Flying while deaf
Old September 25th 04, 06:35 PM
bryan chaisone
Default Flying while deaf
How does one communicate with ATC when one is deaf?
Bryan "The Monk" Chaisone
http://cgi.ebay.com/ebaymotors/ws/eB...tego ry=31853
Old September 25th 04, 07:16 PM
Steven P. McNicoll
"bryan chaisone" wrote in message
om...
Via light gun signals.
A better question might have been, "What does having been owned by a deaf
helicopter pilot have to do with the auction of a car?"
Old September 25th 04, 08:59 PM
Steve R.
ink.net...
om...
That's for communications with the control tower at a controlled field
airport, not ATC!
Agreed!
Fly Safe,
Steve R.
Old September 25th 04, 09:08 PM
Steven P. McNicoll
"Steve R." wrote in message
airport, not ATC!
It's not ATC that staffs control towers?
Old September 25th 04, 09:51 PM
Steve R.
ink.net...
airport, not ATC!
Maybe, but if the guy is 20 miles out and needing clearance to enter the
airport traffic area, he's not going to be able to "see" the signal lights
very well, is he? What if he needs to transit a Class B airspace to get to
the controlled field? If he can't hear, he can't communicate with ATC,
thus, he can't get clearance. I've got to wonder if this one isn't a scam.
Signal lights are for short range, visual communications and there's no use
for them outside the airport traffic area.
Fly Safe,
Steve R.
Old September 25th 04, 11:51 PM
Peter Duniho
airport, not ATC!
very well, is he?
Are you aware of any other method by which a deaf pilot communicates with
ATC?
Seems to me that Steven's reply quite accurately described how a deaf pilot
would communicate with ATC. The fact that the deaf pilot cannot communicate
with ATC in all circumstances is irrelevant to the answer.
Yes, one might infer that it's relevant to the original question, but it's
not Steven's way to go out of his way to be helpful (no offense
Steven...that's just how your posts are) and the original question didn't
ask how deaf pilots *can't* communicate with ATC. Steven *did* answer the
question asked, and as far as I know, did so completely (that is, he left no
other method out).
If you know different, we're all ears (except the deaf pilots ).
Pete
Old September 26th 04, 12:04 AM
Toks Desalu
very well, is he?
I am not sure about bravo airspace due to nature of traffic. For other
controlled airspaces, deaf pilot already got his clearance. In order to
enter controlled airspace, he/she can contact tower by phone (They use
special device called TTY to communicate through phone) The deaf pilot will
be given instructions and squawk code.That's it. He/she will follow that
instructions.
Again, I dont think the deaf pilot can enter bravo airspace, even with a
special clearance due to nature of traffic. Besides, bravo airspaces only
cover a small percent of whole airspace system. I am pretty sure that they
can afford to make small detour if there is a conflict.
use
It is not a scam or anything. They fly strictly under VFR, like any other
pilots who fly without radio.
Toks Desalu
PP-ASEL
Dyin to soar!
Old September 26th 04, 02:11 AM
Steve R.
Hi Peter & All,
Well, obviously, I missed part of the conversation. If I spoke out of turn,
I apologize. The part I did catch didn't make sense to me at the time and I
was probably taking things a bit too literally.
Toks Desalu made some good points in his reply, points I hadn't considered.
Yes, there will be areas in aviation that the hearing impaired will have
trouble with but there are still plenty of places that they are more than
capable of enjoying safely. As they rightly pointed out, there's still
plenty of places where a radio isn't even required.
Again, if I spoke out of turn on this issue, I apologize. I certainly did
not mean any offense to the hearing impaired.
Fly Safe,
Steve R.
pilot would communicate with ATC. The fact that the deaf pilot cannot
communicate with ATC in all circumstances is irrelevant to the answer.
no other method out).
Pete
Old September 26th 04, 03:31 AM
Steven P. McNicoll
airport, not ATC!
Maybe,
Maybe it's not ATC that staffs control towers? Who do you think staffs
them?
but if the guy is 20 miles out and needing clearance to enter the airport
traffic area, he's not going to be able to "see" the signal lights very
well, is he?
What is this airport traffic area that requires clearance to enter at 20
miles out?
What if he needs to transit a Class B airspace to get to the
controlled field?
Then he's almost certainly outta luck. ATC must separate all traffic in
Class B airspace and it's rather hard to do that without communications.
If he can't hear, he can't communicate with ATC, thus,
The question was, "How does one communicate with ATC when one is deaf?"
It's a simple question. One CAN use light gun signals. Can you think of
any others?
Incidentally, there was a time when most aircraft had no radios and light
gun signals were the main form of pilot/controller communications at towered
fields.
use for them outside the airport traffic area.
That's all true. So what's your point?
Incidentally, we haven't had Airport Traffic Areas in the US for almost
eleven years now.
Old September 26th 04, 06:50 AM
Toks Desalu
turn,
I
I can see where you going with this. You probably took this a bit too
literally. That bring us back to the previous question. "What does having
been owned by a deaf helicopter have to do with the auction of a car?" I
don't know. Maybe, some people think that car have a sentimental value.
Maybe, the seller is trying to make a profit by using that article. I don't
know what the seller's motive behind this. Either way, I think his
advertising is plainly stupid. But, the seller might get lucky.
Toks Desalu
PP-ASEL
Dyin' to Soar!
Routine Aviation Career Guy Alcala Military Aviation 0 September 26th 04 12:33 AM
World War II Flying 'Ace' Salutes Racial Progress, By Gerry J. Gilmore Otis Willie Military Aviation 2 February 22nd 04 03:33 AM
Flying is Life - The Rest is Just Details Michael Piloting 55 February 7th 04 03:17 PM
Wm Buckley on John Kerry Big John Piloting 22 February 7th 04 02:19 AM
Announcing THE book on airshow flying Dudley Henriques Piloting 11 January 9th 04 07:33 PM
