"Ramapriya" wrote in
ups.com: Andrew Sarangan wrote: a. is dependent on its airspeed, and is independent of its weight and weight distribution, and No, the stall AOA is independent of both airspeed and weight. Too confusing ![]() Getting back to basics, wings produce lift only when wind hits them, i.e. when the aircraft starts moving. This keeps increasing until the airspeed is adequate enough to produce a total lift that can levitate the aircraft. Since the angle of the wings can't be varied, ignoring flaps momentarily, I can't see how the stall AOA can be independent of airspeed. What then is 'stall speed' of an airplane? I see where you are getting the misconceptions from. You are thinking of the takeoff and landing as the start and end of flight. Just because an aircraft is on the ground does not mean it is stalled. Instead, picture an aircraft in mid flight. Then imagine what happens if you increase the angle of attack. The airflow over the wings will start to break up. This is the start of stall.This point is only related to the angle at which the airstream strikes the wing. Think of the AOA as the difference between the angle where the aircraft is pointing and where it is going. If stalling AOA is reached, adding engine power before the plane goes into a stall will prevent the stall by increasing airspeed, right? b. varies, for a given airspeed, with the air density (altitude) No the stall AOA does not vary with density. The stall AOA is determined by the shape of the wing. It is independent of weight and airspeed. However, the airspeed vs AOA relationship depends on a variety of factors, such as weight and density. This is why stall speed is somewhat a misleading quantity. AOA would be a better quantity. Unfortunately there is no direct way to measure the AOA in most aircraft, so we use the airspeed as an indirect indication of the AOA. Don't know much yet about this but I'm sure I saw the AOA indicated in an A320 cockpit recently. I thought the pitch itself indicated AOA but when the captain showed me the actual AOA reading, it varied by a wee from the aircraft's pitch. He had to punch some buttons into the flight computer to get the AOA reading. True, some of the larger aircraft and military jets have an AOA indicator. Most small aircraft do not have an AOA indicator. There is a good reason for this. In a large aircraft, the weight can vary substantially over its flight envelope. This will result in a large variation in stall speed. In a small aircraft, the stall speed variation is rather small, and a single stall speed can be used safely. Need to read up John Denker's book and the FAA material a lotttt more, I guess :\ No, you need to take a couple of flying lessons. |
True, some of the larger aircraft and military jets have an AOA indicator. Most small aircraft do not have an AOA indicator. There is a good reason for this. In a large aircraft, the weight can vary substantially over its flight envelope. This will result in a large variation in stall speed. In a small aircraft, the stall speed variation is rather small, and a single stall speed can be used safely. IMHO, there is no good reason for not having an AOA indicator on GA aircraft. Stall/spin is a leading cause of death among GA pilots and passengers. Best glide (potential emergency situation) is determined by AOA. Put an AOA sensor on GA planes with a hand that smacks the pilot on the head when the AOA approaches the critical AOA and a lot fewer people will die while having fun on the weekends. Hilton |
"Hilton" wrote in message
link.net... Andrew Sarangan wrote: True, some of the larger aircraft and military jets have an AOA indicator. Most small aircraft do not have an AOA indicator. There is a good reason for this. In a large aircraft, the weight can vary substantially over its flight envelope. This will result in a large variation in stall speed. In a small aircraft, the stall speed variation is rather small, and a single stall speed can be used safely. IMHO, there is no good reason for not having an AOA indicator on GA aircraft. Stall/spin is a leading cause of death among GA pilots and passengers. Best glide (potential emergency situation) is determined by AOA. Put an AOA sensor on GA planes with a hand that smacks the pilot on the head when the AOA approaches the critical AOA and a lot fewer people will die while having fun on the weekends. Hilton The April, 1973 (yeah, that's a while ago) issue of FLYING had a great article about Safe Flight's AOA indicator. Peter Garrison described it as "phenomenally useful", after flying a Beech Sierra equipped with one. |
passengers. Caused by the pilot not paying attention. Will having another instrument that he's not paying attention to really help? Best glide (potential emergency situation) is determined by AOA. A few knots either way isn't going to make much difference. Plus, how often is maximum glide range critical in an engine out situation? How closely is the pilot really maintaining one airspeed (or AOA) during an emergency? Put an AOA sensor on GA planes with a hand that smacks the pilot on the head Some studies I've seen have shown that pilots are often oblivious to warning horns and lights, though stick shakers are effective. My prediction: put an AOA indicator on every airplane in the fleet and you won't see much change in the accident rate due to stall spin. |
