Simulator with 3-minotr support?
Old September 28th 04, 02:41 PM
Gary G
Default Simulator with 3-minotr support?
Thanks for your response.
I appreciate that you took the time to respond.
3-monitor cards can be had more easily than you think.
Who said anything about "new".
There are many second-hand locations, including Ebay, where you can get a good deal
on a pretty decent 3-monitor card.
In fact, although it's not below $100, I recently ordered a surplus Matrox 3-something card
that is fairly new, 3 monitor output plus an S-Video output for $119.
Not bad, eh?
Anyways - thanks for your response.
I'll have to look more into MS 2004 - it says multi-monitor support, but
it's not clear if it supports 3 and what can be displayed.
Sometimes it's non-3D kneeboard or other stuff.
I want 2 side scenery displays!
Regards,
Gary
Old September 28th 04, 08:13 PM
chris priest
Not bad, eh?
Regards,
Gary
There is new technology by NVIDIA that allows you to hook multiple GPUs
together so instead of running 3 monitors off three monitors, you can
run 3 monitors off 3 (or more) video cards. This way there will be no
power loss from the ultra high resolution of three displays. It would be
expensive, but awesome as heck.
link: http://www.nvidia.com/page/sli.html
Old September 30th 04, 06:46 AM
Cockpit Colin
I did this with (2 screens on) FS2002 a couple of years ago. Off memory it
was a little triky to resize the views and place them where I wanted them,
but the biggest issue (at the time) was the hit on performance - 25 fps on
one screen -v- around 5 fps with 2 monitors going - although obviously
things have improved a lot since then.
Food for thought - many video cards these days have 2 outputs - the usual 15
pin mini-din and another (digital?) output - which you can convert to a 2nd
15 pin mini-din with a cheap adaptor (we do this all the time). For a 3rd
monitor consider using any old PCI based card and use it just for the
instruments?
Old September 30th 04, 03:37 PM
Gary G
Good idea - thanks for the info!
35th's Life Support Section named best in the Air Force Otis Willie Military Aviation 0 July 16th 04 11:08 PM
24/7 computer tech support [email protected] Home Built 0 May 5th 04 03:32 AM
LONG DEPLOYMENTS, BENEFIT CUTS ERODE SUPPORT FOR PRESIDENT Ewe n0 who Military Aviation 0 March 17th 04 07:57 PM
USAFE commander: 86th Airlift Wing will divide for combat, support operations Otis Willie Military Aviation 0 November 27th 03 11:31 PM
