Wanted: Continental engines guru
Old August 9th 04, 09:58 AM
Philippe
Default Wanted: Continental engines guru
Hello,
On my Gardan Minicab F-PRAZ, I have a A65-8F.
I have some question about these engines (only for experimental use)
1- Is the rear case fuel pump serviceable, or did I need a new rear case for
new oil pump?
2-May I bolt any cylinder P/N on any crankcase? for exemple a C90 cylinder
on a A65 crankcase.
3-May I bolt any exaust assy on any engine?
4- How difficult is it to drill the bigger oil hole for A65 to A75 "upgrade"
rod? Do I need a boring machine or only a drill press?
May I download somewere parts catalog?
thanks
Philippe Vessaire Ò¿Ó¬
Old August 9th 04, 03:21 PM
new oil pump?
on a A65 crankcase.
We've got a pretty good Continental guru, Harry Fenton, with the Fly Baby
group. I've collected a lot of his postings at:
http://www.bowersflybaby.com/tech/fenton.htm
He's got a *lot* of A-65 information there. As far as the cylinder
interchange is concerted, Harry says "The C-85/O-200 cylinders have a
bigger bore than the A-65, the bolt pattern is the same. The cylinder
holes in the A-65 case would have to be opened up to accept larger bore
cylinders, but that could be done with little trouble."
I've got a lot of other small Continental information on the main Fly Baby
engine page:
http://www.bowersflybaby.com/tech/engines.htm
Scroll down a bit, and you'll see an online version of the Continental A&C
Engine Parts Interchangeability List. This will let you know what parts
from the bigger engines can be bolted directly to your A-65.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