![]() Peter Duniho wrote: You understand Andrew correctly, but not stalling. Well, yes I do, but not that late at night or with that much "Christmas cheer", obviously. Rama, in my post, I forgot that at a higher airspeed, the plane is likely to be climbing, therefore the relative wind will be coming from above. You will reach the same angle of attack at a steeper pitch angle at higher airspeeds. George Patterson The desire for safety stands against every great and noble enterprise. |
"Ramapriya" wrote in message
oups.com... My bad. What I intended saying was that the wings on their own can't be tilted about, barring use of flaps; they're after all rigid structures. Even without the use of flaps, you can change the angle of the wings. That's what the elevator control does. |
Ramapriya wrote:
If my understanding is correct, an aircraft stalls beyond that AOA which, when increased any further, produces no (further) lift. If A _wing_ (not an aircraft) is considered stalled whenever the AOA is greater than the AOA of maximum lift. Beyond that point an increase in AOA produces less lift, not more. There is still _some_ lift being produced, all the way up to 90 degrees AOA. (If this was what you meant with "no (further) lift" then you have the general idea right) correct, would it be logical to infer that an aircraft's stalling AOA: The stalling AOA of a _wing_, not of an aircraft. When an aircraft stalls the AOA will of course be somewhere close to the stalling AOA of the wing, but they are still different concepts. a. is dependent on its airspeed, and is independent of its weight and weight distribution, and b. varies, for a given airspeed, with the air density (altitude) The stalling AOA of the _wing_ is generally constant, typically around 15 degrees, and does not depend on any of those factors. The _speed_ at which the _aircraft_ stalls does depend on factors like weight, but the stall will still happen at an AOA somewhere close to the stalling AOA of the wing. CV |
Peter Duniho wrote:
"Ramapriya" wrote in message If stalling AOA is reached, adding engine power before the plane goes into a stall will prevent the stall by increasing airspeed, right? By reducing the AOA actually, which happens as a consequence of increasing airspeed. But see below also. Sort of. By the time you are down to stall speed, what additional engine power actually does is to allow you to fly at *lower* airspeeds. However, And it is interesting how that actually happens. The vertical component of thrust takes a bit of the load off the wings which helps reduce the AOA and keep it under the limit of the stall. Part of the weight is in fact hanging by the propeller, like a helicopter. CV |
I agree that AOA is a nice instrument to have, but I am not convinced if
that is going to reduce the number of stall spin accidents. Most stall spin accidents despite all stall indications, such as low airspeed, buffet and descent rate. Having another instrument on the panel is not going to change the situation. "Hilton" wrote in news:5_Azd.10136$9j5.3520 @newsread3.news.pas.earthlink.net: Andrew Sarangan wrote: True, some of the larger aircraft and military jets have an AOA indicator. Most small aircraft do not have an AOA indicator. There is a good reason for this. In a large aircraft, the weight can vary substantially over its flight envelope. This will result in a large variation in stall speed. In a small aircraft, the stall speed variation is rather small, and a single stall speed can be used safely. IMHO, there is no good reason for not having an AOA indicator on GA aircraft. Stall/spin is a leading cause of death among GA pilots and passengers. Best glide (potential emergency situation) is determined by AOA. Put an AOA sensor on GA planes with a hand that smacks the pilot on the head when the AOA approaches the critical AOA and a lot fewer people will die while having fun on the weekends. Hilton |
"CV" wrote in message
... By reducing the AOA actually, which happens as a consequence of increasing airspeed. But see below also. No. Increased airspeed happens as a result of reduced angle of attack, not the other way around. Airspeed has no direct effect on AOA, though it does have indirect effects (since changes in airspeed affect what AOA you need for a given performance goal, whether that's turning, climbing, descending, or whatever). And it is interesting how that actually happens. The vertical component of thrust takes a bit of the load off the wings which helps reduce the AOA and keep it under the limit of the stall. Part of the weight is in fact hanging by the propeller, like a helicopter. Thrust does contribute, yes. But the primary reason for requiring additional power is that, while the wing is capable of generating the necessary thrust at a lower airspeed, higher angle of attack (all the way up to the stalling AOA of course), the higher angle of attack results in higher drag, requiring higher thrust. Pete |
PIREP--CO Experts low level carbon monoxide detector | Jay Honeck | Piloting | 10 | December 3rd 04 11:21 AM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
flight level in Flight simulator | Robert | Piloting | 3 | August 20th 03 07:37 PM |
