Is this chopper about to crash?
Old December 18th 03, 04:54 AM
Trentus
Default Is this chopper about to crash?
It would appear that the majority in aus.aviation seem to think this shot
http://www.thedamnedestthing.com/page15.html was moments from impact, but
then they fly the wrong type of aircraft in that newsgroup, so what would
they know.
If not how is it still in the air at that angle? My "hunch" is that it could
be feasible to fly at that angle while towing a load, but it's certainly
just a hunch, my knowledge of physics is high school level, and helicopter
flight knowledge even less.
Trentus
Old December 18th 03, 05:39 AM
Larry Fransson
Ask the question again when the server is serving.
Old December 18th 03, 08:25 AM
Larry Fransson
Okay, it's working now.
I don't know, but it doesn't look good to me!
Old December 18th 03, 02:01 PM
SelwayKid
"Trentus" wrote in message ...
they know.
Trentus
That picture has been around for a long time now and is amazing to
those of us, well at least me!, who fly helicopters for a living. I'm
sure the crew lifted off wondering what it would take to make this
work and had some help on the ground to tell them what was happening
where they couldn't see.
As they pulled pitch and forward cyclic I can only imagine what the
view was in the cockpit and certainly someone was watching the blade
tips to avoid ground contact while they waited to see if the load
would move or not.
There is no doubt in my military mind they were VERY cognizant of what
they were doing. This kind of ranks up there with the USMC flag
raising on Suribachi for dramatic impact.
Before you holler at me...I am an old 10 year active duty Marine and
still stand at attention when the Marine Hymn is played and I've got
more than 21,000 hours of interesting flying.
Old December 19th 03, 04:42 AM
Bob
Actually as seen in that that photo, the Boeing Vertol 107 is towing the
sled seen behind it. The photo was shot in Greenland. and I actually have
or did have an original copy from the film.
Bob
Old December 20th 03, 03:15 AM
John Roncallo
Clark wrote:
"Trentus" wrote in
shot http://www.thedamnedestthing.com/page15.html was moments from
impact, but then they fly the wrong type of aircraft in that newsgroup,
so what would they know.
could be feasible to fly at that angle while towing a load, but it's
certainly just a hunch, my knowledge of physics is high school level,
and helicopter flight knowledge even less.
No, it's not about to crash. Check out http://www.colheli.com/colheli.html
and look at the The Hover Barge Photo under the Nesw & Events menu.
According to the article they only had a 25° nose down attitude. It
looks alot worse than that in the picture. Since most helicopters of
this size typically lift twice there own weight (when empty). I would
estimate that the maximum theoretical nose down angle whould be 60°.
This gives you a thrust vector component of twice youre vertical
component. However the transmission lube systems would not like this at all.
John Roncallo
Old December 20th 03, 04:42 AM
Rhodesst
John Roncallo
As long as you can maintain a vertical component of lift equal to the weight of
the helicopter, you'll be Ok. Either way, that looks like one hell of a
balancing act.
I don't know for sure but that looks like it might not be too much different
from a simple (huh?) hover with a heavy sling load as far as control imputs are
concerned. Of course, I'm probably wrong about that. It's never that easy, if
hovering is considered easy. :-)
Fly Safe,
Steve R.
Old December 20th 03, 05:46 AM
Trentus
"Bob" wrote in message
Bob
Yes, I was aware it was towing, but that's a scarey angle, the view from the
cockpit must have been pretty amazing, they'd see little more than the
ground, but I just had a "hunch" that it would still be ok, despite how it
appears, and that a crash ISN'T imminent. But that's gotta be one pretty
damned brave, or very confident in his abilities, pilot.
Trentus
Old December 20th 03, 03:30 PM
The camera that took the photo was above the helicopter in the photo.
This makes it look like its at a lower angle than it really is. Not
only that, but the article says that a telephoto lense was also used
which can also alter perception.
If you have ever seen MASH on TV, the opening credits show what
appears to be helicopters flying backwards. In reality, its
helicopters flying forward with the camera behind them flying forward
faster.
Dennis Hawkins
n4mwd AT amsat DOT org (humans know what to do)
"A RECESSION is when you know somebody who is out of work.
A DEPRESSION is when YOU are out of work.
A RECOVERY is when all the H-1B's are out of work."
To find out what an H-1B is and how Congress is using
them to put Americans out of work, visit the following
web site and click on the "Exporting America" CNN news
video: http://zazona.com/ShameH1B/MediaClips.htm
Old December 24th 03, 12:07 AM
John
"Rhodesst" wrote in message
all.
John Roncallo
weight of
balancing act.
different
imputs are
easy, if
Fly Safe,
Steve R.
Ok i have read all the posts up to 23rd dec on this thread, i understand
it's some sort of an illusion.
I know next to nothing about sling operations.
I'm just surprised that no one seemed to think about the principles of
dynamic roll over and try to apply them here ?
I know the sling load probably isn't stuck to the ground ..but could become
stuck, then there is inertia and acceleration considerations, i have only a
fuzzy understanding of all this ...but i think that the maximum nose down
angle when towing would be a lot less than
anyones gut feeling or quick calculation based only on thrust to weight
ratios and thrust vectors.
Do i have a point ?
I'm sure someone will elaborate on this?
update on Montrose crash Bob Moore Piloting 3 November 29th 04 02:38 PM
Homebuilt Airplane Crash Harry O Home Built 1 November 15th 04 03:40 AM
Bizzare findings of Flight 93 crash in PA on 9-11 Laura Bush murdered her boy friend Military Aviation 38 April 12th 04 08:10 PM
Sunday's Crash in LI Sound Marco Leon Piloting 0 November 5th 03 04:34 PM
Homemade plane crash Big John Home Built 9 October 17th 03 06:45 PM
