Slats and Fowler Flaps On Light Plane
Old July 25th 03, 02:51 PM
Brock
Default Slats and Fowler Flaps On Light Plane
I feel there is a real advantage to the use of slats and flaps in
order to have things happen slowly during landing and yet still have a
good cruise speed. Of course the problem is in the complexity and the
extra weight. For rails I was thinking about something like standard
kitchen drawer rails or perhaps a tube within a tube design. I
wouldn't think their would be a lot of force on the slat at low
takeoff speeds so the structure wouldn't have to be bullet proof,
their would probably be a lot more force on the flaps though. I
haven't been able to find information if the necessary airplane
hardware is available commercially, perhaps it would have to be custom
made. Any ideas on how to go about building something like this?
Brock
Old July 25th 03, 05:50 PM
Kyle Boatright
"Brock" wrote in message
om...
Brock
You could copy the flap design from the RV-10 or the Glasair series. Good
luck on the slats - those have to be built to very tight tolerances so they
operate at the same time. Differential slat extension has killed quite a few
people. Also, more than a few people have been killed by having a slat
depart the airframe in flight.
Vortex generators might be a safer alternative.
KB
Old July 25th 03, 06:18 PM
Bob Kuykendall
something like standard kitchen
within a tube design. I wouldn't
force on the slat...
The two factors that might surprise you are the worst-case loads on an
extended slat at design limit loading, and the consequences of failure
of the actuators or the support rails. Taken together, they suggest
that the structure should be about as bulletproof as any other element
of primary structure.
...perhaps it would have to be
custom made.
Almost certainly the case. Fortunately, the raw materials (bearings,
steel, aluminum) are all relatively cheap and plentiful. Let the
Aircraft Spruce (or Wicks) catalog be your guide and playground.
Make a sectional model out of garbage (plywood, masonite, nails) and
keep modifying it until it gives good motion.
Then make a prototype of one of the actuator/support stations, and
load test it to validate that it supports loadings about 1.5x of the
maximum expected.
Then make a full-scale prototype and test it on the experimental
aircraft of your choice. Good luck.
The slats on the Me-109 (or Bf-109) might be a god model to start
from. I understand that they're just spring-loaded so they pop out
when the pressure at the stagnation point goes below a certain value.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com/hp-24
Old July 25th 03, 06:55 PM
Philippe Vessaire
Le Vendredi 25 Juillet 2003 18:50
Good luck on the slats - those have to be built to very tight
tolerances so they operate at the same time. Differential slat
slat depart the airframe in flight.
The slat MUST be built with mecanical link to operate together. See
what you can read about french design Morane Rallye ('60 to '80).
This plane had all the features you want.
By
Philippe Vessaire Ò¿Ó¬
Old July 26th 03, 12:15 AM
Ernest Christley
If there isn't a lot of force on them then they aren't doing you any good.
----Because I can----
http://www.ernest.isa-geek.org/
Old July 26th 03, 12:33 AM
Peter Dohm
Brock
Whereas the Helio Courier and Morane Rallye (among others), and their
slats, are discussed elsewhere in the thread; I'll just mention that all
of the high wing Cessna aircraft with which I am familiar have single
slotted Fowler flaps. I have no idea how much performance you would
gain with double slotted Fowler flaps, and doubt that they would add
much weight; but believe that they would be a real pain in the neck to
build s the dimensions would need to be held closely in order for the
slots to have the correct proportions and the additional surfaces would
need to be finished.
Peter
Old July 26th 03, 01:08 AM
Big John
Flew em both. Worked fine.
Big John
On Fri, 25 Jul 2003 18:56:13 GMT, "Capt. Doug"
Philippe Vessaire wrote in message The slat MUST be built with mecanical
For the proper way to design slats, study the Sabreliner and the
Helio-Courier, neither of which is mechanically interconnected, or French.
D. (couldn't resist)
Old July 26th 03, 01:34 AM
clare @ snyder.on .ca
On Fri, 25 Jul 2003 23:27:14 GMT, Richard Lamb
WHAT actuators, Bob.
Most slats are deployed by aerodynamic forces,
not mechanical ones...
The Pegazair has automatic, independent slats. Because they are
controlled by lift, or lack thereof, they only come out when needed,
and sometimes they are only needed on one side.
It is a Dedalius (spelling?) style wing - also supplied as an add-on
to the CH701, and, I believe, other planes. No springs either.
custom made.
maximum expected.
Bob K.
Old July 26th 03, 03:33 AM
Richard Lamb
When the slats pop out on the Helio Courier based here,
it sounds like a shotgun. Loud BOOM!
There is indeed a lot of force here...
