#11
Most of my time is high-wing but I've flown various
low-wing planes - SR20, Mooney, Grob, a couple of hours in Cherokees. They all have something in common compared to high-wing planes - they feel like they land flatter. Don't try to full-stall them in a really nose-high attitude. I managed to hit the tie-down ring in the SR20 doing that once. Of course when I say "flatter" I don't mean "flat" - there is still a fair amount of nose-up and the mains touch first but it is a different feeling and sight picture than the Cessna. Of course the other comments are all true too, especially speed control. John Jon Kraus wrote: We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
"Jon Kraus" wrote in message
... I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . I think you're most of the way there, in that you've correctly identified the major issue. Once you've got the speed control mastered (which is critical, as everyone has told you) it *is* all about sight picture and knowing where the wheels are in relation to the runway. Mooneys are particularly unflattering of bad landings because of the nature of the gear, but no harder to land well. Julian Scarfe |
Julian Scarfe wrote:
"Jon Kraus" wrote in message ... I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . I think you're most of the way there, in that you've correctly identified the major issue. Once you've got the speed control mastered (which is critical, as everyone has told you) it *is* all about sight picture and knowing where the wheels are in relation to the runway. Mooneys are particularly unflattering of bad landings because of the nature of the gear, but no harder to land well. I'd add one more thing to the speed control notes. You want to be crossing the threshold at 71 knots (M20J). On final, if you see you are high, try -raising- the nose and scrubbing off 5 knots or so. It's counterintuitive, but you will find raising the nose at this speed will increase your descent angle. For a normal landing, cross the threshold at 71. For a short-field landing, 65. Don't go any slower than that or you won't be able to flare. Don't go any faster, or you'll float or bounce. There's little shock absorrption in the landing gear, so don't let it touch when you're going to fast or you'll be airborne again in a heartbeat, with a wheelbarrow to follow. |
I can relate. I just got my first few landings in a Comanche-250 the other
day. The downward pitch and apparent nose-scrubbing tendency was the biggest hurdle. I normally land my Cherokee with 2 of the 3 notches of flaps to keep it from pitching the nose down so much. With the speed of the Comanche (which I've heard is very similar to the Mooney save for the strut/puck gear differences), all the flaps are normally required. It seemed to be a matter of holding the (apparent nose-low) attitute *by sight* before flaring to let the speed bleed off. Then the actual touchdown was by feel once slow enough to not balloon and keep the nosewheel off. YMMV... sure did like the 1500 fpm climb though... ![]() -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
How tall are you? If you are not a very tall person you may be having a hard
time seeing over the cowl. The seats are very low in the Mooney since the plane was designed for 6' + individuals. What I like to do with students is to pull onto the runway and sit there lined up with the runway (make sure the CFI is watching for traffic you have your back too!). Really take the time to get used to the picture down the runway with the plane on the ground. Notice where the runway edge intersects your head (probably above your ears). Although some runways are more wide or narrow the runway edge will always intersect your head at the same point (its based only on your hight above the runway). Also, when landing the Mooney understand that if the stall horn isn't even going off you are far, far from landing speed. The Mooney will float and in the begining you can use the stall horn to help determine when you should allow the plane to sink below 3 feet. Anything faster than 65 knots or so should be kept above 3 feet. The Mooney gets very upset if the nose wheel touches first because there are no shocks. Because of the donut's characteristics the nose will push back rather hard and bounce you back into the air. You get 2 bounces for free, the 3rd will cost about $15,000. As long as you control your speed in the Mooney, plan your decents far enough out, and keep ahead of the plane you will find it a very nice, rather easy plane to fly. It does not deserve the neg reputation it has for being hard to fly. -Robert, Mooney CFI "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
"Robert M. Gary" wrote
Really take the time to get used to the picture down the runway with the plane on the ground. Robert, I go one step further, I get out and hold the tail down in order that the student can see (and hopefully retain) the landing attitude. Bob Moore |
Don't flare a Mooney.
