Groen Bros.
Old May 5th 04, 11:19 PM
Al Colunio
Default Groen Bros.
Hi. I have been lurking lately. I have an interest in Gyroplanes (not enough
money for helicopters). Does anyone have any comments about the new gyro kit
that the groen bros are introducing, or is it to early to tell much. Thanks
for any info.
Old May 5th 04, 11:38 PM
Stu & Kathy Fields
I got a ride in the prototype at Arlington last year and was impressed with
the stability. Was not impressed with the control forces HIGH. Prototype
used an RAF cabin and was much closer than what I was used to with my
Safari. I never did find the rudder pedals. I tried an stock RAF after my
ride in the Groen and found the rudder pedal forces in that bird were pretty
much the same HIGH. All that said, I have a great load of respect for Jim
Mayfield and his gyro knowledge and engineering expertise. In the past,
I've had some time with Jim and he knows what he is doing. I think that
their gyro will be the leading two seater quickly;
Stu Fields ex gyro pilot turned helo pilot.
"Al Colunio" wrote in message
m...
enough
kit
Thanks
for any info.
Old May 6th 04, 08:42 AM
Ken Sandyeggo
I have the first customer-converted gyro converted to Sparrowhawk
specs done by Jim and his crew. I started with the RAF without a
horizontal stabilizer and after a few months, I was considering
selling it. It was scary to fly. The slightest updraft and the nose
would go shooting upwards, opposite of what a stable craft of any kind
should do. I then had a stab made and that was a lot better. I then
had the conversion done and what a difference. It flies like a
Cessna. I can actually relax my hand on the stick and not be fighting
it most of the time.
The stick is a little heavy, but then I'm not trying to do stupid
human tricks either. You get used to it. Just like a Cessna doesn't
respond like a Pitts to inputs, neither does the Sparrowhawk to an
open-frame, more squirrely machine. The Sparrowhawk kit is similar to
mine but with a wider and higher cabin and a pedestal instead of a
flat-panel. The big difference is the Sparrowhawk was actually
engineered, stress-tested and comes with aircraft grade components and
hardware and an actual suspension system, something unheard of at RAF,
who still considers a horizontal stab a "contraption" and has an
almost foot-high thrustline trying to tumble you over. The
Sparrowhawk is center-line thrust.
Ken J. - Sandy Eggo
"Stu & Kathy Fields" wrote in message ...
m...
enough
kit
Thanks
for any info.
Old May 6th 04, 05:05 PM
Stu & Kathy Fields
Ken: I've got time in nearly all the Cessna, Piper, Ercoupe, Aeronca,some
Kitfox and some RV6, and some Mooney as well as the Benson, Safari, Bell 47,
Brantly, UH-1 and T-38 which includes supersonic flite. I've never flown
anything with the stick forces I found in the Sparrowhawk prototype. What
is the reason for such High stick forces? Has Groen kept this stick force
gradient in the finished copy?
Stu Fields Safari pilot
"Ken Sandyeggo" wrote in message
om...
Ken J. - Sandy Eggo
with
Prototype
my
pretty
m...
enough
gyro
kit
Thanks
for any info.
Old May 7th 04, 07:37 AM
Ken Sandyeggo
Stu,
I don't know about the stick forces on the Sparrowhawk kits. I've
never flown another type gyro except the RAF and now my Groen modified
ship. I'm comfortable with the "solid" feeling as I fly mine pretty
much like a Cessna.....fairly conservatively. I like to pull out a
sandwich and a beer from the cooler, light up a cigar and read the
Enquirer while I'm heading out, without having to worry about it
falling off into a dive.
om...
Ken J. - Sandy Eggo
with
Prototype
my
pretty
m...
enough
gyro
kit
Thanks
for any info.
Old May 7th 04, 02:48 PM
Shiver Me Timbers
Ken Sandyeggo wrote:
I like to pull out a sandwich and a beer from the cooler,
light up a cigar and read the Enquirer while I'm heading out,
without having to worry about it falling off into a dive.
Oh come on Ken.... Stop lying like the proverbial rug.
Isn't more like lighting up a smoke and sipping a starbucks while your
little two legged co-pilot with the bottomless stomach does the stick
time.
He must have a hundred hours in his own logbook by now.
Old May 8th 04, 02:22 AM
Stu & Kathy Fields
Jesus (pronounced Hay Seuss in Calif) You have come up with the best ad for
any Gyro I've ever seen!! In My Safari, I've only recently learned how to
change frequencies without first landing. I can't even think about the beer
due to the slightly intoxicating affect of thinking about a cold one that
would affect my flying to a dangerous extent. Where do I trade my Safari
for a Groen Mod? Or maybe I should ask Mayfield to do a mod on the
Safari....I will have to say that your "Solid" equates to my "stuck fence
post". Should we ever meet, I will definitely avoid arm wrestling with you.
Stu Fields
om...
Stu,
Aeronca,some
47,
flown
What
force
om...
Ken J. - Sandy Eggo
impressed
with
Prototype
my
after
my
were
pretty
for
ast,
that
m...
(not
enough
new
gyro
kit
much.
Thanks
for any info.
Wright bros. - True distance Steve Beaver Home Built 8 January 15th 04 07:16 PM
Starman Bros. Auctions Larry Smith Home Built 1 December 8th 03 05:36 PM
