#41
On Sat, 06 Nov 2004 22:22:22 GMT, Mike Rhodes
wrote: A banked aircraft will not turn if, and only if, the wing is not generating lift. A wing will not generate lift if its angle of attack is so controlled by the horizontal stabilizer. I was not quite right with the "if and only if". Of course the rudder can also stop the turn, as in a side-slip. And the side-slip Peter mentioned is what pushes the nose around in the turn by its push on vertical stabilizer. I did not point directly at the vert stabilizer as Peter did in his reply. Because the banked aircraft is aligned less with gravity, it would then want to accelerate 'up', as 'up' is relative to the aircraft. But this would immediately change the angle-of-attack of the both the wing and the horizontal stab. So the wing loses some lift, while the horizontal stab increases its already downward push. This would tend to push the nose 'up', and restore the angle of attack of the wing. The turn is a relatively slow process (the pilot has time to make adjustments), and maybe the mechanics are not so simple as I think my post implied. --Mike |
#42
On Mon, 08 Nov 2004 19:30:24 GMT, Mike Rhodes
wrote: On Sat, 06 Nov 2004 22:22:22 GMT, Mike Rhodes wrote: Because the banked aircraft is aligned less with gravity, it would then want to accelerate 'up', as 'up' is relative to the aircraft. But this would immediately change the angle-of-attack of the both the wing and the horizontal stab. So the wing loses some lift, while the horizontal stab increases its already downward push. This would tend to push the nose 'up', and restore the angle of attack of the wing. Oops. I got this wrong. If both wing and horizontal stab are pushed down then the net effect is no change in angle of attack. --Mike |
#43
Ramapriya wrote:
Hi guys, Unlike the elevators and rudder that change an aircraft's pitch and yaw with no other secondary effect, None of the controls really operate without producing secondary effects. Rudder-only will produce Yaw, of course, but the yaw accelerates one wing forward and one wing back, which changes the airflow over the wings - the forward-accelerating wing produces additional lift, the aft-accellerating wing less, producing a roll. Its a sloppy turn, but it can be done. Elevator changes the pitch, which typically will affect the angle of attack and thus the lift produced by the wings, and may produce a climb or descent which will affect the airspeed, ... why does the banking of wings by the use of ailerons not just roll an aircraft but also produces a turn (yaw)? Logically, one would expect an aircraft to keep going straight ahead even if the pilot banked the aircraft left or right. Where does the turning effect come from? The wings produce Lift. In straight and level flight, the lift vector is straight up. When you bank, you change the direction of the lift vector - the bank introduces a lateral component that accelerates the aircraft in that direction - the turn. The rudder is used in this case only to counteract any adverse yaw produced by the ailerons in commanding the bank. And the 'tail feathers' (vertical stabilizer) tend to keep the aircraft aligned with the airflow. Is there a website you know of that can teach me such basics, without having to bug you? ![]() There are many. But try: http://www.av8n.com/how/ |
#44
![]() Yes, my understanding is that a bank causes an airplane to slip, which then causes it to weathervane into the wind. Why do you ask? Is there something I am missing? "Hilton" wrote in news:lUGjd.8614$O11.3080 @newsread3.news.pas.earthlink.net: Andrew, Andrew Sarangan wrote: Hilton wrote: Andrew Sarangan wrote: Sure, but that still does not explain why the airplane turns. A horizontal component of lift will make the airplane side-slip, not turn. It is the stability (weathervane effect) that makes the airplane turn. By definition, the 'weathervane effect' occurs because air exerts more pressure on one side of the object (aircraft) than the other - same definition as slipping. Therefore, are you are asserting that an aircraft turns because it is slipping? More over, it will only turn if it is slipping? Hilton Think of the space shuttle. If you fire rockets horizontal to the flight path, the shuttle will slide sideways. It will not turn the nose towards the direction of travel. An airplane turns because it wants to point the nose into the relative wind. I understand that, but you never answered my question: "Are you asserting that an aircraft turns because it is slipping (weathervaning)?" Hilton Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
#45
That is exatly what I said in a previous post on this thread. A bank causes
an airplane to side-slip, which in turn makes it point into the wind. soxinbox wrote in . 165: I don't think anyone has hit on what is really going on here. The explanations about the sideways force created by lift when the AC is banked cause it to move ( accelerate ) to the side, but not rotate. The dihedral wing explanation doesn't work either, because the raised wing's horizontal force is applied aft of the CG, thus causing rotation in the opposite direction of the turn. The major reason that a plane rotates about the vertical axis during a turn is wind vaning. You bank the plane, the lift is broken into horizontal and vertical components. The horizontal force causes the plane to accelerate to the side, but not rotate as others have stated. Now with the plane picking up speed in the lateral direction, the relative wind is now coming from one side of the plane, a forward quartering headwind! As anyone who has taxied on a windy day knows, planes have a natural tendency to face into the wind. This is caused by the big wind vane we call a tail. This rotates the plane into the wind. The relative wind is thus always leading the plane by a few degrees, causing a continued rotation. And as a side benefit, the horizontal acceleration is countered by the centripetal force of the turn, so we don't continue to accelerate to faster and faster horizontal speeds. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
#46
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Phoenix AIM-54A (QUESTION) | Krztalizer | Naval Aviation | 10 | February 23rd 04 07:22 AM |
Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 09:40 PM |
Question about Question 4488 | Paul@Rasdoc.com | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Basic Stupid Newbie Questions... | John Penta | Military Aviation | 5 | September 19th 03 05:23 PM |
