcycle engines. George Patterson In Idaho, tossing a rattlesnake into a crowded room is felony assault. In Tennessee, it's evangelism. |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
