Argh! Last week (about nine shipping days ago) I ordered both approach
charts for lower Ontario, Canada, and a low altitude IFR en route chart from Pilotshop.com in lieu of my upcoming flight to Toronto from NY state. This afternoon, a mere day and a half before my trip, Pilotshop sends me an email stating that they are all out of these charts due to the approaching Nov 25th issuance of the new charts. Now, that's a way to win a new customer's repeat business. ![]() With one more full day until my trip, there is no time to order a set of charts. The local FBOs do not carry Canadian charts. I have a current Detroit VFR sectional for the area and I can print an IFR en route chart from Jepp's FLightStar software, but I do not have a good airport diagram, nor do I have any approach plates. At this point, the weather is looking to be good VFR, but I would like to have an airport diagram with frequencies for CYTZ. Searching the web turned up nothing. If anyone has a scanned image of the diagram that could be sent via email, I would be *most* indebted. A working email for me is (remove the X). -- Peter |
In a previous article, Peter R. said:
At this point, the weather is looking to be good VFR, but I would like to have an airport diagram with frequencies for CYTZ. Searching the web http://www.torontoport.com/PortAutho...pilot_info.asp Click on "Communications and Navigation" for frequencies. -- Paul Tomblin http://xcski.com/blogs/pt/ Real Time, adj.: Here and now, as opposed to fake time, which only occurs there and then. |
"Paul Tomblin" wrote in message ... In a previous article, Peter R. said: At this point, the weather is looking to be good VFR, but I would like to have an airport diagram with frequencies for CYTZ. Searching the web http://www.torontoport.com/PortAutho...pilot_info.asp Click on "Communications and Navigation" for frequencies. There is one little piece of outdated information on their "flight planning" page. If you need/want to talk to an FSS, it is no longer at Toronto/Buttonville as shown on that page... it is now at London; you would call "London Radio". The same FSS frequencies should still work. The 126.7 is the "in-the-air" frequency, so the "above 3000" qualifier may be valid, but the 123.15 is supposed to work when you are on the ground at the airport. And those Buttonville phone numbers are useless, also. To reach FSS by phone, just call 1-866-WX BRIEF |
Icebound ) wrote:
There is one little piece of outdated information on their "flight planning" page. If you need/want to talk to an FSS, it is no longer at Toronto/Buttonville as shown on that page... it is now at London; you would call "London Radio". The same FSS frequencies should still work. The 126.7 is the "in-the-air" frequency, so the "above 3000" qualifier may be valid, but the 123.15 is supposed to work when you are on the ground at the airport. And those Buttonville phone numbers are useless, also. To reach FSS by phone, just call 1-866-WX BRIEF So, do I understand the information on that page correctly that to activate my IFR flight plan, I would have to call FSS rather than speak to the ground controller? Or does the following quote refer to VFR flight plans? "Pilots are requested to open & close flight plans with Toronto/Buttonville FSS on 126.7 or 123.15 above 3000 AGL or by phone." -- Peter |
Paul Tomblin ) wrote:
http://www.torontoport.com/PortAutho...pilot_info.asp Click on "Communications and Navigation" for frequencies. Thanks, Paul. Unfortunately, the airport diagram on that page didn't print very well. I did print off the frequencies, though. -- Peter |
"Peter R." wrote in message ... Icebound ) wrote: There is one little piece of outdated information on their "flight planning" page. If you need/want to talk to an FSS, it is no longer at Toronto/Buttonville as shown on that page... it is now at London; you would call "London Radio". The same FSS frequencies should still work. The 126.7 is the "in-the-air" frequency, so the "above 3000" qualifier may be valid, but the 123.15 is supposed to work when you are on the ground at the airport. And those Buttonville phone numbers are useless, also. To reach FSS by phone, just call 1-866-WX BRIEF So, do I understand the information on that page correctly that to activate my IFR flight plan, I would have to call FSS rather than speak to the ground controller? Or does the following quote refer to VFR flight plans? "Pilots are requested to open & close flight plans with Toronto/Buttonville FSS on 126.7 or 123.15 above 3000 AGL or by phone." It refers to VFR plans for sure, but it could be that they request closing through FSS after landing as being more convenient for everyone all around (see my previous post about 123.15). In the google archives, there are a lot of posters who claim Canadian ATC will open/close IFR plans at towered airports. You could just put in the "close" request to the ground controller and the worst that will happen is he will direct you to the FSS. In case it wasn't clear, by the way, that FSS "WX BRIEF" number is for filing FP, as well as weather info. |
Peter R. wrote:
Doesn't AOPA online have that stuff? |
Schmoe ) wrote:
Peter R. wrote: Doesn't AOPA online have that stuff? Not for Canada they don't. I even called AOPA to see if someone there could fax me a plate or two from their personal collection. No one had one and there probably is some crazy liability reason why they would not be allowed to even if they did have one. Now, Jeppesen can fax approach plates for Canadian at US $55 for the fax service, $10 for an airport, and $5 per plate, for a total of $65 for one ILS approach plate. No thanks. Just this morning, someone from this group was going to send me some from his collection, but I just received a call from the manager of my local flight school. He was able to find a pilot with current Canadian plates that he will let me borrow for the day. -- Peter |
"Icebound" wrote in message ... "Schmoe" wrote in message et... Peter R. wrote: Doesn't AOPA online have that stuff? Yeah, Canadian plates are only sold as the "Canada Air Pilot" Series through...snip... Anyway, they always ask for feedback, so you can ask (or suggest) about their on-line policy (or lack of it) at:...snip... Damn... hit enter just as I realized that I didn't scramble the email address. But it is all over their public website anyway, so I am sure the spammers already have it.... Damn... |
| Thread Tools | |
| Display Modes | |
| GA Airport center for Charley relief | Bob Chilcoat | Piloting | 4 | August 19th 04 05:04 PM |
| Bush's Attempt to Usurp the Constitution | WalterM140 | Military Aviation | 20 | July 2nd 04 05:09 PM |
| N94 Airport may expand into mobile home community, locals supportive | William Summers | Piloting | 0 | March 18th 04 04:03 AM |
| Rules on what can be in a hangar | Brett Justus | Owning | 13 | February 27th 04 06:35 PM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
