IFR class E
Old January 26th 05, 04:18 AM
mindenpilot
Default IFR class E
I'm VFR and have some questions about IFR.
I've been toying with the idea of pursuing an IFR rating, especially due to
the recent (uncharacteristic) fog.
I've only flown real in IMC once.
I was at a class D airport, and the CFI got clearance before takeoff.
He got all kinds of instructions for going up through the soup.
I'm wondering how that works at a class E airport, like the one I'm based at
in Minden, NV.
For example, if there was real IMC (a fog layer at 300 AGL), would you be
allowed to take off?
If so, what would be the procedure?
How would you ensure separation from other traffic?
The closest tower is Reno, but they wouldn't be able to get any radar fix
until you climbed to about 3500' AGL.
Similarly, for landing (assuming a GPS approach is approved, there is no
ILS, etc).
What would you do once Reno lost radar contact?
Thanks,
Adam
N7966L
Beech Super III
Old January 26th 05, 04:34 AM
Peter R.
in Minden, NV.
The communication note for Minden reads (area code left out in the event
of some Usenet telephone number spam harvester, if there is such a
thing):
FOR CD/P CALL RENO APCH CTL ON (xxx) 348-8840
Thus, you would call this number while on the ground after your
preflight to receive your clearance. Assuming there was not an IFR
aircraft approaching to land, Reno approach would issue you a clearance
on the ground with a void time. This means you have until that time to
take off and climb to an altitude where they will pick you up on radar.
During this block of time, the airport is yours. No other aircraft can
take off IFR until you do.
If the field were IFR, the system restricts other IFR aircraft from
taking off until you do. Again, if an aircraft were on an IFR
approach, it would have to land and call to cancel the IFR flight plan
before Reno would issue you the clearance to depart.
Take off, follow the departure/obstacle clearance procedure, then fly
your clearance. As soon as able, make contact with Reno. Even if they
cannot pick you up you might be able to establish radio contact with
them to let them know you are off and climbing.
ILS, etc).
Reno would vector you to the IAF, then clear you for the approach. At
that point, you are on your own to fly the published approach to the
best of your ability.
Once on the ground, you must immediately call Reno on a land line to
cancel your IFR flight plan so that a) they know you landed safely and
b) they can release the airport for other IFR operations.
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old January 26th 05, 04:37 AM
Peter R.
I made a mistake here. I should have typed: This means that you have
until that time to take off and make radio contact with Reno approach.
Big difference between that wording and Reno making radar contact, since
it is possible to make radio contact well before radar contact.
Peter
Old January 26th 05, 04:40 AM
BTIZ
I'll let the Reno/Minden pilots answer the particulars for that airport...
but in general, at an airport out side ClassD, you'll need to get an IFR
clearance from the controlling agency, whether that be Reno Approach or
Center. Normally a phone or radio relay through a FSS. My Minden approach
plates tell me Reno Appch Control is in charge.
Remember, a ClassD tower is a VFR tower, he had to get the IFR clearance
from the local IFR ATC facility, rather it be an approach control or Air
Route Traffic Control Center (ARTCC).
ok, so I looked up MEV in my approach charts: I only see GPS approaches into
Minden (MEV), the minimum descent altitude is 6220MSL (1494 AGL), so... a
smart minded IFR pilot would not depart into a 300ft ceiling knowing he
could not get back to MEV in an emergency.. Even the ILS approach into RNO
has an 1100ft AGL Decision Altitude, so that would not be a suitable
situation/alternate on a 300ft day. But there is nothing stopping a Part91
IFR pilot from departing into a 300ft overcast in this situation.
As for Radar coverage from ATC.. not an issue, you need to be able to, and
will be expected to fly anywhere without radar coverage. ATC using radar
makes it nicer to run traffic closer together and handle more aircraft than
using the tried and true manual separation methods. ATC will be blocking all
IFR traffic up to the minimum IFR altitude that you are cleared to until
they can see you, and if they cant see you (radar failure or your
transponder failure), then all traffic stays above until you get "found" and
have cleared the area.
Now, the weather issue, snow on the ground? fog in the area (warm air over
cold ground). What is the outside temperature and where is the freezing
level... does the cloud layer go to the freezing level or higher?.. flying
your Musketeer SuperIII into a freezing layer would not be good.
It is difficult to maintain IFR proficiency even down here in LAS single
engine with a Piper Arrow or Bonanza. When the IFR rolls in, the minimum IFR
altitude is well into or above the freezing level. The lowest minimum IFR
altitude (on airways) around the Mustang VOR is 10,000MSL.
I came back VFR from Cal City to VGT at 9,500MSL through the MOAs and the
OAT was 36F. If IFR were required, long way around and minimum IFR altitude
on the airway is 12,000 or 14,000ft.
But getting an instrument rating is a smart thing to do, but not always a
save all.
BT
(former ZBOS ARTCC)
"mindenpilot" wrote in message
to the recent (uncharacteristic) fog.
at in Minden, NV.
ILS, etc).
Thanks,
Adam
N7966L
Beech Super III
Old January 26th 05, 04:47 AM
Peter R.
BTIZ ) wrote:
BT
(former ZBOS ARTCC)
Really? That's the first time I read you were a former controller in
the few years I have been reading these groups.
I have an additional respect for you, as I tried, but failed, to become
a controller in the late 80s.
