Engine failure on final
Old January 21st 05, 09:56 AM
Ron Garret
Default Engine failure on final
The discussion about cutting power on final reminded me of something
I've been puzzled about for some time now.
If you fly final with some amount of power (which I gather most people
do -- I always have) that seems to guarantee that if you lose your
engine on final you will land short, and there's pretty much nothing you
can do about it. Is that true? Or have I missed something? What
should you do if you lose your engine just after turning base to final?
rg
Old January 21st 05, 10:16 AM
Happy Dog
"Ron Garret"
Unless you do every landing power off with room to spare, yes. Or, aim for
the mid point of a 2500' plus field. There are ways to do it. But, almost
nobody does. Base turn should be doable power off in most cases in a 172 or
similar glider.
Land short. That's why the slow idle check during the run-up is important.
moo
Old January 21st 05, 11:43 AM
Cub Driver
On Fri, 21 Jan 2005 00:56:22 -0800, Ron Garret
Yes, that's true, and it's why the Old Timers taught power-off
landings, and it's why I fly them routinely.
(To tell the truth, I also like the feeling of whooshing down without
that engine blatting away. Perhaps I was a glider pilot in another
life.)
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
Old January 21st 05, 01:41 PM
Neil Gould
Recently, Ron Garret posted:
you can do about it. Is that true? Or have I missed something? What
final?
As I was taught, the point of flying safely is to always have a viable
option. So, I fly tight patterns and make power-off landings as a rule. If
I make it to the pattern, I can make it to a runway, engine or no.
Neil
Old January 21st 05, 02:07 PM
Larry Dighera
On Fri, 21 Jan 2005 12:41:39 GMT, "Neil Gould"
wrote in
Truly? So when you're #5 in the pattern (which necessitates a
looooong, extended downwind leg) you just fly the pattern at 2,000'
then?
Old January 21st 05, 03:54 PM
Corky Scott
rg
Can anyone cite an instance when a pilot lost his engine while on
final and landed short because of it?
Thanks, Corky Scott
Old January 21st 05, 04:02 PM
Denny
you
Worse than that, is that I have noticed that many pilots seem to take
off using power... That guarantees that they absolutely will land short
if they lose power... What should we all do about that?
Denny jeez
Old January 21st 05, 04:05 PM
Sport Pilot
wrote in
viable
rule. If
then?
Noting you can do about requested extended downwind leg. But you could
keep your decent low or delay the decent to give you more reach. Also
consider a flapless landing to keep the glide angle shallow. Wait to
add flaps when you are certain to make the runway.
Old January 21st 05, 04:31 PM
then?
I was about to ask that, too. Depending on the airport, it would be
tricky to make power-off approaches from the downwind *as a rule*. Not
only is there the situation Larry mentioned above (3rd, 4th or 5th
behind who-knows-what), but also airports with two runways that are
staggered by 1500' or so and ATCs frequently instructing you to switch
runways at the last minute.
Old January 21st 05, 04:58 PM
David Gunter
So what do you do when you are on 1/4-mile final and you spot a coyote
or two playing around in the middle of the runway? This has happened to
me repeatedly in Santa Fe and just serves to remind me that I want some
backup power just in case the landing isn't assured. Perhaps you don't
see this where you fly "routinely" but it could always be something else.
I typically pull the throttle all the way back to idle about 1/4 mile
out, Cessna 172.
-david
David Gunter
Santa Fe, NM
life.)
Warbird's Forum:
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 07:23 PM
Diesel engine Bryan Home Built 41 May 1st 04 08:23 PM
Night engine failure in Boston Dan Luke Piloting 8 February 13th 04 06:33 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 05:09 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
