#21
![]() "CV" wrote in message ... Dave Stadt wrote: The leading cause of fatal accidents is maneuvering flight at 30%. The second leading cause is takeoff and climb at 18%. Third is weather related Takeoff and climb is not a cause of accident. Perhaps you mean that 18% occur during takeoff and climb, which is something very different than cause. Simplistically we could claim that takeoff causes 100% of accidents, since if you hadn't taken off there would have been no accident. This is like claiming getting out of bed in the morning as the cause for 100% of traffic accidents (and aviation and most other accidents for that matter). Cheers CV Go read the Nall report then come back once you have educated yourself. If you don't believe you can get killed during the takeoff and climb portion of flight you should stay far away from airports. |
![]() Happy Dog wrote: "zatatime" wrote in message news: On Wed, 01 Dec 2004 03:59:48 GMT, tony roberts wrote: BUT: Most light aircraft accidents are caused through continued flight into IFR (read - don't even attempt to fly there there) weather. To be more clear: The accidents of this type are for VFR (good weather) pilots without training on how to effectively operate an aircraft in IFR (bad weather) conditions. Not just VFR pilots. Happens to a surprising number if instrument rated pilots (flying VFR) as well. I'll try to find some stats. Here's what you'll find...Instrument rated pilots are far more likely to get into farming by scud running than VFR only pilots. |
"Dave Stadt" wrote in message
om... Go read the Nall report then come back once you have educated yourself. If you don't believe you can get killed during the takeoff and climb portion of flight you should stay far away from airports. CV was simply pointing out that takeoffs and climbs are not CAUSES of accidents. And they aren't. I have no idea why you insist on claiming that they are, or why you insist on berating someone that simply pointed out the fact that they are not. But the fact remains that none of the things you described (maneuvering flight, takeoff and climb, weather, etc.) are CAUSES of accidents. They are certainly ways to describe categories of accidents (though, inasmuch as they are not orthogonal, I've always felt the chosen categories are a little odd...in what category does an accident that occurred during maneuvering after takeoff in poor weather belong?), but they are NOT causes. Pilot error and mechanical failure are examples of CAUSES, and they can CAUSE an accident during any of the kinds of flight you mention. Pete |
#24
![]() Andrew Gideon wrote: That statement was made during an ASF presentation I attended a while ago. It puzzled me. Why would a IR pilot fly VFR into IMC? I'm not sure myself, but I do remember an incident that was presented in a safety videotape. The pilot involved intended an IFR flight from Frederick, MD to the west. She was delayed in a business meeting and discovered when she got to the airport that her flight plan had expired. Rather than file a new one, she took off VFR under low ceilings intending to file in the air. Frederick is under the control of the Baltimore ATC. The ground rises to the west. Baltimore wouldn't clear her until they could pick her up on radar, and you have to get pretty high for them to do that in that area. While trying to get clearance and climbing to avoid terrain, the windshield went opaque. She came out of the clouds in a spiral at over a 70 degree bank, recovered a few hundred feet above the ground, and returned to Frederick to file a flight plan. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
#25
The typical aircraft accident rate is comparable to the typical
motorcycle accident rate Comparisons like that are tricky. Is that accidents per hour, or per mile? Those two ways would give drasticaly different answers. But I recall a discussion of that topic in Flying mag, years ago. In a subsequent issue, a letter to the editor from an insurance adjuster said, "The only more dangerous way to get from point A to Point B than by motorcycle is by being shot from a cannon." However, there's an important difference; bikers are at the mercy of automobile drivers, who open doors in their path, pull out in front of them, etc. Pilots, however, are rarely killed by someone else. So a careful, "unbold" pilot is less likely to become a statistic than an equally careful biker. vince norris |
#26
![]() "G.R. Patterson III" wrote in message ... Andrew Gideon wrote: That statement was made during an ASF presentation I attended a while ago. It puzzled me. Why would a IR pilot fly VFR into IMC? I'm not sure myself, but I do remember an incident that was presented in a safety videotape. The pilot involved intended an IFR flight from Frederick, MD to the west. She was delayed in a business meeting and discovered when she got to the airport that her flight plan had expired. Rather than file a new one, she took off VFR under low ceilings intending to file in the air. Frederick is under the control of the Baltimore ATC. The ground rises to the west. Baltimore wouldn't clear her until they could pick her up on radar, and you have to get pretty high for them to do that in that area. While trying to get clearance and climbing to avoid terrain, the windshield went opaque. She came out of the clouds in a spiral at over a 70 degree bank, recovered a few hundred feet above the ground, and returned to Frederick to file a flight plan. She had originally filed a IFR flight pan, but lost control in the clouds? Certainly the flight plan was a small part of the problem. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#27
![]() "Andrew Gideon" wrote in message online.com... C Kingsbury wrote: On the other, it means you're much more likely to encounter weather beyond your abilities. What was said during the ASF presentation is that this is a problem not of pilots under IFR encountering weather but IR pilots continuing VFR into IMC. Icing? T-Storms? -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
#28
Newps wrote: BUT: Most light aircraft accidents are caused through continued flight into IFR (read - don't even attempt to fly there there) weather. To be more clear: The accidents of this type are for VFR (good weather) pilots without training on how to effectively operate an aircraft in IFR (bad weather) conditions. Not just VFR pilots. Happens to a surprising number if instrument rated pilots (flying VFR) as well. I'll try to find some stats. Here's what you'll find...Instrument rated pilots are far more likely to get into farming by scud running than VFR only pilots. Which has nothing to do with the rating, but rather is a result of pilot stupidity. -- Bob Noel |
#29
On Wed, 01 Dec 2004 05:05:47 GMT, "Dave Stadt" On Wed, 01 Dec 2004 03:59:48 GMT, tony roberts wrote: BUT: Most light aircraft accidents are caused through continued flight into IFR (read - don't even attempt to fly there there) weather. To be more clear: The accidents of this type are for VFR (good weather) pilots without training on how to effectively operate an aircraft in IFR (bad weather) conditions. For June's understanding, these are people that only have the license your husband got first. Since he is now working toward his instrument ticket these statistics are greatly reduced. Just don't want you to think that the added training he is going for makes this far more dangerous. It will actually make him safer overall. I don't believe statistically IFR rated pilots have a better safety record. It is a false assumption. IFR pilot's have a better safety record in IFR conditions than VFR pilots do in IFR conditions, which is all I was trying to say. I may not have been perfectly clear. VFR pilots don't legally fly in IFR conditions. Your statement "To be more clear: The accidents of this type [continued illegal flight into IMC] are for VFR (good weather) pilots without training on how to effectively operate an aircraft in IFR (bad weather) conditions." is quite clear and substantially incorrect. moo |
#30
"Newps" wrote in message
Not just VFR pilots. Happens to a surprising number if instrument rated pilots (flying VFR) as well. I'll try to find some stats. Here's what you'll find...Instrument rated pilots are far more likely to get into farming by scud running than VFR only pilots. You got stats on this? All I've seen are stats on continued flight into IMC. moo |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Is Spooky safe to take downtown? | Henry J Cobb | Military Aviation | 17 | May 16th 04 04:23 AM |
An Algorithm for Defeating CAPS, or how the TSA will make us less safe | Aviv Hod | Piloting | 0 | January 14th 04 01:55 PM |
Fast Safe Plane | Charles Talleyrand | Piloting | 6 | December 30th 03 10:23 PM |
Four Nimitz Aviators Safe after | Otis Willie | Naval Aviation | 0 | July 28th 03 10:31 PM |
