AA NiMH Best Deal
Old September 20th 04, 03:13 AM
Larry
"TD" wrote in message
Where can one find rechargeable AA Lithium batteries? Any safe way to
recharge those "non-rechargeable" Li AA batteries?
It's just not worth burning the shop to the ground to save a couple bucks
(in my opinion), just buy a name-brand rechargeable and be done with it.
(¯`·._.· £ãrrÿ ·._.·´¯)
Old September 20th 04, 05:48 PM
TD
"Larry" wrote in message ...
WHICH name-brand rechargeable Lithium AA batteries are you referring to?
Tien
Old September 20th 04, 06:42 PM
Peter
Many devices designed to operate on a pair of AA cells can also use the
RCR-3V Li+ cells (depending on the shape of the battery compartment).
A few manufacturers are shown he
http://www.thomas-distributing.com/rcr-v3-index.htm
Old September 21st 04, 02:18 AM
TD
"Peter" wrote in message
Thanks, but I was really hoping for some rechargeable AA Lithium batteries
to plug into my the battery compartment of my handheld GPS. My experience
with disposable AA Li batteries is that they last a heck of alot longer than
2300 mAH NiMH AA`s. So I was hoping for something in this generic form.
The key of course, is the compartment size issue.
Tien
Old September 21st 04, 03:42 AM
Peter
The problem is that the rechargeable Li ion chemistry results in a
battery voltage of over 3V/cell and would probably damage your GPS
receiver if you were to put two of those in instead of regular AAs, so
AFAIK they aren't made in AA size. The RCR-3V cells get around that
problem by making a single cell in a shape that approximates a pair of
AA cells side-by-side and with a voltage of just over 3V which is also
appropriate for two series AAs. They fit in the battery compartment of
my GPS which was made for AA cells and may work in yours as well.
The single-use AA lithiums are a different chemistry of Lithium Iron
Disulfide with a voltage of about 1.6. Based on their specs they should
last at least 50% longer than good NiMHs in a GPS receiver.
Old September 21st 04, 03:58 AM
Morgans
than
Tien
You do realize that Lithium ion batteries need a pretty sophisticated
charger to keep them from blowing up, right? You could buy a couple three
sets of NiMH batteries, and a charger, before you could buy the lithium
charger. #2 problem is that lithium batteries are 3 volts per cell, so you
can't do a straight swap in an AA battery pack.
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.766 / Virus Database: 513 - Release Date: 9/17/2004
Old September 21st 04, 03:22 PM
Rich S.
"Morgans" wrote in message
you
Even using a sophisticated charger, many Radio Control flyers remove their
Lithium battery from the airplane and charge it in a remote location, away
from other people, buildings, cars, etc. - just in case.
Rich S.
Old September 21st 04, 07:59 PM
TD
"Rich S." wrote in message news:S-
What makes this necessary for RC planes` Li batteries? I don`t
recharge my digital camcorder or digital camera in the shed to avoid
explosions! Or should I start doing that?!
Tien
Old September 21st 04, 08:45 PM
Rich S.
m...
their
away
Tien
Many times the modeler is using faster charge rates than the low-amperage
"wall-warts" which come with camcorders, etc. The risk of the battery
swelling, leaking, heating or exploding increases along with the charging
amperage. There is also the occasional case where someone uses a ni-cad
charger for Lithium/Ion or Lithium/Poly cells, or misadjusts a multi-mode
charger. There have been enough incidents now that most flying fields
require that battery charging be done waaaay over there!
Rich S.
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 04:30 PM
C & D NiMH Best Deal Larry Home Built 6 October 1st 04 01:41 PM
AA NiMH Best Deal Jim Weir Home Built 27 September 29th 04 08:39 PM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
D'Amato's Role Investigated in La Guardia Airport Deal Roy Smith General Aviation 0 December 25th 03 05:47 AM
