circumnavigating Chicago Class B
Old September 16th 04, 10:40 PM
Neil Bratney
Default circumnavigating Chicago Class B
Hey all,
I'm looking at flying my PA 28-161 VFR from Minneapolis to South Bend,
Indiana, in a few weeks for a Notre Dame football game (go irish!). Two
big things, of course, stand in my way: Lake Michigan and the Chicago
Class B airspace.
I've looked at the Chicago Terminal Chart, and have come up with two
possibilities:
1.) Aim for the OBK VOR, then skirt under Class Bravo at 2,900, and hug
the lakeshore all the way around to South Bend.
2.) Take 'er up to 11,500 in southcentral Wisconsin, go above the Class
B airspace. I've never been up that high before! This might let me cut
a little deeper across Lake Michigan.
3.) Accept a transition through Class B from ATC.
I'm a pretty new VFR pilot (you might remember my Duluth post) with
about 80 hrs... but am very comfortable communicating with ATC in /
around MSP Class B airspace.
I will, as always, have VFR flight following. Will ATC be expecting me
to choose one of the above options when I approach Chicagoland? How
much ATC interaction should I expect while I'm over / under their
airspace? Maybe just handoffs?
Also, Meigs Class D is still on the chart. Is it really still in
effect/operation?
Thanks a ton!
Neil Bratney
PP-ASEL
Old September 16th 04, 11:32 PM
tony zambon
"Neil Bratney" wrote in message
Hey all,
Class B airspace.
possibilities:
effect/operation?
Thanks a ton!
Neil Bratney
PP-ASEL
in reverse order meigs is just a park now it is a class nothing.
flight following around ohare? you can try but dont count on it.
getting a transition through the class B? not a chance in hell.
climb above the class b? i wouldnt, there is a lot of high speed traffic
up there.
if the weather is good just head down the shoreline at about 2000 feet it
is really neat.
if the weather is a bit iffy head for the dupage vor to joliet vor then
gary
tony zambon
9941L
Old September 17th 04, 01:07 AM
Dave Stadt
Hey all,
Class B airspace.
possibilities:
effect/operation?
Thanks a ton!
Neil Bratney
PP-ASEL
If you have never transited the lake shore it is a million dollar ride and
definitely worth doing.
Old September 17th 04, 02:54 AM
Marc J. Zeitlin
tony zambon wrote:
Class
traffic up there.
I've done that (11,500 a couple of times), and it works fine. I've
never seen a "lot" of high speed traffic at that (or any other) level
that I fly at. All the small stuff is lower, and all the big stuff is
higher. All the big stuff down low is IN the "B", hence the "B" :-).
Plus, you can go in a straight line.
feet it
is really neat.
Agreed - it's wonderful in NYC - I imagine the same would be true for
Chicago.
Marc J. Zeitlin
http://marc.zeitlin.home.comcast.net/
http://www.cozybuilders.org/
Copyright (c) 2004
Old September 17th 04, 03:10 AM
Travis Marlatte
Chances of continuing flight following around Chicago is 50/50. Sounding
professional and time of day determines your chance of getting handed off.
Chances of tranisitioning the class B is zero. The lakeshore ride is the
better view. If the weather is iffy, stay west.
Most people transition the lakeshore at 2000. Personally, I do it at 2200 or
1800. Keep your eyes open. With Meigs gone, there is no one controlling the
lakeshore anymore. Talk to Gary around the south side.
If you want to talk, send me an email.
Travis
Hey all,
Class B airspace.
possibilities:
effect/operation?
Thanks a ton!
Neil Bratney
PP-ASEL
Old September 17th 04, 04:52 AM
vincent p. norris
I enthusiasticallly second that; it's the way I go to and return from
OSH.
But when I go from central PA down to the Outer Banks, I go over
Dulles above the Class B. Works great.
vince norris
Old September 17th 04, 05:25 AM
David Johnson
up there.
Baloney. All that "high speed traffic" is either taking off or landing
(way down below you) or is overflying waaaayyy above you at 11.5 or
12.5. Overflying is the safest place to be. The view is great as
well (assuming good weather)
Been there, done that
David Johnson
Old September 17th 04, 04:20 PM
tony zambon
"David Johnson" wrote in message
om...
traffic
up there.
David Johnson
sorry but i have to disagree. flying over the top of ohare is not a
good place to be. if you dont believe me check out the STARs, most have the
inbounds crossing various fixes at 30 to 40 miles out at 11,000 ft.
tony zambon
grumman
9941L
Old September 17th 04, 04:56 PM
Nathan Young
Option #1. The Chicago lakeshore view is awesome, especially on a
clear evening. Beware the lakefront and stadium TFRs that come and
go. Approach is 20.55. You can fly the lakeshore at 2900MSL. Watch
for other sightseeing traffic as it is heavy. Drop down lower and
look up at the Hancock and Sears Tower as you fly by. If you do the
OBK VOR to the lakeshore, be careful not to clip the lower ring of the
Bravo and/or PWKs airspace.
Option #2. If you are on flightfollowing, ORD approach will probably
ask you to go around ORD, and may cancel FF if you go over. Also,
Chicago center does not usually coordinate handoffs with ORD approach,
so you may find yourself mixing it up with the Janesville arrival
traffic without flight following. Good views, but doing this makes me
nervous.
Option #3 will not happen. I've been flying in ORD area for 10 years
and have had 1 VFR ransition through the Bravo, and that was at 2am.
Alternate option. Go around ORD to the West and South. Approach is
20.55, 33.5, 19.35 respectively. What's another 15 minutes of flying?
On Thu, 16 Sep 2004 21:40:12 GMT, Neil Bratney
Hey all,
Class B airspace.
possibilities:
effect/operation?
Thanks a ton!
Neil Bratney
PP-ASEL
Old September 17th 04, 05:32 PM
MLenoch
I've been flying VFR over the top of O'Hare for the past 20 years. Almost no
traffic up there. I find all of the traffic below 10,000' and above 4000'
around the sides of the class B. But then again, I transition over the top in
excess of 250 knots. For slower VFR, I'd recommend lake shore or the west side
as previous posts have described.
VL
Negative XPDR - under the outer ring of Class C bcjames Piloting 8 August 30th 04 11:49 PM
Run-in with Chicago Center Jay Honeck Piloting 93 August 24th 04 04:53 PM
Overlapping class C & D Andrew Sarangan Piloting 14 May 6th 04 04:08 AM
