In some occations it might be handy to use the cellphone in the airplane,
but the noisy atmosphere makes it somewhat difficult. I found an ad for an interesting "box" that connects a handphone to the intercom/headset allowing for better quality communications. http://www.flightcell.co.nz/flightce...flighcell.html Any experience out there regarding the Flightcell IV, that also allows for plugin of a handheld comm-set that might be handy in case of a radio failure? I am also aware that some of the newer ANR headsets allows for plug-in of cellphones. -- Christian ENZV |
$349 is a ridiculous price. I have the cellset. www.cellset.com Many
headsets now have an interface built right in. Christian wrote: In some occations it might be handy to use the cellphone in the airplane, but the noisy atmosphere makes it somewhat difficult. I found an ad for an interesting "box" that connects a handphone to the intercom/headset allowing for better quality communications. http://www.flightcell.co.nz/flightce...flighcell.html Any experience out there regarding the Flightcell IV, that also allows for plugin of a handheld comm-set that might be handy in case of a radio failure? I am also aware that some of the newer ANR headsets allows for plug-in of cellphones. |
Christian wrote:
I am also aware that some of the newer ANR headsets allows for plug-in of cellphones. This is the version I have experience with and it works quite well. One of my headsets has a cell phone adapter that I've used for picking up clearances and such. -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
I have a Lightspeed 30 3G which has a cell phone adapter built in.
I use it to pick up clearances and it works like a charm. Pete "Christian" wrote in message ... In some occations it might be handy to use the cellphone in the airplane, but the noisy atmosphere makes it somewhat difficult. I found an ad for an interesting "box" that connects a handphone to the intercom/headset allowing for better quality communications. http://www.flightcell.co.nz/flightce...flighcell.html Any experience out there regarding the Flightcell IV, that also allows for plugin of a handheld comm-set that might be handy in case of a radio failure? I am also aware that some of the newer ANR headsets allows for plug-in of cellphones. -- Christian ENZV |
You'd probably think differently if you knew what it cost to make it.
"Newps" wrote in message ... $349 is a ridiculous price. I have the cellset. www.cellset.com Many headsets now have an interface built right in. Christian wrote: In some occations it might be handy to use the cellphone in the airplane, but the noisy atmosphere makes it somewhat difficult. I found an ad for an interesting "box" that connects a handphone to the intercom/headset allowing for better quality communications. http://www.flightcell.co.nz/flightce...flighcell.html Any experience out there regarding the Flightcell IV, that also allows for plugin of a handheld comm-set that might be handy in case of a radio failure? I am also aware that some of the newer ANR headsets allows for plug-in of cellphones. |
You might be interested to know of flightcells entry-level product -
Flightcell2Go at $199 USD. "Christian" wrote in message ... In some occations it might be handy to use the cellphone in the airplane, but the noisy atmosphere makes it somewhat difficult. I found an ad for an interesting "box" that connects a handphone to the intercom/headset allowing for better quality communications. http://www.flightcell.co.nz/flightce...flighcell.html Any experience out there regarding the Flightcell IV, that also allows for plugin of a handheld comm-set that might be handy in case of a radio failure? I am also aware that some of the newer ANR headsets allows for plug-in of cellphones. -- Christian ENZV |
![]() "Cockpit Colin" wrote in message ... You'd probably think differently if you knew what it cost to make it. Ohh don't go there, I have reverse engineered many electronics devices in my 9 years being an E.E. I know the cost of electronics devices quality of PCB's and components & workmanship. None of the cell phone adapters would cost over $5.00ea to have mass produced and that is a high estimate using good parts with tolerances of 1-2% not 5 to 10% and for $300.00 I could build 20 of them using US supply houses. |
Um - actually I work with the chap runs the flightcell company, and have
been privvy to a lot of "behind the scenes" info. I'm afraid to say, you couldn't be further from the truth. Additionally, if you can supply all the components for less than $5 (same quality) I'm sure we could get you a 100% margin and make you a very rich person. It's not just the components - it's the research and development - the marketing - the wages - the rent - hell, even a bit of profit (and not as much as you're thinking). The mould for the case alone cost over $5,000 USD. Interestingly the USAF took a look at them and have bought over 1200 of them, with more to follow. Only cell phone interface endorsed by Bose too. (PS: I've been involved in electronics / avionics for 26 years) Just my 10c worth. "NW_PILOT" wrote in message ... "Cockpit Colin" wrote in message ... You'd probably think differently if you knew what it cost to make it. Ohh don't go there, I have reverse engineered many electronics devices in my 9 years being an E.E. I know the cost of electronics devices quality of PCB's and components & workmanship. None of the cell phone adapters would cost over $5.00ea to have mass produced and that is a high estimate using good parts with tolerances of 1-2% not 5 to 10% and for $300.00 I could build 20 of them using US supply houses. |
Cockpit,
You'd probably think differently if you knew what it cost to make it. You're kidding, right? If one company can produce a full ANR headset with a cell phone adapter for what another company charges for the cell phone adapter alone, one of the two is ripping its clients off. -- Thomas Borchert (EDDH) |
Christian,
I am also aware that some of the newer ANR headsets allows for plug-in of cellphones. Yep. Works real well with all of the Lightspeed headsets. And the boxes cost more than many of the Lightspeed models. -- Thomas Borchert (EDDH) |
Peltor Headset Experience | Mark T. Mueller | Instrument Flight Rules | 7 | June 6th 04 07:40 PM |
Headset music | Neil Bratney | Piloting | 23 | April 27th 04 12:59 PM |
Bose makes good on my wife's headset. | Kyler Laird | General Aviation | 3 | March 10th 04 02:08 PM |
Bose makes good on my wife's headset. | Kyler Laird | Piloting | 3 | March 10th 04 02:08 PM |
Headset wanted | Mike Cunningham | Aviation Marketplace | 0 | August 25th 03 01:26 AM |
