#211
On Tue, 7 Dec 2004 06:26:57 -0600, "Dan Luke"
wrote: I've been parking my airplane under a shelter within a mile of Mobile Bay for five years. I never top up the tanks after a flight. In that time, I don't recall ever sumping a drop of water out of any of the drains. My tanks hold 32 gal. usable each. That would be Mobile Bay Alabama, right? How much change in temperature occurs overnight during the summers there? Here in New England, we can, and often do, see a 30 to 40 degree swing from the cold of night to the warmest part of the day. Corky Scott |
#212
wrote in :: I've been parking my airplane under a shelter within a mile of Mobile Bay for five years. I never top up the tanks after a flight. In that time, I don't recall ever sumping a drop of water out of any of the drains. That doesn't mean there is no water in your C-172RG's fuel system. Are there rubber bladders in its fuel tanks? As in the accident to which I included a link earlier in this message thread, an uncoordinated bank on approach could be enough to cause water trapped by the tanks folds to reach the carburetor (if so equipped) at an altitude insufficient to facilitate a recovery. |
#213
![]() "Larry Dighera" wrote in message ... On Mon, 06 Dec 2004 14:21:10 -0000, Dylan Smith wrote in :: I have never discovered water condensing in half-full fuel tanks. Perhaps the laws of physics have been repealed on the Isle of Man. :-) I guess that goes for Illinois also. Never a drop of water even with partial tanks sitting in all seasons. Why don't other types of vehicles have this supposed problem? Automobiles, boats, construction equipment? |
#214
![]() "Larry Dighera" wrote: I've been parking my airplane under a shelter within a mile of Mobile Bay for five years. I never top up the tanks after a flight. In that time, I don't recall ever sumping a drop of water out of any of the drains. That doesn't mean there is no water in your C-172RG's fuel system. If there has been, I haven't seen--or felt--any evidence of it. While small amounts might get stuck behind the fuel tank baffles, at least a *little* should have shown up in the samples in all that time, don't you think? After all, the airplane is parked in one of the most persistently humid locations in the U. S. Day after day, warm, wet afternoons are followed by mornings where the OAT falls to the dewpoint; you literally could wash my airplane many mornings without using a hose. Those are perfect conditions for the respiration/condensation scenario you fear, but they just don't seem to put any detectable amount of water in my tanks. Why is that? Are there rubber bladders in its fuel tanks? No. Now, how about some calculations showing that fuel tank respiration caused by daily temperature fluctuations can cause enough air changes to produce significant added condensation? [snip] -- Dan C-172RG at BFM |
#215
![]() "Dan Luke" wrote in message ... "Roger" wrote: Which is an old wives tale. The amount of water contained in 20-30 gallons of air is insignificant. Just let those tanks inhale and exhale a few times. They do that every morning and night so there is a *lot* more than 20-30 gallons involved. Another OWT, I'm afraid. Can you produce calculations to show how many air exchanges/week occur in a half-full 40-gal. tank given a daily temperature swing of 20 deg. F? [snip] I fly a Deb with about the same fuel capacity (not counting the tip tanks). With half tanks and the plane hangered for two weeks in the Spring, I drained over two full samplers of water out of one tank and a half out of the other. None out of the auxiliaries as they were full. Since you bring up anecdotal evidence, I'll chip in: I've been parking my airplane under a shelter within a mile of Mobile Bay for five years. I never top up the tanks after a flight. In that time, I don't recall ever sumping a drop of water out of any of the drains. My tanks hold 32 gal. usable each. [snip] -- Dan C172RG at BFM To add another data point, when I had a Turbo Lance parked outside at Santa Monica I never sumped a drop of water either. Same thing at Minden NV when it was outside there. Never a drop. Mike MU-2 |
#216
![]() "Corky Scott" wrote: I've been parking my airplane under a shelter within a mile of Mobile Bay for five years. I never top up the tanks after a flight. In that time, I don't recall ever sumping a drop of water out of any of the drains. My tanks hold 32 gal. usable each. That would be Mobile Bay Alabama, right? How much change in temperature occurs overnight during the summers there? 16-20 deg. F. It falls to the dewpoint most mornings in summer. Here in New England, we can, and often do, see a 30 to 40 degree swing from the cold of night to the warmest part of the day. Overnight dry bulb temperatures, assuming no weather change, typically do not fall below the dewpoint because of the heat of condensation. Therefore, if there is that much swing, the dewpoint is mighty low; there is damned little moisture in the air to begin with. Fuel tank respiration/condensation would still not be a problem. -- Dan C-172RG at BFM |
#217
Corky Scott wrote:
...... How much change in temperature occurs overnight during the summers there? Here in New England, we can, and often do, see a 30 to 40 degree swing from the cold of night to the warmest part of the day. Another data point, as long as we're throwing them out - I park my COZY MKIV outside at KFIT in MA. It lives outside throughout the whole year, and sees large temperature swings (daily, usually). The fuel tanks are integral with the strakes and made from fiberglass/epoxy - no bladders or "wrinkles" in the bottom to trap water. The drains are at the lowest point of the tanks. I rarely top up after a flight, and regularly leave the tanks 1/10 - 1/2 full. I always sump the tanks first thing when approaching the plane, before I move it or top it off. I have seen water in the tanks exactly once, and that was after a very heavy rain. I tightened the O-ring seal on the gas cap, and have never seen water again in over 1.5 years. The fiberglass is a good insulator, and as the temperature changes, I see lots of condensation on the OUTSIDE - if it was going to condense on the inside to any appreciable degree, it's got it's chance with the materials at hand. It doesn't do so. Personally, I think this condensation thing is a crock - if you've got water in your tanks, it's because your caps leak in the rain. -- Marc J. Zeitlin http://marc.zeitlin.home.comcast.net/ http://www.cozybuilders.org/ Copyright (c) 2004 |
#218
![]() "Marc J. Zeitlin" wrote: Another data point, as long as we're throwing them out - I park my COZY MKIV outside at KFIT in MA. One more. My Maule has been parked outside since I bought it in 1995. Since the venting system has no anti-syphon devices, it has a tendency to dump fuel if I park it with the tanks near full, so I have not done so since shortly after I bought it. I check the tanks during preflight, and, if they're down around 3/8, I fill it back up before flying. I'm based now at Lakewood, which is a few miles from an inlet of the Atlantic. I've never seen any water in the fuel. George Patterson The desire for safety stands against every great and noble enterprise. |
#219
![]() "Marc J. Zeitlin" wrote: Personally, I think this condensation thing is a crock... Couldn't have said it better, myself. -- Dan non-condensing C-172RG at BFM |
#220
On Tue, 07 Dec 2004 16:31:27 GMT, "G.R. Patterson III"
wrote: I'm based now at Lakewood Do you know if a mechanic named Bob Hayes is still down there? Just curious, z |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Baghdad airport safe to fly ?? | Nemo l'ancien | Military Aviation | 17 | April 9th 04 11:58 PM |
An Algorithm for Defeating CAPS, or how the TSA will make us less safe | Aviv Hod | Piloting | 0 | January 14th 04 01:55 PM |
Fast Safe Plane | Charles Talleyrand | Piloting | 6 | December 30th 03 10:23 PM |
Four Nimitz Aviators Safe after | Otis Willie | Naval Aviation | 0 | July 28th 03 10:31 PM |
