1. In the other very well-discussed thread on the turning effect
produced during banking, it was pretty much clear that yaw is almost inevitable during a bank. So what use the rudder at all? Or even the tail - surely not merely to house the elevators?? 2. Is there any advantage or disadvantage in having engines attached to the fuselage near the tail section vis-a-vis under the wings? I'd imagine banking would feel a lot lighter and enjoyable if the engines weren't there ![]() Education welcome, even if the Qs aren't ![]() Ramapriya |
"Ramapriya" wrote in message om... 1. In the other very well-discussed thread on the turning effect produced during banking, it was pretty much clear that yaw is almost inevitable during a bank. So what use the rudder at all? Or even the tail - surely not merely to house the elevators?? "Stick and Rudder" by Langewiesche will answer all of your questions about how planes fly and how to use that knowledge to fly them. It's still very much in print and can be purchased from Amazon. I strongly suggest reading this before spending too much time readign newsgroup threads. Oh, and it is a very fast and easy read. * There are definitely still debates about whether Langewiesche got this or that detail quite right, and whether what we know as "conventional" aircraft design is truly optimal, but you won't go wrong if you start there. If you don't learn the "conventional wisdom" first I think it's a lot more likely you'll get confused in details that are not really critical. 2. Is there any advantage or disadvantage in having engines attached to the fuselage near the tail section vis-a-vis under the wings? I'd imagine banking would feel a lot lighter and enjoyable if the engines weren't there ![]() In every decision in aviation there are both pluses and minuses. Having engines closer to the centerline reduces turning effect if one engine quits. Also allows for a cleaner wing design (potentially) as you can build the wing without worrying about supporting the weight/thrust of the engine or all the plumbing for it. Also, on smaller planes ground clearance is an issue, and there often isn't enough room under the wing to hang an engine. On the negative, engines in the rear will eat into cabin space. I also suspect that there are weight distribution issues or some such as you will notice that above a certain size, big transports have always mounted their engines under the wings. Also the new prototype HondaJet (6-8 seat bizjet) does something novel and mounts the engines on pylons *above* the wings. This provides ground clearance but also allows them to get more usable cabin space. -cwk. |
On Wed, 17 Nov 2004 16:20:57 GMT, C Kingsbury wrote:
On the negative, engines in the rear will eat into cabin space. I also suspect that there are weight distribution issues or some such as you will notice that above a certain size, big transports have always mounted their engines under the wings. Also the new prototype HondaJet (6-8 seat bizjet) does something novel and mounts the engines on pylons *above* the wings. This provides ground clearance but also allows them to get more usable cabin space. Just a nit, but above-wing mounting is not really novel. Check out http://www.airliners.net/search/phot...nct_entry=true for example. There were also a number of early aircraft that used above-wing mounting, particularly in seaplanes. - Rich |
Just a nit, but above-wing mounting is not really novel. Check out http://www.airliners.net/search/phot...nct_entry=true for example. That is one butt ugly aircraft, IMHO. :-o -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.797 / Virus Database: 541 - Release Date: 11/15/2004 |
Here to there wrote:
Just a nit, but above-wing mounting is not really novel. Check out http://www.airliners.net/search/phot...nct_entry=true Is it just or doesn't it look like this one http://www.airliners.net/open.file/559166/L/ is missing it's right aileron? -- Chris W Gift Giving Made Easy Get the gifts you want & give the gifts they want this holiday season http://thewishzone.com "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -- Benjamin Franklin, 1759 Historical Review of Pennsylvania |
Chris W wrote: Is it just or doesn't it look like this one http://www.airliners.net/open.file/559166/L/ is missing it's right aileron? It's an illusion. The flaps extend past the ailerons on that plane. You can't see the flaps on the left wing because the fuselage is in the way. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
| F-16 Fires on Elementary School | Dean Wilkinson | Piloting | 21 | November 6th 04 04:52 PM |
