Garmin 296 - Fuel Timer
Old November 17th 04, 12:47 AM
Cockpit Colin
Default Garmin 296 - Fuel Timer
Hi Folks,
Can someone with a Garmin 296 please tell me how the fuel timer works -
whenever I set it on the gound it keeps going back to zero - I can't figure
the thing out!
Many thanks,
CC
Old November 17th 04, 05:23 PM
Jon Woellhaf
Please be a bit more specific.
"Cockpit Colin" wrote in message
Hi Folks,
figure
the thing out!
Many thanks,
CC
Old November 17th 04, 09:26 PM
Cockpit Colin
OK ...
.... I go into SETUP - flick to the TIMERS tab - Move down to FUEL TIMER and
select ON.
I move accross to the next field and set it for something like 4 hours.
1 second later (on the next screen refresh) it goes back to zero.
Basic problem is I don't understand how it's supposed to work - I would have
thought that one would set it for some value (say 30 minutes) at which point
it would count backwards to zero - display an alart message - reset to 30
minuts - and start counting down. Possibly starting when the GPS detects
motion of the aircraft.
If I set the timer to off I can get it to hold a setting - but as soon as I
turn it to on it goes right to zero.
Cheers,
CC
"Jon Woellhaf" wrote in message
news:%NLmd.108464$R05.104729@attbi_s53...
Hi Folks,
figure
the thing out!
Many thanks,
CC
Old November 17th 04, 10:07 PM
FLYFisher
"Cockpit Colin" wrote in message ...
Hi Folks,
the thing out!
Many thanks,
CC
Colin,
It does not sound like you are pressing enter after you have entered
the time. If you press the rocker key to the left twice, this will
clear the values that you have input into the field.
The timer will only start once you have reached 30knots, according to
Garmin.
Old November 18th 04, 04:29 AM
Cockpit Colin
Thanks for that - but still no joy
"FLYFisher" wrote in message
om...
Hi Folks,
figure
the thing out!
Many thanks,
CC
Colin,
Garmin.
Old November 19th 04, 11:21 AM
Cub Driver
Have you established an aircraft profile with a burn rate, and is that
the active aircraft profile when you set the timer?
(I've never used this feature, since my watch work better: two hours
and I look for a runway!)
all the best -- Dan Ford
email: (put Cubdriver in subject line)
Warbird's Forum
www.warbirdforum.com
Piper Cub Forum www.pipercubforum.com
the blog www.danford.net
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. Nathan Young Piloting 4 June 14th 04 06:13 PM
faith in the fuel delivery infrastructure Chris Hoffmann Piloting 12 April 3rd 04 01:55 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
