Is hyraulic drive posible?
Old July 1st 04, 07:53 AM
PAW
Default Is hyraulic drive posible?
This is a BS question, but I'm curious.
I was looking at some hydraulic motors the other day and was wondering if
a pump and motor could be used to drive a prop. A crazy example; two
hydraulic motors and a couple pumps (powered with a mazda 13b maybe ??) to
power something like a Cessna 337 in-line thrust type aircraft.
Understanding weight would be an issue, I'm wondering how it would, or could
,work. I was looking at an Eaton motor that was rated at (up to) 3200 RPM @
about 120 ft. lb of torque. Weight was 20 lbs. They have a pump (48 lbs)
that moves 42 gpm @ 4000 psi.
Is it possible? Single place would be fine.
Old July 1st 04, 01:04 PM
Rip
Sure, why not? Or you could use the engine to drive a generator which
would then drive electric motors to spin the props. Or you could do away
with the added weight and complexity and drive the props right from the
engine!
Old July 1st 04, 02:18 PM
Mark Hickey
engine!
You should patent that idea!
Mark Hickey
Old July 1st 04, 02:44 PM
Rob Turk
"Mark Hickey" wrote in message
engine!
I'm sure the USPTO will be unable to find any form of prior art and assign
the pattent in a heartbeat...
Rob
Old July 1st 04, 03:16 PM
On Wed, 30 Jun 2004 23:53:15 -0700, "PAW"
So the engine drives a pump and the pump drives a hydraulic motor, and
the motor spins the prop, right? I'm thinking of the homebuilt
designers maxim: "Build it light and simplicate." In addition, you've
got the prop spinning at 3200 rpm which is kind of high and will mean
a smallish, noisy propeller that doesn't produce much low speed
thrust, which means long takeoff runs.
In addition, the weight of the items you mention will likely be higher
because you will need some means of cooling the oil, as it will be
working hard. There will also be the weight of the oil lines.
I'm not an expert but since you asked, here's a guess: Airplane
designers are a particularly ingenious lot. If it were possible to
utilize such a prop drive as you describe, I think someone would
probably have tried it by now. After all, we've had virtually every
other manner of providing thrust including photovoltaic cells coupled
to electric motors.
My guess is that your idea might work, albeit extremely marginally and
heat rejection will be a major issue, as will be efficiency due to all
the pumping losses incurred building pressure and converting the
pressure to rotational thrust. All for, in my opinion, relatively low
propeller thrust.
I'll bet a good mechanical engineer could compute the relative
efficiency of this design vs. a direct drive prop or PSRU driven prop.
That should be relatively painless and you'd know before buying any
pieces if this would be worth it or not.
Corky Scott
Old July 1st 04, 08:09 PM
PAW
"Bob Kuykendall" wrote in message
om...
Earlier, wrote:
...In addition, you've got the prop
spinning at 3200 rpm...
Well, that's one of the things that makes hydraulic drive sort of
compelling: There are plenty of variable displacement pumps that will
give you infinitely variable ratios. So there's no reason at all why
you would be constrained to 1:1 drive. Or even to any fixed ratio. And
the pumps and motors developed for airline and military aircraft
application offer some pretty good power/weight ratios. We're not
necessarily limited to the cast-iron lumps that Grainger sells for use
in industrial trash-smashers and the like.
...There will also be the weight of
the oil lines...
Well maybe the weight of the oil lines would be compensated by the
absence of shafts, belts, gears, etc...
One possible application might be for driving remotely-mounted
propellers for unconventional configurations, as the OP suggests.
Sure, for your typical aircraft of conventional configuration, direct
drive will probably continue to be best way to go. But perhaps for
retractable-propeller self-launch sailplanes, and other odd layouts,
the advantages of hydraulic drive might outweigh the disadvantages.
Bob K.
Thanks Bob.
Hydraulic power was the only way I could think of to use one engine with
two drives in an in-line thrust design. Some of these motors are very
lightweight (IMO) and,as you said, are not the $150.00 cast-iron jobs from
Graingers. These are $2300.00 each. They're piston motors. They ( Eaton )
carry several that are rated from 2000 RPM, up to 3600 RPM... several models
to choose from. And, they have a ton of torque! :
Phil (on his way to the patent office) J/K
Old July 1st 04, 08:20 PM
PAW
"Rip" wrote in message
engine!
And how might you suggest powering two props with *one* engine (when the
props are 12 feet from each other at opposite ends of the aircraft) via your
"less complex" methode of direct drive from the engine. Keep in mind a 13b
spins at 6000 RPM. Opps, gotta add a re-drive (or two). Thank you much for
your brilliant (and sarcastic) less complex answer.
if
to
could
RPM @
Old July 1st 04, 08:33 PM
Barnyard BOb -
If one gears a clock motor low enuff...
it is said that one could pull the earth off axis.
Hardly a desireable speed for a prop.
There is no free lunch where torque is concerned.
Best be careful what is implied to the uninformed.
http://vettenet.org/torquehp.html
http://www.carcraft.com/techarticles/868/
P.S.
Rotsa' ruck at the U.S. Pat. Off.
Barnyard BOb --
Old July 1st 04, 09:12 PM
PAW
"Barnyard BOb -" wrote in message
from
models
P.S.
Barnyard BOb --
You lost me. What gearing are you talking about? These motors would be
direct-drive.
Phil
Warp Drive Propeller Jean-Paul Roy Home Built 0 May 13th 04 01:28 AM
Warp drive or other ground adjustable props Wallace Berry Home Built 0 March 10th 04 04:02 PM
The Dean Drive - was Antigrav Felger Carbon Home Built 0 February 10th 04 01:27 AM
WTB VW Type I Reduction Drive Alan Home Built 0 January 2nd 04 04:14 AM
Any Canadians Who Can Provide Numbers on a Champ, Taylorcraft, or Luscombe with Warp Drive Propeller? Larry Smith Home Built 7 December 21st 03 09:39 PM
