#21
Don't forget that, as with any airplane, stall speed and thus approach speed vary with weight. If 70 knots works well on short final at max gross weight, then to get the same flare and float characteristics, you must be slower at lighter weights. If the plane is 20% below max gross, then approach speed should be 10% less. A couple of other things that might be a bit more 'advanced', or at least are not in the POH but are worth considering. When you're deep in the flare, flip your flaps to up. Stall speed goes up, the airplane will stay down when it touches down. If there's a serious cross wind and the runway is wide -- say 100 feet or so -- you can take 4 or so degrees off the crosswind component by planing your touch down near the downwind side of the runway, aiming towards the upwide side. If you cross say 50 feet of runway -- 25 feet from the downwind edge to within 25 feet of the upwind edge in say 750 feet you'll have changed the effective runway heading about 4 degrees. It's often enough to give you a little more rudder authority (in my M20J at least I run out of rudder in strong cross winds -- I like to touch down pretty slowly). |
Until you get your visual sight picture down you might try reducing power to
idle at about 50' and just flying it onto the runway with a controlled smooth descent, making sure you don't land nosegear first. Then when you have that down you could use the "normal" procedure of holding it just off the runway until it plays out and lands. With a low wing you have a little more ground effect near touchdown. -- Darrell R. Schmidt B-58 Hustler History: http://members.cox.net/dschmidt1/ - "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
Hard to resist this thread. I was on the Mooney listserver for a couple of
years and there is an 'unlimited' number of landing notes for you. Every model, vintage, condition. If you aren't on it, you should be. Don't have the details though. The various models apparently have different speeds, challenges, and techniques. I flew a '61 model 21 with the Johnson bar. I fell in love with landing it, and I'm a high wing guy too. Airspeed as always was the key. The thing I liked the most though, was doing short field landings at 65mph as I remember. At a very specific airspeed (68 I think at our weight), you apparently fell out of laminar flow mode and the descent angle would significantly steepen. If you held 65 and pulled the power 2 wingspans up, it was automatic spot landing. Neat. I think someone else mentioned that effect (pitch up and slow 5 knots and the descent rate goes up). Apparently that is a lot trickier on the later heavier models. Have fun! "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
#24
wrote: With the speed of the Comanche (which I've heard is very similar to the Mooney save for the strut/puck gear differences), all the flaps are normally required. It seemed to be a matter of holding the (apparent nose-low) attitute *by sight* before flaring to let the speed bleed off. The transition from floating to landing can be abrupt. If you're a few feet in the air when that happens you're going to plonk down (properly inflated struts are important for this maneuver!). If you round out to about 1' up you will have time to sense that final sink and flare. You'll have to pull more than you think, otherwise you'll just fall. This was tricky for me to get used to because if you balloon it's followed abruptly by the aforementioned plonk. If it works your touchdown attitude will be very nose-high. If you start to balloon add power immediately. I found that my fly-just-above-the- runway reflexes from the C172 led to a lot of ballooning early on. What I prefer to do now is round out very low and fly as close to the runway as possible so that the final sink/plonk is more gentle. This is more like my C172 technique, but the results are much different from a C172. A 172 will go slower and slower and more nose high until you land. The Comanche will maintain essentially the same attitude until you settle onto the runway. Once you're down, either don't brake (you'll just skid) or raise the flaps first. A lot of people are squeamish about the idea of touching the flaps on the runway. If you want to stop in the shortest possible distance you have no choice, IMO. -- Ben Jackson http://www.ben.com/ |
#25
Orval Fairbairn wrote:
In article , Jon Kraus wrote: We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Remember to KEEP THAT NOSE OFF! Too many Mooney drivers land too fast, touch nosewheel first and wheelbarrow down the runway. Proper flare technique is critical on a Mooney. How about if you are "in" a Mooney? :-) Matt |
#26
"Ben Jackson" wrote The transition from floating to landing can be abrupt. If you're a few feet in the air when that happens you're going to plonk down (properly inflated struts are important for this maneuver!). Ben Jackson What Mooney has inflatable struts? All I have seen have rubber donuts. Damn, those are hard to chew, and digest, too. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.788 / Virus Database: 533 - Release Date: 11/1/2004 |
#27
I generally take 5 knots off everything in my Mooney when I'm light.
"Barry" wrote in message ... Don't forget that, as with any airplane, stall speed and thus approach speed vary with weight. If 70 knots works well on short final at max gross weight, then to get the same flare and float characteristics, you must be slower at lighter weights. If the plane is 20% below max gross, then approach speed should be 10% less. |
#28
Excellent idea but I'm not sure if I'm strong enough to do that. I've never
noticed the Mooney tending to tip (unlike a 172). You must be a large muscle type of guy. You aren't by chance the governor of California are you? BTW: I find that for tailwheel training its really good to have the student sit in the plane while we lift the tail. Students tend to think that they will hit the prop on a wheel landing (some times you can though). They don't realize that most tailwheels will "tuck" the prop under the plane before it hits the ground. You generally have to tip MUCH more than students think to hit the prop in the tailwheel. -Robert "Bob Moore" wrote in message . 122... "Robert M. Gary" wrote Really take the time to get used to the picture down the runway with the plane on the ground. Robert, I go one step further, I get out and hold the tail down in order that the student can see (and hopefully retain) the landing attitude. Bob Moore |
#29
I also do my short field landings like that when I'm in Mexico with my
Mooney. As you slow the Mooney down below around 70 knots the rate of decent goes up a lot. You can drag it in on the prop and drop it one a spot easily. If you run the trim all the way back you can also raise the nose up on take off and accelerate on the mains. Tricky though, check out a CFI first. BTW: If you are flying an older Mooney just substitute knots for mph. So the older Mooneys approach at 75-80mpg, the newer one use 75-80 knots. Same thing with over the fence speed (should be 5 mph less than your approach speed). Kinda neat that it works out that way. -Robert "Maule Driver" wrote in message om... Hard to resist this thread. I was on the Mooney listserver for a couple of years and there is an 'unlimited' number of landing notes for you. Every model, vintage, condition. If you aren't on it, you should be. Don't have the details though. The various models apparently have different speeds, challenges, and techniques. I flew a '61 model 21 with the Johnson bar. I fell in love with landing it, and I'm a high wing guy too. Airspeed as always was the key. The thing I liked the most though, was doing short field landings at 65mph as I remember. At a very specific airspeed (68 I think at our weight), you apparently fell out of laminar flow mode and the descent angle would significantly steepen. If you held 65 and pulled the power 2 wingspans up, it was automatic spot landing. Neat. I think someone else mentioned that effect (pitch up and slow 5 knots and the descent rate goes up). Apparently that is a lot trickier on the later heavier models. Have fun! "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
#30
Years ago I did allot of flying in a M20C, they are fast and tend to float.
If I remember the key is to be right on the speed at flare or expect it to balloon and float. It will get better with practice. Ron Gardner Jon Kraus wrote: We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
| Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 07:49 PM |
| Landing a Mooney | Jon Kraus | Owning | 42 | November 16th 04 08:00 PM |
| VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 06:22 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 05:35 PM |
