Question about Add on Aircraft
Old August 8th 03, 06:50 AM
Dudley Henriques
Default Question about Add on Aircraft
I have a question.
Do simulator software developers use the default key assignments in FS2K2
(or any sim for that matter that their aircraft is designed to be used
in)....when they design an add on aircraft to be used in that simulator?
Reason I ask is this. Can changing the default key assignments to another
key....say the idle cutoff from cntrl/shift/F1 to say...cntrl/q for example,
foul up an installation of an add on aircraft? Keep in mind I'm not talking
about controller button assignments. That doesn't change the default key
that function is assigned to in the simulator. I'm just talking about
changing key assignments only and asking if changing them might cause
conflicts with add on aircraft!!!
Thanks.
Dudley
Old August 8th 03, 04:54 PM
Dudley Henriques
Many thanks. I guess this isn't the problem. I'll keep looking.
D
"Handsome" wrote in message
I imagine the only conflict to be wary about is if you assign a key/key
combo that already has an assignment. You will loose the original
assignment. If you attempt this however a warning will appear to tell you
what the original assignment is.
In FS2002, all key assignments are recorded in the FS2002.cfg file so they
do not make any changes in any aircraft configuration.
I assume '04 is the same.
All the main key commands seem consitent with all addon and default
aircraft
in my experience.........so if you make an assignment change it will apply
to all your a/c.
Hope this helps in some way.
Martin
nk.net...
| I have a question.
FS2K2
another
example,
talking
| Thanks.
| Dudley
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 08:00 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 01:14 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 03:13 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