Peter
Old January 26th 05, 04:51 AM
Dan Thompson
I assume by "fog layer at 300" you mean fog from the ground topping out at
300. Otherwise you would say an "overcast layer at 300."
Either way, you can depart from a Class E (or Class G) untowered airport IFR
with what is called a void time clearance. You call up the approach
facility, over the phone or radio in some cases, and either directly or
relayed through an FSS, and are cleared to take off IFR in a short slot time
that ends at the "void time." In the old days we used to call from a pay
phone at the FBO, then hurry to take off before the clearance expired. Now
we call from the end of the runway on the cell phone when ready. Works like
a champ, and once you see it done it is not as hard as it sounds.
Separation is provided all the way to the ground if it is a true Class E
airport (somewhat rare.) At a Class G airport, separation is not provided
until you enter Class E. While your void time clearance is in effect, ATC
will not allow any IFR traffic into "your" airport. The big sky theory is
your assurance? of separation in Class G.
Landing is pretty much the same way in reverse. You are cleared to execute
the approach before you lose ATC on the radio. It does not matter if they
can see you on radar or not. You call on the phone when you are on the
ground to close your IFR flight plan. Until you do, ATC will hold all
traffic going in or out IFR. Again, it is "your" airport until you cancel
IFR or close your plan.
Hope this answers your questions.
at in Minden, NV.
ILS, etc).
Thanks,
Adam
N7966L
Beech Super III
Old January 26th 05, 05:08 AM
Mike Rapoport
I was based at Minden for several years and still have property there. To
depart MEV IFR you call Reno Approach and get your clearance over the phone.
Be aware of the following limitations for IFR into and out of MEV (and the
rest of the Carson Valley).
The approach minimiums are over 1000'AGL so you certainly can't land with
300' ceilings. The only approaches are GPS.
The approved departure proceedure requires RNP .3nm which means IFR approved
GPS.
There is almost no flyable IMC in airplanes without known ice certification
and radar. There is almost always icing at the MEA and above. The
exception to this is when there are thunderstorms.
The MEAs south of MEV are high. Almost all routes south and west will
require O2.
The east side of the Sierra is a particularly unforgiving place to fly and
there are fatailies in the area virtually every year (or more). The Carson
Valley is better than the Owens Valley to the south but it is not really
suitable for single engine IFR. There is a reason that glider pilots from
all over the world come to Minden! That reason is the powerful weather.
In short, to fly IMC in the area you need GPS, Known Ice, Radar, O2 (and the
ability to climb fast) and should really have a big heavy plane because the
turbulence is so bad.
Mike
MU-2
at in Minden, NV.
ILS, etc).
Thanks,
Adam
N7966L
Beech Super III
Old January 26th 05, 05:10 AM
mindenpilot
Thanks to all for the responses.
I picked a hypothetical situation.
Actual conditions have actually been just as you described above, but with
fog at the surface, and visiblity at 1/4 SM, so I wouldn't even be able to
see the other end of the runway!
I was citing conditions I saw in both Dallas and the SF Bay area.
Thin layer of clouds (maybe 200 ft thick) at about 300-500 AGL, then
beautiful on top.
I should have been more clear, stating that I wouldn't even be able to get
radio contact with Reno until 3000-3500 AGL.
Currently, I can't even get ATIS until I'm about 3000' AGL.
Anyway, I think you've answered my questions..now I have one more.
Since the only approach in Minden is GPS, does it make sense to get an
IFR-certified GPS?
Anyone have any preferences.
I don't want to put a $10K upgrade in ;-)
Thanks,
Adam
N7966L
Beech Super III
Old January 26th 05, 05:15 AM
Mike Rapoport
over cold ground). What is the outside temperature and where is the
freezing level... does the cloud layer go to the freezing level or
higher?.. flying your Musketeer SuperIII into a freezing layer would not
be good.
beautiful on top.
IFR-certified GPS?
Thanks,
Adam
N7966L
Beech Super III
Read my other post. You might want to spend some time talking to Bill Hutt
or someone else who has flown a lot in the area about the utility of flying
IMC in your current airplane. Basically it isn't enough airplane for IMC
flying in that area. Even a heavy twin like a 421 is marginal.
Mike
MU-2
Old January 26th 05, 05:21 AM
mindenpilot
Hutt or someone else who has flown a lot in the area about the utility of
flying IMC in your current airplane. Basically it isn't enough airplane
for IMC flying in that area. Even a heavy twin like a 421 is marginal.
Mike
MU-2
Bummer.
On the other hand, this weather is really uncharacteristic.
Last winter, I flew all winter long with very few days that weren't VFR.
On the whole, I would say 90% of the days here are VFR.
Sorry to ask IFR-illiterate questions, but here's more.
A more realistic mission would be flying from Minden to the Bay Area.
Like I said, it's usually VFR in Minden, but there is often fog in the Bay
Area (Santa Rosa, STS).
I don't have IFR plates, but I know STS is pretty flat, and is at sea level
(100').
Not sure about icing conditions, but it's definitely warmer in the winter
than here in Minden.
Does this sound like something that I could handle in my Super III, or do I
need the heavy metal?
Thanks
Adam
N7966L
Beech Super III
Carrying flight gear on the airlines Peter MacPherson Piloting 20 November 25th 04 12:29 AM
Negative XPDR - under the outer ring of Class C bcjames Piloting 8 August 30th 04 11:49 PM
Must the PLANE be IFR-equipped to fly over17,500? john smith Home Built 11 August 27th 04 02:29 AM
Overlapping class C & D Andrew Sarangan Piloting 14 May 6th 04 04:08 AM
