#11
"Travis Marlatte" wrote:
Most people transition the lakeshore at 2000. Personally, I do it at 2200 or 1800. Is this option something you'd consider for a Cub or Champ cruising at 70 mph with a battery operated radio and no XPDR? If heading from the east coast (Mass) to Oshkosh in such an old timer how would you go? I doubt I can get over the top. Around the west side of Chicago or up through Canada are pretty far at such a slow speed, and 50 miles over water on the direct route is not something I'm anxious to try. |
In 20+ years of going to OSH from OH, I have only gone over the top
once. All but one other time have been along the lakeshore. The other exception was around the west side in 1985 in a Champ. That was to stop for lunch and fuel at Clow. Bob wrote: "Travis Marlatte" wrote: Most people transition the lakeshore at 2000. Personally, I do it at 2200 or 1800. Is this option something you'd consider for a Cub or Champ cruising at 70 mph with a battery operated radio and no XPDR? If heading from the east coast (Mass) to Oshkosh in such an old timer how would you go? I doubt I can get over the top. Around the west side of Chicago or up through Canada are pretty far at such a slow speed, and 50 miles over water on the direct route is not something I'm anxious to try. |
I have flown the low altitude route as well as over the top VFR and much
prefer the high altitude. If you have an engine problem you have a lot more options, and traffic is a lot more visible up high. Don't forget that all of the heavy iron has TCAS and will see you on the screen well before you see them. |
No radio? No problem. No XPDR? Oops. You'd have to be pretty far out over
Lake Michigan to be outside the ORD class B 30nm mode C veil. So, that depends on your definition of risk. Do you mind being 15 miles offshore with no floats and a battery operated radio that might not transmit to shore and no XPDR so that they could track your splash? That's too much risk for me. I'd stick to the farm fields south and west of the class B veil. -- ------------------------------- Travis "Bob" wrote in message ... "Travis Marlatte" wrote: Most people transition the lakeshore at 2000. Personally, I do it at 2200 or 1800. Is this option something you'd consider for a Cub or Champ cruising at 70 mph with a battery operated radio and no XPDR? If heading from the east coast (Mass) to Oshkosh in such an old timer how would you go? I doubt I can get over the top. Around the west side of Chicago or up through Canada are pretty far at such a slow speed, and 50 miles over water on the direct route is not something I'm anxious to try. |
"Travis Marlatte" wrote in message ink.net... No radio? No problem. No XPDR? Oops. You'd have to be pretty far out over Lake Michigan to be outside the ORD class B 30nm mode C veil. So, that depends on your definition of risk. Do you mind being 15 miles offshore with no floats and a battery operated radio that might not transmit to shore and no XPDR so that they could track your splash? That's too much risk for me. I'd stick to the farm fields south and west of the class B veil. Most Cubs and Champs were built without electrical systems and thus are exempt from the transponder requirements of the Mode C veil. |
Yep! I can fly right up to the inner-most cylinder, below 1200' AGL.
Steven P. McNicoll wrote: Most Cubs and Champs were built without electrical systems and thus are exempt from the transponder requirements of the Mode C veil. |
Travis Marlatte wrote: No radio? No problem. No XPDR? Oops. You'd have to be pretty far out over Lake Michigan to be outside the ORD class B 30nm mode C veil. He said a Cub or a Champ; that is, an aircraft that was built with no electrical system. He can fly such an aircraft within the veil as long as he stays out of the class-B itself. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
Oops. Sorry. I guess I should have assumed that from the "battery operated
radio" phrase. Then it's a phone call to get permission, right? -- ------------------------------- Travis "Steven P. McNicoll" wrote in message ink.net... "Travis Marlatte" wrote in message ink.net... No radio? No problem. No XPDR? Oops. You'd have to be pretty far out over Lake Michigan to be outside the ORD class B 30nm mode C veil. So, that depends on your definition of risk. Do you mind being 15 miles offshore with no floats and a battery operated radio that might not transmit to shore and no XPDR so that they could track your splash? That's too much risk for me. I'd stick to the farm fields south and west of the class B veil. Most Cubs and Champs were built without electrical systems and thus are exempt from the transponder requirements of the Mode C veil. |
ink.net... Oops. Sorry. I guess I should have assumed that from the "battery operated radio" phrase. Then it's a phone call to get permission, right? Only to operate within the Class B itself. Which is not what they are suggesting. |
"Travis Marlatte" wrote in message ink.net... Oops. Sorry. I guess I should have assumed that from the "battery operated radio" phrase. Then it's a phone call to get permission, right? No. No permission is required for VFR flight in the Mode C veil. |
| Thread Tools | |
| Display Modes | |
| Negative XPDR - under the outer ring of Class C | bcjames | Piloting | 8 | August 31st 04 12:49 AM |
| Run-in with Chicago Center | Jay Honeck | Piloting | 93 | August 24th 04 05:53 PM |
| Overlapping class C & D | Andrew Sarangan | Piloting | 14 | May 6th 04 05:08 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
