#21
I have uploaded a few Iowa City Municipal Airport images to
alt.binaries.pictures.aviation Thanks, Steven! They will make a fine addition to the history. Not complaining, just curious: The pix all seem to have a very fine checkerboard pattern on them. Is this imparted in scanning, or was it on the originals? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Jay Honeck" wrote in message news:QTj9d.200765$MQ5.54602@attbi_s52... Thanks, Steven! They will make a fine addition to the history. Not complaining, just curious: The pix all seem to have a very fine checkerboard pattern on them. Is this imparted in scanning, or was it on the originals? It's in the scanning. A different resolution can sometimes eliminate it. |
![]() "Steven P. McNicoll" wrote in message ink.net... "Jay Honeck" wrote in message news:QTj9d.200765$MQ5.54602@attbi_s52... Thanks, Steven! They will make a fine addition to the history. Not complaining, just curious: The pix all seem to have a very fine checkerboard pattern on them. Is this imparted in scanning, or was it on the originals? It's in the scanning. A different resolution can sometimes eliminate it. I suspect that is a Moiré pattern caused by dot scanning a photo with dots on it. Steven, take a close look at the photos you scanned and see if they were printed with a screen that left dots. If they are, check the scanner's user guide. Most scanners have a correction that can be applied to significantly reduce the effect. |
#24
![]() "Casey Wilson" wrote in message news:Ydl9d.8547$Sl2.1043@trnddc09... I suspect that is a Moiré pattern caused by dot scanning a photo with dots on it. Steven, take a close look at the photos you scanned and see if they were printed with a screen that left dots. If they are, check the scanner's user guide. Most scanners have a correction that can be applied to significantly reduce the effect. I'm using a Lexmark X75 combo. It didn't mention Moiré in the "Help" menu, but it did mention dot patterns: To remove image patterns from black and white or gray items: 1 Open the Lexmark X74-X75 All-In-One Center. 2 If the Scan. section of the All-In-One Main Page is not expanded, click See More Scan Settings. 3 Click Display Advanced Scan Settings. 4 From the Image Enhancements tab, select Smooth conversion of gray image to black and white dot pattern (dither), and then select a dithering algorithm from the drop-down menu. 5 Click OK to save your changes and return to the All-In-One Main Page. 6 Open the top cover on your scanner, and then place an item face down on the glass. 7 Close the top cover. 8 From the All-In-One Main Page, click Scan Now. 9 Save your scanned item. I followed that procedure and rescanned the 1937 IOW image. It's worse than it was before. The image is posted in alt.binaries.pictures.aviation There is a drop down menu where one must select a dithering algorithm. The selections are Burkes, Floyd-Steinberg, Sierra, and Stucki. I used Burkes. I'll work with it a bit to see if I can improve the image. |
#25
![]() "Steven P. McNicoll" wrote in message link.net... I suspect that is a Moiré pattern caused by dot scanning a photo with dots on it. Steven, take a close look at the photos you scanned and see if they were printed with a screen that left dots. If they are, check the scanner's user guide. Most scanners have a correction that can be applied to significantly reduce the effect. I'm using a Lexmark X75 combo. It didn't mention Moiré in the "Help" menu, but it did mention dot patterns: To remove image patterns from black and white or gray items: 1 Open the Lexmark X74-X75 All-In-One Center. 2 If the Scan. section of the All-In-One Main Page is not expanded, click See More Scan Settings. 3 Click Display Advanced Scan Settings. 4 From the Image Enhancements tab, select Smooth conversion of gray image to black and white dot pattern (dither), and then select a dithering algorithm from the drop-down menu. 5 Click OK to save your changes and return to the All-In-One Main Page. 6 Open the top cover on your scanner, and then place an item face down on the glass. 7 Close the top cover. 8 From the All-In-One Main Page, click Scan Now. 9 Save your scanned item. I followed that procedure and rescanned the 1937 IOW image. It's worse than it was before. The image is posted in alt.binaries.pictures.aviation There is a drop down menu where one must select a dithering algorithm. The selections are Burkes, Floyd-Steinberg, Sierra, and Stucki. I used Burkes. I'll work with it a bit to see if I can improve the image. I think I've got it now. There is another 1937 image at alt.binaries.pictures.aviation |
#26
![]() "Jay Honeck" wrote in message news:QTj9d.200765$MQ5.54602@attbi_s52... Thanks, Steven! They will make a fine addition to the history. Not complaining, just curious: The pix all seem to have a very fine checkerboard pattern on them. Is this imparted in scanning, or was it on the originals? I changed the settings on my scanner and rescanned the images. That pattern is gone and the images are larger and show more detail. Of course, the files are larger as well. They've also been posted to alt.binaries.pictures.aviation |
#27
![]() "Steven P. McNicoll" wrote I think I've got it now. There is another 1937 image at alt.binaries.pictures.aviation What did you come up with, as a solution? -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.774 / Virus Database: 521 - Release Date: 10/7/2004 |
#28
pattern is gone and the images are larger and show more detail. Of course, the files are larger as well. They've also been posted to alt.binaries.pictures.aviation Those are AWESOME! Thanks! I just added the originals to the IC Airport History website earlier today. I'll have to re-do it with these new scans tomorrow. BTW: There were only three of the new scans on the binary channel -- was that correct, or did I somehow miss the other ones? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#29
#30
![]() "Jay Honeck" wrote in message news:GGI9d.213777$D%.137529@attbi_s51... BTW: There were only three of the new scans on the binary channel -- was that correct, or did I somehow miss the other ones? I posted images from 1937,1948, 1959, 1970, 1982, and 1989. I see all of them in the binaries group. |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
N94 Airport may expand into mobile home community, locals supportive | William Summers | Piloting | 0 | March 18th 04 03:03 AM |
Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 05:35 PM |
Enola Gay: Burnt flesh and other magnificent technological achievements | me | Military Aviation | 146 | January 15th 04 10:13 PM |