What you know as a flare will cause nothing but trouble. Instead of the "flare" do a "round out". If you have good electric trim, use it instead of back pressure. Also, don't chop the power, remove it SLOOOOWWWWLLLY. The plane can land before idle.You want a slow transition from nose down to nose wheel just a bit higher. Let the plane fly down the runway while the speed bleeds. Worry about spot landings after you have practiced smooth ones. Once you have the site pictures and techniques, you can move it to the numbers. What others have said about airspeed and stabilized approach are more important than what I just said, but if you got them right this is the next step. "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
Don't forget that, as with any airplane, stall speed and thus approach speed
vary with weight. If 70 knots works well on short final at max gross weight, then to get the same flare and float characteristics, you must be slower at lighter weights. If the plane is 20% below max gross, then approach speed should be 10% less. |
I should have said MPH... I am just so used to using knots for the
Skyhawk I forgot. My bad!! JK Dudley Henriques wrote: "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ Hi Jon; I've flown the Mk21 and even the old Mite, but it's been a few years :-) Mooney's are VERY clean and have a tendency to stay put in the flare until they bleed off energy (airspeed). It's not a big deal really, but it pays you to fly a stabilized approach in these airplanes and nail the flare airspeed right on the nose. Their slippery enough that they can get a bit away from you airspeed wise almost before you can catch it, putting you in the flare a bit hotter than you want to be. If this happens, just hold it there if you have the room and let it bleed into the landing, or take it around if you have any doubt at all about the available runway. Ground effect is prevalent in a Mooney because of the short gear height. It can be tricky, but it's nothing to worry about if you're getting a good checkout. One thing to remember in Mooney's; actually any airplane for that matter, but especially something as slippery in the air as a Mooney; stay ahead of the airplane. You don't have the drag of that 172 to bail you out of an airspeed pickup on approach. Start flying the airplane where it will be ten seconds from now and you'll have a fair handle on things with a Mooney. One more thing; stop for a second on line up before takeoff and look directly ahead of you over the glare. Remember that view. That's what you'll be seeing at the instant of touchdown! Good luck; Dudley Henriques International Fighter Pilots Fellowship for email; take out the trash |
I don't think you specified either way did you? All I saw were the
numbers with no mph or kts indicated. I think someone mentioned the difference in a post perhaps? As I said, I haven't flown the Mooney's for a while, but if indeed you WERE dealing with knots, 80 kts over the fence in a Mooney might be a bit hot :-) Anyway Jon, AIRSPEED control is the vital message here. Fly it by the book, and alter if needed for conditions, fly a stabilized approach and NAIL the airspeed at the flare.....and there IS a flare in a Mooney just like any other airplane. It's just fast, smooth, and slippery, so airspeed control is more critical with higher performance airplanes. It's ok to consider the flare as a "transition" into a landing if you like, because that's all it is anyway :-) Dudley Henriques International Fighter Pilots Fellowship for email; take out the trash "Jon Kraus" wrote in message ... I should have said MPH... I am just so used to using knots for the Skyhawk I forgot. My bad!! JK Dudley Henriques wrote: "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ Hi Jon; I've flown the Mk21 and even the old Mite, but it's been a few years :-) Mooney's are VERY clean and have a tendency to stay put in the flare until they bleed off energy (airspeed). It's not a big deal really, but it pays you to fly a stabilized approach in these airplanes and nail the flare airspeed right on the nose. Their slippery enough that they can get a bit away from you airspeed wise almost before you can catch it, putting you in the flare a bit hotter than you want to be. If this happens, just hold it there if you have the room and let it bleed into the landing, or take it around if you have any doubt at all about the available runway. Ground effect is prevalent in a Mooney because of the short gear height. It can be tricky, but it's nothing to worry about if you're getting a good checkout. One thing to remember in Mooney's; actually any airplane for that matter, but especially something as slippery in the air as a Mooney; stay ahead of the airplane. You don't have the drag of that 172 to bail you out of an airspeed pickup on approach. Start flying the airplane where it will be ten seconds from now and you'll have a fair handle on things with a Mooney. One more thing; stop for a second on line up before takeoff and look directly ahead of you over the glare. Remember that view. That's what you'll be seeing at the instant of touchdown! Good luck; Dudley Henriques International Fighter Pilots Fellowship for email; take out the trash |
Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 06:49 PM |
Landing a Mooney | Jon Kraus | Owning | 42 | November 16th 04 07:00 PM |
VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 05:22 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
