Question on fuel consumption
Old October 23rd 04, 12:50 AM
C Kingsbury
"Mike Rapoport" wrote in message
ink.net...
Of course this is basically true for any two aircraft, the larger one will
get more passenger miles per gallon. A 777 gets a lot more than a 737 for
instance. The same is true for car vs bus.
There are two numbers that tell the story: the weight of the vehicle per
passenger carried, and the speed at which the vehicle travels. All other
things being equal, it takes more power (and thus fuel) to carry more
weight, and more power to carry a given amount of weight faster. If I
throttled my 172 back to highway speeds I suspect the fuel consumption would
rival many cars', though the same could not be said for payload.
One interesting result of this is that many more modern passenger jets
consume less fuel per passenger-mile than high-speed trains, because the
trains carry a lot more dead weight per passenger. It is thus quite likely
that the BOS-LGA shuttle operates at a higher fuel efficiency than the
high-speed Amtrak train making the same trip.
Best,
-cwk.
Old October 23rd 04, 06:31 AM
C J Campbell
"John Galban" wrote in message
om...
snip
Some small single piston engine planes can easily exceed thirty miles
per
gallon, while others are doing well to get a third of that.
I'm curious, CJ. Can you provide an example of a light single that
easily exceeds 30 mpg? Most of the more common ones (172, PA28,
etc..) tend to average around 15 to 18 mpg, depending on the power
setting.
I know a guy who claims to get that in his Long-EZ, and my brother says he
will probably get that or better in his Celerity Mirage if he ever finishes
it.
Old October 23rd 04, 03:32 PM
Chris W
setting.
The Van's Aircraft RVs get right around 25 mpg
Chris W
Not getting the gifts you want? The Wish Zone can help.
http://thewishzone.com
"They that can give up essential liberty
to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin, 1759 Historical Review of Pennsylvania
  #24
Old October 25th 04, 05:53 PM
Paul Sengupta
ink.net...
Not always the case. From the SAS website, the efficiencies of their various
aircraft:
Family: DH-Q400 (turboprop)
Q400, 58-72 seats, 0.039 liters per seat / km
Family: MD-80 series
MD87, 110-125 seats, 0.048 liters per seat / km (JT8D)
MD81/82, 141-145 seats, 0.043 liters per seat / km (JT8D)
MD90, 147 seats, 0.039 liters per seat / km (V2500)
Family: 737 (all CFM-56)
737-600, 123 seats, 0.044 liters/seat km
737-700, 131 seats, 0.042liters/seat km
737-800, 179 seats, 0.034 liters/seat km
Family: A320
A321-200, 184 seats, 0.031 liters / seat km (V2500)
Family: A330/A340
A330-300, 261 seats, 0.035 liter / seat km (Trent 700)
A340-300, 261 seats, 0.039 liters / seat km (CFM-56)
The bigger planes or those with more efficient engines in each family
do better but it's not necessarily the case that the bigger planes are
more efficient. However you can't compare these exactly as the
short haul are probably more densely packed with seats than long
haul.
Paul
  #25
Old October 25th 04, 11:50 PM
David CL Francis
On Fri, 22 Oct 2004 at 23:50:36 in message
. net, C Kingsbury
What matters is drag. On the level a train may be heavy but its friction
is very low.
Rolling friction is roughly 10lb per ton or a bit less. So a train on
level ground has a 'Lift' to drag ratio of 224. Air drag is a tiny part
of a train's drag but let's say assume it easily achieves 200 to 1. For
a 747-400 let's assume that it has a lift drag of 20 to 1. In cruise at
say 705,000 lb. the 747 drag is therefore around 35,250 lb.. A train
with about the same drag could therefore weigh around 3,250 tons. They
both need a lot of energy to climb and the weight of train may be
against it but they don't have to climb above 30,000 ft! :-)
Let me know the AUW weight of the high speed Amtrak train and I can do
it bit better.
Incidentally the drag of an aircraft flying at its maximum Lift/Drag
ratio is the same at all heights. But at altitude it flies much faster
for the same drag.
So some questions for you. Do modern jet airliners use less fuel per
mile by flying higher or do they just get there quicker? Or perhaps the
engine efficiency is much higher at altitude? Better specific thrust
perhaps?
David CL Francis
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
Declared "minimum fuel" O. Sami Saydjari Instrument Flight Rules 14 April 4th 04 02:43 AM
Repairing Plastic Instrument Panel Overlay Jeff P Owning 22 January 29th 04 06:42 PM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
Why did Britain win the BoB? Grantland Military Aviation 79 October 15th 03 03:34 PM
