cpu max'd out
Old November 17th 03, 08:31 PM
Murphy
Default cpu max'd out
I'm running FS2004 and from the moment I start it up my cpu is running at
100% according to Task manager. My system is an Athlon 1.34 GHz cpu with
896meg RAM and a NVIDEA GeForce4MX440 with AGP8X.0 video card. I am running
my monitor at 1280 X 1024 with 32 bit color selected. The result is scenery
loss in the form of large blocks of scenery either missing or flashing on
and off repeatedly. This for some reason only affects the scenery and not
the panel. All FSIM settings are at default. Any help appreciated.
Old November 17th 03, 08:45 PM
Peter Duniho
"Murphy" wrote in message
news:zeaub.415810$pl3.146195@pd7tw3no...
Game applications using 100% CPU is pretty much par for the course. Even in
situations where the video card is the frame rate bottleneck, games are
usually written in a way that spends any time not dealing with graphics
handling game mechanics and user input instead.
If the game's not using 100% of the CPU, it's not trying.
Your problems with the scenery graphics are likely related to something
else. Maybe your graphics settings are too high, or maybe there's some sort
of data or code corruption. Hard to say.
Pete
Old November 17th 03, 09:10 PM
John Hall
Yep, most games use 100% of the CPU and are the most demanding application
that can be run on a PC. You are running FS2004 at a high resolution for
your video card. The MX series of Geforce cards are not really capable of
heavy lifting at high screen resolutions. Try dropping your resolution to
800x600 and things should improve. If you have the cash, invest in a new
Direct X 9 capable video card from ATI or Nvidia, one with 128 megs of ram.
JK
at
in
sort
Pete
Old November 18th 03, 07:30 AM
Roger Halstead
On Mon, 17 Nov 2003 12:45:09 -0800, "Peter Duniho"
Probably either video or buss related.
I run either CB FS, or 2004 AND the Seti at home project at the same
time. It's not unusual to have other apps up at the same time
although they end up in the background with reduced cycles.
I haven't had any problems with the display freezing even with all the
extra stuff, but the CPUs here run 100% just about 100% of the time,
24 X 7 as if nothing else is in the way the seti program will push it
up to 98 to 100% along with the system apps.
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
Pete
Old November 22nd 03, 07:53 AM
Murphy
Thanks to everybody who took the time to respond.
Murphy
"Roger Halstead" wrote in message
at
in
sort
Pete
Old November 25th 03, 05:53 AM
Dashi
It's supposed to be at 100%, this is normal for FS9.
Dashi
"Jeffrey Voight" wrote in message
Turn off anti-aliasing.
Jeff...
at
running
scenery
on
not
Old November 25th 03, 06:53 AM
Peter Duniho
"Dashi" wrote in message
I just assumed he was recommending a fix for the graphical glitches, given
that we already had the "it's supposed to be at 100%" responses.
Pete
