Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Rotorcraft
Plasma Reduces Jet Noise (Turbines?)
Old June 25th 04, 11:41 PM
sanman
Default Plasma Reduces Jet Noise (Turbines?)
Here's an article:
http://www.newscientist.com/news/news.jsp?id=ns99996073
So if plasma reduces jet noise, then can it reduce turbine noise?
There are gyroplanes like the one made by Groen Bros, and also the old
Fairy, which used ramjets on the rotortips to boost rpm and lift
during takeoff, but this caused terrible noise problems. Could this
plasma noise-deadening approach make the ramjet rotor-assist more
practical and feasible?
Old June 27th 04, 12:45 AM
Otro Malo Más ...\(Aka Gokú\)
Conventional turbo-shaft engines aren't quieter with these thecnology because it
noise has different origin (the turbine blades in some ways), the case of the
ramjets is differnt, in this case the technology is aplicable, but not easy to
"fine tune", and the plasma machines hads lows MTBF.
This is not the only way to reduce the noise of the engines, other techonology
is the active noise canceling using small piezo electric flaps on the gas
stream, this could be used into the engines and on the rotors (Boeing Vertol and
Eurocopter are working on it right now, GE and P&W also does research on this
technology).
Regards,
JAngel
"sanman" escribió en el mensaje
om...
| Here's an article:
Cherokee Strobe Noise Jonathan Goodish Owning 20 November 2nd 04 02:42 AM
Funny noise update Peter Duniho Piloting 1 July 1st 04 02:58 PM
Plasma Reduces Jet Noise (Turbines?) sanman Home Built 1 June 27th 04 12:45 AM
Prop noise vs. engine noise Morgans Piloting 8 December 24th 03 03:24 AM
Getting rid of turbines. (grin) ArtKramr Military Aviation 15 December 6th 03 05:25 AM
