iPod & Headset?
Old November 12th 04, 08:22 AM
Thomas Borchert
Jens,
Best Headset
ever, and I've tried a lot
Well, be that as it may, but they just seem to be lacking a music
input, don't they? Which the Lightspeeds happen to have, for way less
money, don't they?
gd&r
Thomas Borchert (EDDH)
Old November 12th 04, 01:23 PM
tscottme
"Jens Krueger" wrote in message
Anybody know of a "box", which I could you use to hook my iPod to my
Headset? Earbuds plus Headset is too much cable hanging around... ;-)
Cheers,
jens
The easiest thing to do is put on your Ipod earbuds and then put your
headset on over the earbuds. The headset blocks out the ambient noise and
the earbuds provide the tunes. Cost, zero.
Scott
There already is a UN approved two-state solution in Palestine, it's called
Israel and Jordan.
Old November 12th 04, 07:57 PM
John Galban
Thomas Borchert wrote in message ...
Are we talking about the Garmin 340 audio panel? That's a known problem
- and there's a work-around and a fic by Garmin. If you're interested
in the details, I'll provide them.
No. I've tried this on Softcomm and Flightcom portable intercoms
and a Flightcom 2 place panel mount. I've also tried using several
audio sources. The only luck I've had is with older devices that were
originally designed to drive a real speaker. It's really looking like
a power (output wattage) issue.
Old November 12th 04, 10:06 PM
Maule Driver
I've got a Garmin 340 and plug my iPod in. Works like a charm. Better than
I would have expected. Listening thru a set of Peltor ANRs (which I would
not recommend - does ANR slowly wear off?!!!)
"Thomas Borchert" wrote in message
John,
When
I plug one of these into the input jack of the intercomm, I have to
crank the volume on the player up to maximum and it's barely audible
over the background noise in flight.
Also, yes, this can be a problem.
Old November 12th 04, 10:31 PM
Blueskies
"John Galban" wrote in message om...
I think it is an impedance match issue...
Old November 13th 04, 03:10 AM
Morgans
om...
How about cannibalizing one of those stand alone powered speakers that are
supposed to hook onto the earphone jack of a walkman? Toss the speakers,
put on an output jack, get a small experiment enclosure from rat shack, and
let the inside goodies drive the intercom. Should be do-able for about 25
or 30 bucks.
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.794 / Virus Database: 538 - Release Date: 11/10/2004
Old November 13th 04, 09:42 AM
Thomas Borchert
John,
ok. It is an impedance mismatch. Here's what Dave Katz posted two years
ago. I did this using a photo film box, and it works real well.
If you have any
soldering skills, pick up a couple of 8/1000 ohm matching transformers
and a male/male mini-plug cable from Radio Shack. It's a minor
impedance mismatch problem. I put one together for my Cirrus and it
boosts volume by more than enough, and it's completely passive so
there's no batteries or other stuff. One of my fellow Cirrus brethren
came up with a great packaging hack--a small prescription pill bottle
is big enough to hold everything. Drill a hole in the bottom and in
the lid, tie knots for strain relief, and it's all quite tidy, if a
mite funny looking.
One transformer for each side if you want stereo. The low impedance
side
(red/white) goes to the audio device, and the high impedance side
(green/blue) goes to the intercom. You can snip off the black center
tap on the high side. I hooked the white and green leads to the
common (sleeve) connections on each side, but I don't suppose that
it matters so long as you're consistent (so you don't phase-reverse
one side.)
They were the only transformers for sale at the Radio Shack at which I
got mine. They may just be called "audio transformers" or somesuch,
but
it'll say 8 ohm/1000 ohm on the packaging.
Old November 15th 04, 01:01 AM
Royce Brown
"tscottme" writes:
I guess that would work if you never used flight following or knew no one
else would be calling you.
Distortion in headset - advice wanted Andrew Sarangan Piloting 3 August 21st 04 02:15 PM
Headset music Neil Bratney Piloting 23 April 27th 04 12:59 PM
Bose makes good on my wife's headset. Kyler Laird General Aviation 3 March 10th 04 02:08 PM
Bose makes good on my wife's headset. Kyler Laird Piloting 3 March 10th 04 02:08 PM
Music input into intercom and IPOD Paul Tomblin Owning 1 August 7th 03 07:03 PM
