Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Opinions/Experience with PC Flight System's eGyro-3, anyone?
Old January 14th 04, 10:15 PM
Andrew Gideon
Default Opinions/Experience with PC Flight System's eGyro-3, anyone?
I'm considering trying to convince my club to switch to the eGryo-3 instead
of a differential pressure vacuum backup. However, I'm curious about a
couple of things.
The differential pressure mechanism is - I believe - STCed. What would we
need to go through for a panel mounted eGyro-3 (assuming it isn't STCed)?
A field approval, requiring an inspection? Complex? Expensive?
We're in the area of the Teterboro FSDO, if that makes a difference.
Also, the differential pressure mechanism powers the DG. I see that the
eGyro-3 provides AI and TC backup. Does it also provide heading
information?
Finally, what about electrical problems? The differential pressure
mechanism is immune to this, but the eGyro-3 is electrically powered. Of
course, PC Flight System has a portable solution, but I'm really looking
(at the moment; check again with me in a little while {8^) for a
panel-mounted solution.
Any insights would be appreciated.
Thanks...
Andrew
Old January 14th 04, 11:12 PM
Ron Natalie
"Andrew Gideon" wrote in message online.com...
couple of things.
I presume you're talking about the Precise Flight standby vacuum (or something
like it). Why get rid of it if it is already there?
Unlikely to be approved for installation if you asked any FAA type. These
things do not meet the requirements for aircraft parts. The STC would be
the least of your worries. The big question would be if such a system would
even require you to mention it to the FAA. I'm not going there, you will get
differing opinions from different people.
information?
Presumably the differential pressure system feeds ALL the vacuum instruments
which is typically the DG and the AI. The TC is usually already electric.
The eGyro-3 provides only the AI and TC functions (why no heading info
I do not know)
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 10:20 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
The cost sharing - reimbursment - flight for hire mess Roger Long Piloting 18 October 21st 03 03:12 PM
