Talking with some of the sea plane operations, it seems pretty common
to take floats on and off. However, the rigging and all for the floats (rudders, etc) seems complicated. Is it actually that easy to put floats on and off? If I bought a Champ could I just pick up a used pair of EDO float and put them on every once in awhile (I know insurance is another issue..)? Most of the floats for 2 place planes look very similar, are they generic to type? -robert |
There is some specialized equipment needed. A hoist of some kind. I go on
and off floats every other year. A Cessna 185 takes three men four hours to convert to floats. For many installations an STC is not necessary. For instance, EDO 2960's are certified on a Cessna 185 and do not require an STC. However, a set of Aerocets require an STC. Karl "C Kingsbury" wrote in message om... (Robert M. Gary) wrote in message . com... Talking with some of the sea plane operations, it seems pretty common to take floats on and off. However, the rigging and all for the floats (rudders, etc) seems complicated. Is it actually that easy to put floats on and off? It's more complicated than changing a tire, but not unreasonable to do at the beginning and end of the season, especially if the shop does it often. If I bought a Champ could I just pick up a used pair of EDO float and put them on every once in awhile (I know insurance is another issue..)? Most of the floats for 2 place planes look very similar, are they generic to type? The rule with floats is that 1 float needs to be capable of supporting 90% of the max gross weight of the plane. Many manufacturers name their floats based on the weight they can support, e.g. "Edo 2100" can hold up 2100 lbs. Each model of float by each mfr. will have an STC allowing it to be installed on certain airframes. Also, sometimes the STC for float A allows an increase in the gross weight (b/c the floats generate lift in flight) while float B, which is no different really, did not do to testing to obtain this modification. Worth checking each model to see who offers the best overall package. Also, a Champ would not be my choice of airframe, I'd much prefer a PA-18, but if you just want to go for a ride around the lake it's probably plenty. Training is very important. Every landing is being made off-airport and the equipment is less forgiving. If you haven't earned your rating yet and want to learn with a bunch of real professionals, check these guys out: http://arctic.net/akfloats/ Just be forewarned that once you've flown in Alaska everything else will pale in comparison. Best, -cwk. |
Most people figure about a day to change.
Mike MU-2 "Robert M. Gary" wrote in message om... Talking with some of the sea plane operations, it seems pretty common to take floats on and off. However, the rigging and all for the floats (rudders, etc) seems complicated. Is it actually that easy to put floats on and off? If I bought a Champ could I just pick up a used pair of EDO float and put them on every once in awhile (I know insurance is another issue..)? Most of the floats for 2 place planes look very similar, are they generic to type? -robert |
and the equipment is less forgiving. If you haven't earned your rating yet and want to learn with a bunch of real professionals, check these guys out: http://arctic.net/akfloats/ Thanks. I did both my private and commercial sea ratings with Terry Campbell at Norcal aviation http://www.norcalaviation.com . Terry was featured on a Discovery Wings program on sea instructors. Technically, I'm also a sea instructor now. -Robert, CFI (land and sea). |
(C Kingsbury) wrote in message . com...
(Robert M. Gary) wrote in message . com... Talking with some of the sea plane operations, it seems pretty common to take floats on and off. However, the rigging and all for the floats (rudders, etc) seems complicated. Is it actually that easy to put floats on and off? It's more complicated than changing a tire, but not unreasonable to do at the beginning and end of the season, especially if the shop does it often. How do you get the plane from the lake to the airport after putting wheels on? |
"Robert M. Gary" wrote in message om... How do you get the plane from the lake to the airport after putting wheels on? Sometimes seaplanes are landed on wet grass runways. Some airports adjacent to water have seaplane ramps. |
Many years ago I had an Aeronca Sedan on Edo 2000s. It took a big day
each time to change the floats for the wheels etc. We lifted the airframe by the engine mount using three 4 X 4s as a tripod, although looking back on it I wouldn't recommend that from a lifting stress standpoint. Don't plan on landing on wet grass with floats. I have heard that dewey grass is more slippery, but a lot of float planes have ended on their backs after such a stunt. We built a three wheeled (a non swiveling nose wheel worked well) dolly for the spring takeoff from a hard surface runway, using a drag chute to stop the dolly after liftoff. In the fall we ramped it extra high on shore and converted it to wheels after freezeup, flying it off the ice back to a field to get it worked on. The first consideration on a float plane is where are you going to keep it. Hull insurance rates are outrageous. A cousin of mine was in the aircraft insurance business, and among other things insured four float planes. In one summer he lost all 4 of them! |
