A newbie doubt, if it's ok...
Old November 4th 04, 06:49 PM
Ramapriya
Default A newbie doubt, if it's ok...
Hi there,
Is a non-aviator airing a doubt ok with you folks?
I know cars and trucks tend to skid even at low speeds in sleet and on
ice, with braking often proving ineffectual. This leaves me wondering
why is it that we don't ever hear of aircraft skidding and going
off-track while taxiing or even during takeoff/landing? Is the lack of
such incidents only because of the meticulousness of ice clearance by
airport authorities?
Look forward to a comment on this from you experienced folks
Cheers,
Ramapriya
Old November 4th 04, 07:08 PM
jls
"Ramapriya" wrote in message
om...
Hi there,
Cheers,
Ramapriya
Old November 4th 04, 07:14 PM
Greg Butler
It is because no pilot would dare take off or land on an icy runway, and yes
they are meticulously cleared at major airports.
Old November 4th 04, 07:17 PM
C Kingsbury
om...
These things do happen, though mostly to small planes and not generally
fatal so they're not big news items.
Why doesn't this happen with airliners? I'll hazard the following guesses:
1. Thrust reversers provide braking power even if the tires have no grip at
all
2. Landings are made in a straight line on a flat runway. It's curves and
hills that cause trouble on icy roads.
3. Weight-to-tire-area ratio: I'm guessing here, but it seems to me that
airliners put a lot of weight on a relatively small amount of tire area
compared to cars. This would improve traction.
4. Operator skill: Trained pilots vs. idiot/unskilled drivers
In my (limited) experience, you're lucky if the runway is cleared of
snow/ice better than the highways, especially during/after a large storm.
-cwk.
Old November 4th 04, 07:36 PM
Peter Duniho
om...
Sure.
Perhaps you just aren't receiving your information from sources that would
mention such an event.
Is the lack of
At some airports, yes. Generally, the more important an airport is to the
national transportation system (and all airports are important at least to
some degree), the better quality of maintenance, including keeping the
pavement clear of snow and ice. Some of the largest airports even have
heated runways, I believe.
Even so, once in a very long while, an airliner does wind up skidding off
the runway or taxiway somewhere. I don't know the exact frequency, but
probably on the order of once a decade or so.
At smaller airports, this happens more frequently, but as with cars, it
rarely involves more than some bent sheet metal. Accidents are likely to be
low speed (almost all taxiing happens at relatively low speeds...5-10mph at
most), and those that happen on landing (i.e. at higher speed) often don't
wind up in the news because they happened at the airport, rather than
somewhere that would make for something that sells ads on the evening news
(like a residential neighborhood).
Another factor is that airplanes have more to control them than just the
tires. In particular, the faster the airplane is going, the more likely the
same surfaces used to control the airplane in the air can also be used to
control the airplane on the ground.
Just as a "for example", I landed at the Reno, NV airport once on a VERY hot
day, while flying a small four-seater single-engine airplane. I landed on
the same runway that the big airliners use, and touched down in the same
spot that they do. Well, it turns out that when they touch down, each one
leaves a little rubber. By the time I'd arrive, there was a WHOLE LOT of
rubber, at a very high temperature. It was as slick as any ice, perhaps
slicker.
I had no braking whatsoever. But I didn't lose control of the airplane,
because I still had plenty of rudder control to keep me going in the right
direction. I simply "flew" the airplane while on the ground, until I got to
the pavement that was clear, made a normal stop and taxied off the runway.
This same effect helps prevent takeoff accidents...long before the airplane
leaves the ground, the tires are no longer required to keep the airplane
aligned with the runway. Rudder control is perfectly sufficient, especially
on a runway that is nice and flat.
Of course, all of the things that "cwk" mentions are relevant too. The
bottom line is that it's not actually true that airplanes don't have trouble
with ice, but it IS true that there are reasons those issues come up less
frequently than they might with automobiles.
Pete
Old November 4th 04, 07:44 PM
Journeyman
Depends on the doubt. Some "doubt"s sound like trolls.
Good question. In fact it does happen on occasion. Sometimes
airlines run off the end of the runway, the equivalent of a (very
expensive) fender bender, with few injuries.
It doesn't happen often because the main difference between airplanes
maneuvering on the ground and road vehicles is that airplanes are
going much slower, so the brakes remain relatively effective (add
extra distance for the stopping distance). At higher speeds when
taking off and landing, they're getting their drive and control from
aerodynamic forces.
A number of years ago when the world was younger, a buddy who was/is
(lost touch with him) a Greek national, who's mother work(s|ed) for
the airline told a story of sitting in the jump seat of a 747 leaving
NY.
It was the first plane out after a closure (usually, the first airline
out "sweeps" the runway) The copilot, who didn't have any winter
driving experience (not a lot of winter driving conditions in Greece)
turned onto the runway, applying too much power, spun out. No
damage, except to pride.
Normally, when that happens, you go back to the end of the line (there
will be a long line of delayed planes waiting to leave under those
conditions). The pilot of the #2 aircraft "politely" let them try
again anyway (so he got the freshly sweeped runway).
Morris
Old November 4th 04, 08:01 PM
Dale
I was going to argue this point with you, but realized that when I did
my landings and takeoffs from the surface of a frozen lake it wasn't a
"runway".
It was icy however. G
Dale L. Falk
Old November 4th 04, 08:40 PM
jls
om...
Hi there,
Cheers,
Ramapriya
They WILL skid but don't ordinarily. Many of the older aircraft did very
well without brakes. You taxi slowly and don't generate any centrifugal
force in a turn.
If you take off in a straight line, which aircraft do, 99% of the time there
is no force which can cause the aircraft to skid. You use rudder and
aileron to correct against any force, like the wind or torque of the
propeller, to keep your takeoff under control.
I see skid marks on our runway all the time. Tires skid as soon as they
touch down. It takes them a few feet to spin up. Sometimes a pilot will
get on the brakes a little too heavy and skid, but that's either because
he's had poor training or is about to run out of runway on landing rollout.
The brakes on my old airplane from the forties are very poor and only
effective enough to allow me to turn during taxi by differential braking.
Otherwise I never use them except when landing on a very short field when I
can see the bark on the trees ahead.
Old November 4th 04, 09:53 PM
Dean Wilkinson
1. Ground vehicles rely on their tires for propulsion, which can lead to
loss of control on slick surfaces. Airplanes use propellors or turbines
which push air around for propulsion.
2. Ground vehicles rely solely on their tires for directional control,
which lose traction on slick surfaces. Airplanes can utilize thrust
(including differential thrust) and flight control surfaces (rudder) for
directional control on slick surfaces.
3. Ground vehicles rely solely on brakes and tires for stopping. Many
airplanes have thrust reversers to help them stop. Single engine piston
airplanes have the same problem as ground vehicles when it comes to
stopping.
As you can see, airplanes possess a number of advantages over ground
vehicles for manuevering on slick surfaces. They aren't completely immune
to the problem, but less prone to loss of control.
Dean
om...
Hi there,
Cheers,
Ramapriya
Introduction to a newbie Shane O Aerobatics 9 December 31st 04 06:13 AM
Questions from a newbie. Andrew Tubbiolo Home Built 9 September 14th 04 01:40 AM
Iran does not doubt Bush's stupidity but... Matt Wiser Military Aviation 3 February 16th 04 06:22 PM
Newbie questions Rail / Ejector launchers AL Military Aviation 19 November 14th 03 07:47 PM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 05:23 PM
